Question about Tascam 2488 Portastudio Multitrack Recorder System
I need a ps-p1 ac adapter for an old portastudio, is there an alternative that will work as I,m haveing no luck finding one.;
2 Suggested Answers
  • 189 Answers
SOURCE: Tascam Portastudio 424 Manual needed
Try this page: http://www.tascam.com/products/424mkiii;9,17,141,19.html
Regards,
BD
Posted on Apr 25, 2008
P1 code on Sylvania 12,000BTU portable AC unitl will not clear
The only thing I have been able to find as far as a P1 error code, is the water tray needs to be emptied. If thats emptied then it would be a issue with the float switch that senses the water.
Best I can find
Aug 21, 2013 | Sylvania Heating & Cooling
Kinyo ps-56 ac adapter
My kinyo ps-56 works in 7,5 v.
Hope helps
Apr 04, 2013 | Kinyo In Box 2 Ps-56 Multimedia Speaker...
Something went pop and them the power went out and won't power back on?
Most probably a capacitor exploded either in the AC adapter or on the laptop's motherboard. In order to find out where the damage exactly happened, you can either test your AC adapter with another similar laptop, or test a new AC adapter with your laptop. Alternatively, you can test the output voltage from your AC adapter using a voltmeter.
If the AC adapter turns out to be working properly, then the damage happened on the motherboard. You will need to disassemble the laptop to get access to the motherboard & inspect it. The exploded capacitor could be replaced with a new one to fix the problem.
Jan 12, 2011 | HP Compaq nx6110 PC Laptop
My sister has a pro tron 758slp has call the 800 number with out any results keeps ringing busy. Her problem is that she needs a new car plug in.She has a damaged one. Can you help me.
I also had no luck finding an auto adapter for that brand but an alternative would be a 12VDC to 115VAC inverter and it may even be price competitive with the other:
DC to AC inverter
Her AC-powered home adapter would be then just plugged into this device.
Jan 24, 2009 | Protron PD-758LP
Mag Innovision LT582s 15 in flat monitor
Well, Most montiors have a standered adapter Which you can get from almost any good online store, maby say what the socket looks like most are 3 pin sockets..
Sep 03, 2007 | Mag Innovision LT576s 15" Flat Panel LCD...
Faulty AC adapter
Same called Sears Placed and order Paid 136.95 plus shipping Tax total $168. 12 weeks no part with no due date
Apr 21, 2007 | Protron PLTV-32 Television
Need AC/DC adapter for monitor!
Hi inkedpandora, http://icm.computercci.com/pgi-productspec?PSO080 This one should work for you it's the same voltage and amperage as your unit. 19VDC 3.16A Any standard power cable from an old printer or computer will work with one of those PS's. The only thing you need to check before you buy is the polarity of the barrel connector. I looked on the net but could not find out that info so look at the jack where the power plugs into the monitor. You might see a little diagram showing a + and - signs. If the line coming off the + sign goes to the semi-circle than the barrel is positive and if the - goes to the SC the barrel is negative. Ask them before you buy which way that one is. As long as they are the same you will be able to use that PS. Good Luck, Dude
Nov 22, 2006 | Liquid Video A170E101 Monitor
Tascam 2488 Portastudio Multitrack Recorder System Logo
82 people viewed this question
Top Tascam Audio Players & Recorders Experts
Sam Palermo
Sam Palermo
Michial Gueffroy
John
John
Are you a Tascam Audio Player and Recorder Expert? Answer questions, earn points and help others
