Question about Razor E300 Scooter
Razor e300 just has clicking sound when turn throttle what could this be
Put battery charger on lights on handle bar light up could this be a battery problem.when throttle is turned there is just a clicking sound coming from the control module
3 Suggested Answers
  • 316 Answers
SOURCE: Hi there,My girls Razor E300 is a year old wont fully charge...
My guess is the batteries have gone bad. They only last about a year before they need to be replaced. You can buy them fairly cheap off of Ebay.
Posted on Jan 04, 2013
SOURCE: razor e300 scooter charger light stays green,
I have this same problem? What do you do? I bought a new charger thinking it was that and the light stays green on it too.
Posted on Sep 09, 2010
I turn on my razor E300 the lights comes on to say its on but dont work i plug my charger in and on the chager the green light comes on saying its full charged what could b the prblem ?
The green light will come on if the charger does not sense a low battery. In other words, if you plug it into the wall, and not the scooter, it will still show the green light. It will only show a low charge (and charge the battery) if it is completely connected completing the circuit. My guess is that the battery is dead, and the plug is not all the way connected. Also, I believe the scooter has to be turned off to charge.
Oct 18, 2014 | Razor E300 Scooter
I Replaced the charger port on my Razor Mx500 Dirt Rocket and it ran fine and then just stop. The charger still indicates the batteries are charge but no power. Also I went to check the fuses and manu
Well if it's missing fuses obviously it won't run. When you turn it on does the green light on the throttle come on? if you have a voltmeter that would help. Are you sure the charger is good? if so you want to see 39 volts or so across all 3 batteries. Sometimes the switch contacts develop excessive resistance try shorting them with your screwdriver... if it runs you need a switch. can you hear the controller click when you turn the throttle?
May 21, 2014 | Razor MX500 Dirt Rocket
ALSO IF ANYONE HAS ANY TROUBLE WITH RAZOR SCOOTERS WITH GETTING THEM TO GO,IT CAN BE THE TENSIONER,WHEELS,CHAIN,MOTOR,BATTERY,CHARGER,CONTROL MODULE,RESET BUTTON,LIGHT SWITCH,AND THROTTLE.IF IT WORKS,BUT...
I purchased my batteries on E-bay. Selected the highest rated with a Square trader warranty. Delivery time was 4 days, new was was going to ask.
Delivered to my house for$21.00 with both batteries, charged and ran perfectly. Extended Warranty was also offered but declined.
Batteries still working great 6-months latter.
Mar 08, 2014 | Razor E300 Scooter
E300 , replaced both batteries , now charger light stays green although just plugged in to new batteries for first time. What is it now ?
This is most likely the control module.It can cause this.I had it happen before :) hope this helps.Buy one at www.razor.com or on ebay.
Feb 06, 2014 | Razor E300 Scooter
E300s razor
Note the charger doesn't turn itself off. It will only signal batteries are charged. You can overcharge these batteries by leaving them on the charger for too long. Suggested by retailer is two hours maximum.
Any case, Jackson Mack is correct on all counts there.
If the light is green on the charger, and the scooter still doesn't go, there might be some other issue besides the batteries themselves like loose wiring, fuse switch, etc.
Nov 12, 2013 | Razor E300s Electric Scooter With Seat
Jan 04, 2013 | Razor E300 Scooter
When plugged into the charger the throttle light and charger light are green but when I remove the charger the throttle light immediately changes to yellow and it will not move and i hear a clicking sound
your battery voltage is dropping straight off the charger - batteries are not holding charge & need replacing. You can have your batteries load tested at the battery shop to confirm.
There are guides to battery replacement and trouble shooting here
http://www.razorama.com/razor-installation-guides.html
Jun 28, 2012 | Razor MX350 DIRT ROCKET - BLUE
I know my batteries are good, but when the handle is turned all the scooter does is click. It sounds like a relay click but the scooter doesn't move. whats the deal?
How do you know the batteries are good? sometimes bad batteries can show a good voltage but when you load them it will dramatically drop. Try to measure each battery voltage while pulling the throttle ( with the drive wheel off the ground of course ) and that should eliminate the batteries as a fault.
Or you could wire the batteries to directly to the motor and see if it runs well.
If batteries are ok, then you may have a faulty speed controller or throttle.
Nov 15, 2010 | Razor E300 Scooter
Razor e300 scooter charger light stays green, batterys not taking a charge. I can hear a click when turning on throtle. battery or module?
Aug 16, 2010 | Razor E300 Scooter
Razor E300 Scooter Logo
69 people viewed this question
Top Razor Toys Experts
Clif Roberts
jasiel murphy
Are you a Razor Toy Expert? Answer questions, earn points and help others
