Question about Dryers
The thermo fuse keeps going out on my kitchen aid dryer
  • SCooter13 Jan 24, 2009
    I've replaced the 325fuse 3 times, it works fine until I put i all back together, then I dont get any heat?
    Genius:
  • 1,122 Answers
You need to check the wall vent and dryer vent it sounds like 1 or both might be clogged,if blowing cold air know the heater box fuse has blown again-mike
Posted on Jan 25, 2009
Dryer does not start. I can hear the hummof it receiving power and have changed the motor and door switch.
Hi, I would check the white thermo fuse to see if it's blown. If the thermo fuse it bad it will keep the motor from running. Without a model number it's hard to give much detail, but here is a video that should be similar to your whirlpool dryer that shows you how to replace a thermo fuse. Most all Whirlpool Dryer thermo fuses are white in color. They show the most common one in the video, but your could be a little different shape too.
Aug 07, 2011 | Whirlpool Dryers
I need my kitchen aid oven to unlock
NEVER use the self cleaning feature - again!!
Sounds like my problem two days ago. I have a Kitchen Aid free standing gas oven/range model
KGRI801PWH00. I read online that the thermo-fuse might've blown. I found the thermo-fuse after removing the rear panel. It was at the top/center. Mine is T-O-D (brand) 60F24; Westinghouse #8300802. I ordered mine from appliancepartspros.com for only $34.75; arrived in 36 hrs with regular shipping!! Easy to fix, sure beats several hundred $$ to repairman.
Don't bother to call Kitchen Aid - they'll just blow you off just like the hundreds of complaints said that I found online.
Jan 27, 2011 | Whirlpool GS460 Gas Kitchen Range
We have a kitchen aid KGSA906PSS00 gas range. for the first time today the wife decided to run the self clean function. At some point through the self clean the oven shut off and the control panel died....
Jan 27, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Door locked after self cleaning&panel went blank
NEVER use the self cleaning feature, again!!
Jan 27, 2011 | KitchenAid KGRS807SSS Gas Kitchen Range
It is obvious that there is a major design problem with this model in that numerous enquiries under Kitchen Aid's "popular solutions" deal with a multitude of self-cleaning issues. We have had to...
NEVER use the self cleaning mode.
Jan 25, 2011 | KitchenAid KESA907PSS Electric Kitchen...
The oven door cannot open. The self cleaning cycle was not completed because the display window went blank and as a result the oven door remained locked. This occured during the Christmas season and...
Jan 24, 2011 | KitchenAid KGSA906PSS Gas Kitchen Range
Does thermal fuse burn out only because of temp.?
Possibly or the thermo fuse just went bad normally if the thermo-fuse blows its a venting problem warm moist air back builds into the dryer which in turn blows the thermo-fuse to save the dryer from further damage and also keeps from starting a fire in your home a big saftey feature that has saved many homes.
Jan 04, 2011 | Maytag HYE3657A Electric Dryer
My kitchen aid gas dryer is not heating up.
If it is tumbling. This troubleshooting video will help. Could be the thermal fuse,ignitor,or gas coils. The free video will walk you thru testing.
www.appliancehelponline.com/servicemanual.html
Feb 26, 2010 | KitchenAid Dryers
Trying to locate heating element on kitchen aid dryer
Do you have the part number, is so Put in (Find kitchen aid dryer Part# 111111* ) Or( Find kitchen aid dryer heating element* ). If this is a old dryer some parts are not made anymore. Any Dryer over 7 years old is no longer energy efficient. Hope This Helps.
Zipher
Oct 03, 2009 | KitchenAid Dryers
Kitchen aid superba electric convection range
ouch thats gotta hurt!! how about the clock os that back on atleast??? sounds like a bad thermo stat on the back wall of the unit maybe a quater sized thermo 1 wire in one out, should have ( BUT DOUBt it does) have continuity through it. ifthe clock still doenst work ther is also a small inline thermal fuse connected right to the wire warness connecting to the main control
Mar 18, 2008 | KitchenAid KESC307 Electric Kitchen Range
Dryers Logo
60 people viewed this question
Top Dryers Experts
