Question about Intel Celeron -D 2.26Ghz Computer System PC Desktop
Video card how do you replace a video card in desktop?
  • 1r1sh May 11, 2010
    Is there a video connector on the motherboard? it depends on the mobo. Model of computer and manufacturer.
    Some are AGP, PCI, SLI, depends on the computer.
  • 32 Answers
Http://www.directron.com/howtovideo.html
This link covers basically everything you need to know for installing a video card. Basically you need to determine what kind of card you are going to use based on available slots on your motherboard (PCI, AGP, or PCI-E).
Then find a new card (some really good deals on video cards at newegg.com)
Setup is pretty easy, once you physically install the card, you usually just have run the CD that accompanies your video card to install the drivers for it. If your current video card is onboard video, then you will have to disable it in device manager in order for your new card to work properly.
You also want to be sure your power supply is large enough to supply enough juice to your new video card.
Posted on Jan 25, 2009
No display
try swapping or borrowing a different monitor first- doesnt work pull out video card turn on computer then shut it off, put back in video card- does not work- replace video card with borrowed video card - doesnt work.try different vodeo card in different slot.
Oct 05, 2012 | Dell OptiPlex 380 PC Desktop
My emachien1810-01 does nit show any video. Replacing the video graphic card didnot solve the problem
Richard,
Only two things drive video. The graphics card and the motherboard. Sounds like m'board is eligible for a serious tech session.
May 17, 2012 | eMachines ET1810-01 (EMACHINES ET1810-01...
Monitor say RGB no signal?
If the monitor works with other computer then the video card in the computer where the monitor does not work is bad. You need to replace the video card. If the video card is on the motherboard, just replace it with a video card that fits into one of the PCI slots. If you were using VGA then purchase a PCI VGA Video Card.
Apr 09, 2012 | Computers & Internet
How to replace video card in hp pavilion a305w
Your desktop has integrated video. You cannot replace it, but you can buy an expansion card and install it. Your pc should have 2 free PCI slots for this. Unless you have installed something else. Just get a PCI video card.
Feb 09, 2011 | HP Pavilion a305w (DM181AR) PC Desktop
How to replace a video card on a desktop with a integrated motherboard...HP Pavilion p6533w Desktop PC
>Check your motherboard if the slot you have is an AGP or PCI slot. Then purchase and AGP Video card or PCI Video card then that's it!
>The video card will be automatically detected by your computer and so plug the Video cable to the VGA,HDMI,DVI whatever connector you have there... i suggest you purchase an HDMI cable together with the video card it will make your computer's display go WOW!!!!
>comments suggestions ratings and violent reactions will greatly be appreciated thank you...
Sep 26, 2010 | Computers & Internet
Does this computer have a video card that I can replace, or is it a mother board?
If you look at the back of your computer, note where the video cable is connected. If the video cable is connected to the back plane where the expansion cards are installed, then it has a video card inserted either the PCI slot or the AGP slot.
If the video connector is next to the LPT, COM ports, USB ports etc. then the video controller is part of the motherboard.
If you want to replace the video card, the on-board video card can be disabled from the BIOS configuration and a better quality video card can be inserted into the AGP slot.
Feb 04, 2010 | HP Compaq Presario SR2011WM PC Desktop
Replaced video card. Now sysyem won't turn on.
Did you connect you monitor cable to the new installed video card. You need to connect you monitor cable to the new installed video card. You need also to installed the CD driver of your video card.
Jan 23, 2010 | HP Compaq Presario SR1620NX...
No video on Dell C521
in this case Graphic card is faulty try no built-in/intergarted graphic card such as Nvidia or sis that u computer would support.
Mar 14, 2009 | Dell Dimension C521 PC Desktop
Inspiron 531S Desktop wont start up
Yes there is a problem with your video card.I also faced this problem.i tried to flash bios and updated the video drivers but nothing worked. There is no other way to resolve this issue.Only way is to replace the video card.But the video card is integreted on the motherboard itself.So you will have to replace the motherboard which is cheaper than repairing your faulty motherboard.So i suggest you to replace your motherboard.
thanks
Feb 17, 2009 | Dell Inspiron 531s Desktop Computer
Monitor is black
1. could be dim if laptop or lcd (backlight out) replace
2. video card may be out in cpu if desktop or try turning desktop on immediatly & contiously press f 8 until safe mode etc comes up choose enable vga mode see if that works if not video card maybe bad replace with appropriate card need more info to help you more.
Oct 24, 2008 | Computers & Internet
Open Questions:
as some sites suggest about cheat for igi game i tried it and make changes under Project IGI- I'm going in Cheats----hi friends in this game it is difficult to get the blood/medipack to get this use the folowing instruction. 1)first go to the igi installed folder then go to weapon folder u will find some folders like Ak47,binoculars,colt anaconda,medipack etc. 2)then go to Ak47 folder you will find a folder like weapon the open in hex editor u will find a string like weapon_id_Ak47 by using hexeditor edit the string to weapon_id _medipack. then similarly go to medipack folder u will get a folder like weapon then open in hex editor edit weapon_id_medipack to weapon_id Ak47 the save it. 3)when u will kill a soldier u will get a medipack. for hex editing i installed HEXED30f.zip software and changes in hex file as i described above but due to mistake my igi game not start well aND , SHOW A error like igi stopped and shows problem detail Problem Event Name: APPCRASH Application Name: IGI.exe Application Version: 0.0.0.0 Application Timestamp: 3a1d74c6 Fault Module Name: StackHash_169c Fault Module Version: 0.0.0.0 Fault Module Timestamp: 00000000 Exception Code: c0000005 Exception Offset: 00000000 OS Version: 6.1.7600.2.0.0.256.1 Locale ID: 1033 Additional Information 1: 169c Additional Information 2: 169c69b50cca39ebafad90cf9acfe712 Additional Information 3: 166e Additional Information 4: 166ed9faa1184e606930c56f1ef84d85 please send solution ... or reply
Dec 31, 2010 | Intel Celeron -D 2.26Ghz Computer System...
Intel Celeron -D 2.26Ghz Computer System PC Desktop Logo
228 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
