My washing machine does not start WA7584C1 top loader
  • 1462 Answers
SOURCE: LG WFT1022TP top loader washing machine
the system which controls water level is an air chamber with a small diameter pipe which goes to a pressure stat. when the correct level is reached, the pressure in the air chamber switches the pressure stat and cuts the water off. the things to look for are: gunge in the air chamber split in the pipe. faulty pressure stat to test, get a similiar length of small diameter pipe and connect it to the pressure stat instead. with the machine filling, blow gently into the pipe and see if the water intake cuts off
Posted on Apr 02, 2007
SOURCE: moffat washing machine older really older cant find model number
clothes need be more drye ofter end work
Posted on Feb 25, 2008
jsrock516
  • 5911 Answers
SOURCE: how to take apart a Whirlpool top loader washing machine
If you have not taken the exterior washer casing off, the first steps will explain how to accomplish this:
1. Unplug washing machine.
2. Remove console. This can be accomplished in one of two ways depending on which type of console you have.
a. If the console has removable end caps, the caps lift off by prying on the top from the back of the washer. The cap will pull off towards you as you are facing the unit from the front of the washer. There will be a screw under each end cap that you will need to remove.
b. If the console does not have removable end caps, you will need to slide a putty knife under the front corner of each side and push in while lifting up. There is a retaining clip under each side that has to be released.
3. Once the console has been released it will lift up and fold back over the back of the washer in its resting position. Use care not to stress the small plastic hinges that hold it on. They can break easily.
4. Under the console will be two large brass colored clips. Take a large flat blade screwdriver and place it in the groove of the clip on the washer top. With the screwdriver firmly in the groove, push away from you towards the back of the washer. This will release the clips.
5. Disconnect the lid switch connector plug. This is the white colored plug on the washer top under the console.
6. Remove the washer casing. Open the lid of the washer. Using one hand, grip under the front rim of the washer opening. Do not grab the wash tub, just the casing. Tilt the washer case from the back first towards you, slide forward slightly, and then lift up. The entire case comes off exposing the wash tub and components.
Once the casing is removed, you should have full access the the washer interior components. Since you have mentioned you taken the "internal post" off (I'm assuming this is your agitator), I will spare the steps in involved in accomplishing that task.
Next, follow these series of steps:
1. Remove the tub ring. This is the cylindrical donut shaped ring attached to the top of the wash tub. This ring needs to be removed in order to accommodate the removal of the inner spin basket. The tub ring comes off by placing a screwdriver under the series of the tabs that hold it in place and GENTLY prying them up until they release. Be careful not to break off the tabs, or crack the wash tub.
2. Remove the spanner nut that is under the agitator. This holds the inner spin basket to center post.
3. With the spanner nut removed, the spin basket should lift straight up and out. Sometimes the basket will stick to the center-post and may required some "coaxing" to get it free. This can be accomplished by grabbing the rim of the spin basket and prying up on one side, then the other, in an attempt to rock the basket side to side.
Searspartsdirect.com has excellent exploded view diagrams that you can use as a reference. Simply type in your model number and look under the "Agitator, Basket and Tub" heading. The tub ring gasket, I mention below, is listed as item 6. Appliancepartspros.com also has these same drawings.
Some things to consider:
If you remove the tub ring, it is recommended that you replace the seal on the ring before reassembly. Once the tub seal is broken, it can leak if the seal is not replaced.
When reinstalling the exterior cabinet, follow these steps:
1. Re-install washer case. With the lid of the washer open, place grasp case under front rim and place it on the washer frame. While looking down through the washer lid opening, make sure the front lip of the case is placed UNDER the washer frame and rocked back onto the frame to ensure that the small cleats on the frame fit into the slotted grooves on the washer case base. If you do not get the case seated correctly it will rattle and vibrate while the washer is in operation.
2. Make the back of the washer fits into the washer casing on each side and reinsert the brass clips. Place the clip into the slot on the back of the washer first, and then forcefully push it into the opening on top of the washer. It will snap back into to place.
3. REINSTALL LID SWITCH CONNECTOR. It is easy to forget. If you do not reconnect it, the washer will not work correctly.
4. Reinstall console.
If you have questions, or need further assistance, please let me know. I hope this helps you.
PS What is the reason for removing the spin basket? Anything else I can help you with?
Posted on Jan 17, 2009
SOURCE: Clean LG WF-T652a Top Loader Washing Machine
I have this problem too and I solved it easily !!!!
I hypothesised that something was blocked by dried up lint/silt. So I filled the machine with very hot water and also poured hot water down the lint filter outlets. I left it for 5 minutes and then started a wash cycle - and the water now comes out of the lint filter ducts. ! :-)
Posted on Jun 19, 2010
SOURCE: simpson esprit 450 washing machine top loader
your drive belt is brobably loose or broken
Posted on Aug 10, 2010
My samsung automatic washing machine wa7584c1 is giving me a 1E error why
You can sometimes solve issue by unplugging unit from wall for ten seconds to reset sensors.
CERACOAT-NANOTECH.com
May 14, 2015 | Samsung Washing Machines
WHY AREMY POWER BUTTON NOT COME ON WHEN PRESS
www.samsung.com/in/consumer/.../washing-machin...
www.samsung.com/in/info/contactus.html
Sep 08, 2014 | Washing Machines
My washing machine wont wash it switches on and stary button goes on but wouldnt wash
This isnt something you can repair yourself ordinarily. An appliance repair man can take care of this.
Jan 16, 2013 | Clothing Accessories
Samsung washing machine wa7584c1 power is on, programming seems fine, push start and nothing happens,except water flows ok, no washing no spinning no draining
hello check the belt first to see if it's come off or snaped if ok then the fault could be the brushes on the motor 2 plastic blocks sit either side of the motor they wear down can cause the motor to stop working they just slide out hope it helps
regards
shaun
Mar 13, 2011 | Washing Machines
What's the capacity of a Simpson 175 HD washing machine (approx 22 years old). What new top load should i buy? dials or push button?
about 6to7 kg.to b honest the machines i find that last the longest r kleenmaid top loaders,maytag top loader,whirpool top loaders,and miele front loaders, i would try to advoid electronic units.nothing will b as robust as your 175.
Apr 06, 2010 | Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
Top loader washing machine - won't work unless I slam down the top door. Any suggestions? Thanks
I think it is in the lid switch. If the lid switch is malfunctioning on a maytag top loader it will not start washing. Probably by slamming the lid you are making the connection you need for the time being. It is located at the back underneath the lid in the middle. Follow the link and you will see and diagram and parts associated with your washer. http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=A4910&productCategoryId=0153000&brandId=3048&modelName=MAYTAG-LAUNDRY&diagramPageId=00002&componentDescription=TOP COVER, CONSOLE & LID SWITCH
May 12, 2009 | Maytag Washing Machines
How does a top loader work?
You lift the lid and load your washing into it. They you select the wash cycle, select the type of fabrics you're washing and the temperature and then start the wash cycle.
Then's all kinds of variation, but generally, there's a timer and a thermostat that control a lot of the cycle behaviour like washing times and water temperatur, if their outside the thermostat calibration, the washing machine may not continue to the next cycle until the calibrated temperature registers on the thermostat.
Was there anything else you wanted to know about top loaders?
May 10, 2009 | Samsung Washing Machines
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
