Question about Cutter Tools
What is the difference between the angle cut blades and the shear cut blades on my bolt cutter?
  • 75 Answers
Angle cut blades have the cutter head angled at 25-35 degrees for easier insertion into tight spots. Shear cut blades are light normal scissor blades
Posted on Jan 16, 2013
My husbands clippers won't cut
Blades are NOT moving HOW TO Fix a broken Hair clipper ...
? 2:42
https://www.youtube.com/watch?v=DX4Xc47F_IE
Mar 29, 2015 - Uploaded by You can Fix It!!!!
... blade fix how to won't cut by adjusting the blade adjusting the play with the motor so ... Blades trimmer trim trimming cut cutting cutter trimmers barber ... dog clippers shear shears shearing shave shaver shaving buzz cut ...
My clippers hum like their working but dont cut - Fixya
www.fixya.com/.../t3222969-clippers_hum_like_working_but_dont_cut
Jul 25, 2008 - my clippers hum like their working but dont cut - Wahl Designer 6 (8355100) question. ... hair clippers repair. Apr 22, 2013 ' Shavers · 1 Answer ...Clippers jam and won't cut when trying to use attachments. Jan 11, 2009 ...
Clipper Maintenance - Rapid Edge
www.rapidedge.com.au/cat/maintclip.html
Clipper won't cut cleanly or easily. Lack of oil and dirty. Sometimes a hair gets caught between the blades. Lubricate and clean your Clippers regularly.
Dec 21, 2015 | Health & Beauty
My blades are a little dull will the blades still cut through a bolt?
You shouldn't really be using dull bolt cutters because it requires more force to cut through the metal which increases the likelyhood that you will get an injury. Yes you can use dull bolt cutters but you should always make sure that your blades are sharp before you use them.
Nov 14, 2013 | Cutter Tools
Are bolt cutter blades really sharp?
A pair of new or freshly sharpened bolt cutters will be sharp enough to cut through skin if you run your finger along the blade. Never run your finger along the blade to check for sharpness.
I took the blade off of my riding mower and didn't note the original position of the blades. How do I find the correct position for the replacement blades?
Dont know exactly what you mean, but turn blades with cutting angle up. Make sure if a star like center on blade is lined up and goes over the star like on shaft and tightned bolts. If it has a tray like blade holder, just put up against it and tightned bolt. The way to remember is to put the cutting edge angled side up.
Jun 26, 2010 | Garden
Need manual to see what size bolt is that holds on
Hi and welcome to FixYa. I am Kelly,
It appears your model number is 74370 There are 3 bolts one for each blade and the part number is 26-0671 or 260671 for the blade mount.
Part look up:
http://www.jackssmallengines.com
then enter part number 260671 $6.31 ea.
You can not use just any bolt for this. They are hardened bolts with an NF thread. If you use a non hardened bolt the blade will fly off when the bolt shears.
This bolt is available at most all Lawn Mower Parts Supply sources. Toro uses the same bolt on most all of their mowers.
If you do not have a Lawnmower Parts Supply near by, you might be able to go to an Autoparts supply source with yet one of the other blade bolts in hand and have them match the markings on the bolt head with yours so that you have the exact replacement bolt.
Any other parts for your mower can be found here:
http://www.jackssmallengines.com/help.cfm
Use the Search model window. each line below is a drop down window
Toro
Riding
74370 <- there are numerous models up to 74704
enter your model number if different.
Thanks for using FixYa.
Kelly
Apr 27, 2010 | Toro 42'' Zero Turn Lawn Mower 22hp Kawa...
Not getting clean/sharp cuts
the blade is spaced too far AWAY FROM THE edge --- it should shear against the edge of the base ---- but only lightly
Aug 12, 2009 | Fiskars Brands Fiskars 12" Portable Paper...
Corona professional long-handled hedge shear
try tightening the nut and bolt that hold the shears
Nov 16, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
Trimer buing Question
Double position trimmers For extended reach while on the ground, a double position trimmer avoids you having to climb up high by allowing you to adjust the handle into a right angle to the blades for a level cut across the top of the hedge. Clippings collector As you trim your hedge, collect those stray cuttings in a clippings collector for a neater finish. Automatic cut out An important safety feature, this automatically switches off the hedge trimmer once the trigger is released. Hand guard For reassuring safety, a hand guard will protect you from the moving blades and from falling cuttings as you work.
Aug 27, 2008 | Corona Hedge Shear 10 1/2" Blade Aluminum...
How to use the Total Tool Ultimate Cutter
Exactly cut straight or curvy lines with ease using the Ultimate Cutter. Safer to use than scissors, its cutting blade is enclosed by a plastic shield to keep it safely away from skin and fingers while in use. The shield also ensures perfect leveling by keeping the blade at the proper cutting angle at all times!
The Ultimate Cutter's swiveling head makes even rounded, intricate cuts easy anywhere on the page. A squishy comfort grip makes slippage obsolete.
Comment though > " I really thought this was going to be a cool item sadly it was not. The blade is not sharp and not that you would want it to be with children however ..."
Aug 14, 2008 | Toys
Cutter Tools Logo
737 people viewed this question
Top Cutter Tools Experts
JOHN LAPIER
Are you a Cutter Tool Expert? Answer questions, earn points and help others
