Question about Ryobi 18v One+ Circular Saw P501 18 Volt V 1 Plus
Battery failure-18 volt under factory gurantee
  • David Ford
    David Ford May 11, 2010
    OK if under warranty take it back and get a new one, I dont know how I can help with your question other than that
  • 134 Answers
Return it to Ryobi
Posted on Feb 12, 2009
I need to know what the output needs to be on the charger of an 18 volt jobmate cordless drill.
During the initial state of the charge, the charger operates in a fixed-current mode. This means that the current will be held at a constant rate until the battery is charged to a bit over 18 Volts. During this phase, the output of the charger will not be 18 Volts. This is done for safety and battery preservation; forcing 18 Volts on a battery discharged down to 15 Volts or less could cause the battery to overheat. If no battery is connected, the charge controller may hold the output low until a battery insertion is detected.
The exact behavior of the charger depends on the chemistry for which it is designed, whether Nickel-Cadmium, Nickel-Metal Hydride, or Lithium ion. If the output of a known-good battery is 18 Volts after charging, and it has normal capacity, the charger is working properly.
However, a bad cell in the battery changes things. If you run a Ni-Cd battery down too far, the weakest cell in the battery may begin to reverse charge from the current coming from the other cells. This usually causes an internal short circuit, and the cell will be stuck at 0 Volts. A battery pack with one shorted cell will read 16.7 -16.9 Volts when fully charged, and the drill will not have the peak power it should. The charger will give you a battery fault indication if it is equipped to do so.
Jul 08, 2017 | Drills
Ryobi problems
Check to make sure you don't have a staple stuck under the hammer. If the spring feed is working, then something is keeping the staples from sliding under the hammer. Can you hear the hammer hitting? Does it leave an impression on the wood?
Jul 29, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
MOTORCYCLE BATTERY GOES FLAT
Have you checked the charging output from your alternator? With the engine running, you should get about 14 volts across the battery terminals. If the battery is good, after a charge you should get a reading of around 12.7 to 13.2 volts. If the voltage is less, especially with the motor running, you may have a charging problem due to rectifier bank failure or battery breakdown due to "overcharging" if the reading is above 14 volts. [This is also a rec' fault]. My assumptions are that this batt' goes flat when run on the bike after a full charge. I hope this helps a bit.
Nov 30, 2013 | Suzuki Motorcycles
Can I use a dewalt 18 volt dc9098 battery on the dc385 Saw?
If you have the handle disigned for the lithium battery becareful using the 9096 battery as it moves in the handle a lot and can hit the terminal on the switch wrong and bend it or break it. Also it will get a lot of vibration when running and because it doen't have the support that it needs for a 9096 it wiill likely brak a contact on the switch eventually. the factory does say they work in any tool however.
Feb 14, 2011 | Dewalt 18v Battery Reciprocating Saw Dc385...
Between us my son and I have 10 18 volt batteries for our Makita power tools which we use in our Carpentry work of these 10 batteries 6 have failed. I have to say the reliabillity of the Ni-cad equipment...
Join the battery collectors club. I have 25 batteries, 12 guns, I quit buying the batteries, I found it cheaper to buy the gun with new batteries and charger once a year. Cause they don't even last that long. I have tried different brands too all the same. Got batteries?? Sure do.
May 15, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Just received recondition Ryobi 18 volt chain saw. Motor runs backwards.
electrical motor was wired in reverse, If you you attempt repair assuming product was purchased from store ,your sure not to get a fund or in-store credit.
Dec 07, 2009 | Ryobi Factory Reconditioned 10-Inch 18...
WHERE CAN I GET A REPLACEMENT CHARGER FOR A GREATNECK DRILL?
I have to be the bearer of bad news. These are mass produced to give you the lowest price possible. They are made in Keorea/Taiwan and unfortunately do not make replacement parts. These are sold to any company that pays enough to put their name on it. Shop force makes the same drill and several other brands. So when something goes bad you have to replace the entire drill (only comes in the combo pk). You can't buy seperate pieces. Try shop force or Master craft. They're similar to what you have. Found one on Ebay. IF you keep looking you can probably find a seller with just the charger. Good luck
http://cgi.ebay.com/18V-Cordless-Drill-with-charger-battery-NEW_W0QQitemZ260460074195QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item3ca4a154d3&_trksid=p3286.c0.m14
Jul 31, 2009 | Great Neck 80125/79681 Cordless 18V Drill
18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
Mar 01, 2009 | Ryobi 18v One+ Circular Saw P501 18 Volt V...
Voltage adapter
NO, it is very under rated and powered. You need an 18 volt and not a 12 VOLT. They should not be that hard to find in an electronics store. Also the amp rating is also important. Make sure you are matching both amps and volts AC or DC to the the label on the woofer or you could end up blowing the out.
Sep 24, 2008 | Altec Lansing AVS 300 Computer Speakers
Ryobi 18v One+ Circular Saw P501 18 Volt V 1 Plus Logo
193 people viewed this question
Top Ryobi Saws Experts
JOHN LAPIER
Jim Thurston
Are you a Ryobi Saw Expert? Answer questions, earn points and help others
