Question about Tools & Hardware - Others
My plate compactor won't start, what could be the problem?
    New Friend:
  • 75 Answers
Are you using the choke? do you have the throttle on at least a little bit? if these things are ok, you probably need to add oil to the engine
Posted on Jan 16, 2013
My plate compactor keeps over heating and powers off
Usually the adding the wrong fuel to your machine causes it to over heat. Check your user's manual to make sure you are using the correct fuel.
Nov 11, 2013 | Tools & Hardware - Others
How do I choose the right compactor for the job I'm planning to do?
It all really depends on what you want to do. There are three main types of plate compactors.
1. single-plate compactors only go in the forward direction, this is good for a small project like a laying asphalt.
2. Reversible plates are able to go forward and backwards.
3. High performance and heavy duty plate compactors which are usually used for deeper compaction projects.
For your at home project you should be fine with a single-plate compactor.
What does a plate compactor do?
a plate compactor uses vibrations and pounding to flatten out land so that you can pour pavement or start preparing for landscaping.
Trash Compactor Thumps
I would guess there is a limit switch that tells the machine to stop once the compactor has retracted.
May 04, 2013 | Kitchen Appliances - Others
Does my plate compactor take regular gas or a 2-cycle mix?
it takes regular unleaded gasoline. the same that you would put in your car
Jan 16, 2013 | Tools & Hardware - Others
I have a ge monogram trash compactor the ram is stuck in down position, how can we raise the ram?
Start your investigation by removing the bottom plate. There should be a belt or chain going around 3 gears. Mine has 2 metal and one plastic. The 2 metal ones are on the ends of the rods that the ram runs up and down on. The plastic one is on top of a big speed reduction gear that is turned by the motor gear. Don't pinch your fingers but see if you can turn the big gear by hand. All gears should turn. If not check each gear for broken teeth, or bad bearing & races under the 2 rod gears.
Be sure to check t
he threaded hard plastic nut that drives the screw that powers the scissors up and down. This is the part that usually fails.
Nov 24, 2012 | GE Profile GCG1580LSS 15" Built-In Trash...
Does 15" trash compactor need
If the current rating on the name plate is 15A or better, I would have it on it's own breaker
Dec 27, 2010 | KitchenAid P Series Trash Compactor -...
Have a Viking trash compactor VUC181 that will not open. Appears latch is broke. How can I get it open?
I have had this same problem and found two causes. Latch was never the problem.
#1 - Ram not in full up position. To check remove top plate and attempt to run compactor - depressing microswitch when ram is at the top. If compactor will not run you can check the ram position by turning the primary screw drive with a ratchet wrench. When ram is at the top position attempt to open the compactor drawer. The stop microswitch seems to frequently bend out of alignment - check the microswitch positioning before resecuring top plate and adjust if necessary.
#2 - Can (or other debris) is wedged in between ram and drawer. Remove back cover and carefully inspect insides of the unit - use a flashlight. Pry out any debris that may impede the drawer from opening. Attempt to open the compactor drawer.
Good luck,
Jon B.
jbroccoli@aol.com
Oct 10, 2008 | Viking 24 in. Professional Series VUD141...
Tools & Hardware - Others Logo
554 people viewed this question
Top Tools & Hardware - Others Experts
john h
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
