Question about Exercise & Fitness
What does this foaming agent do? - Exercise & Fitness
    New Friend:
  • 50 Answers
It covers the contents of your stomach with foam so that they can't enter the esophagus, preventing reflux.
Posted on Jan 16, 2013
How to remove foam insulator that comes in a can from my wood floor
If you check your product name/main damaging agent in product and find a solvent to counteract the product, it should stop damaging your floor. Hopefully though, the solvent doesn't ruin your wooden floors as well.
Mar 08, 2013 | Health & Beauty
My sovereign 45 glasswasher is foaming &leaving foam on glasses
Okay, this is under "air conditioners". Try adding a defoaming agent or less soap.
Jun 06, 2012 | Heating & Cooling
What kind of motor oil does a 2500 hpw pressure washer use?
Any non-detergent oil, it gets pounded so hard and fast that it turns into foam, soap suds, the cleaning agents in motor oil. Should be the same oil used in a compressor. Straight 30 w, I am guessing. Hope this helps.
Aug 14, 2010 | Garden
Bonding agent for external car trim damage
Typically I use silicon adhesive takes some time to cure but strong waterproof.
Feb 12, 2010 | Land Rover Discovery Cars & Trucks
Soap suds comming out from under the door of the dishwasher.
you are using the wrong soap. you must use dishwashing detergent only, which has an anti foaming agent in it.
Dec 01, 2009 | GE Dishwashers
It shut off ,the water got real foamy and it shut off . will it reset. Do I need to reset it.
it should reset, try not using a sol that has a foaming agent in it.
Jul 16, 2009 | Vacuums
Driving with overfilled oil, rattling noise.
It likely has little foam in it...most oils have an anti-foaming agent as part of their formula. just drain the pan and re-fill till it's at the proper level. Use a very clean pan and don't drop any road dirt from undercariage in there. Save and use extra for between service top off.
Mar 22, 2009 | 1993 Saturn SC1
I have a pondless waterfall and have a problem with excessive foaming.
Here is some info I looked up. Hope this is useful
Don't forget to rate the answer
Kurt
Definition:
Whenever proteins build up in pond water it causes the water to create foam, especially around the area at the bottom of the waterfall. One of the most frequent causes of protein build up is when the fish spawn so we see more foam in ponds during spring when spawning most often takes place. It's not dangerous but can be unsightly. Use fish-safe de-foaming agents to clear water.
What to Use to Clear Up Foam:
go_button.gif Doc's DeFoamer
Mar 18, 2009 | Gard Aquascape Black Waterfall Foam...
Very sticky handles on Maclaren Techno XT buggy. Not grandchildren as they are only small. Any solutions please?
ok as they are sticky it means you have eft them out side or in the rain
simply just put cling film over the top of the handles it realy works !! :)
Nov 08, 2008 | Maclaren Techno XT Wisteria Umbrella...
Soap foam left after dishes are washes. can't dry properly. and always has soapy water left in it and on the washed plates.
Try adding some liquid fabric softener to your dishwasher. This will reduce the foaming. Also make sure there is rinse agent in the proper dispenser, this will reduce the soap sticking to the dishes. Finally, reduce the amount of dishwasher powder or liquid you put in for each wash. If water remains in the bottom of the dishwasher, check if there is a filter or drain hose clogged. Is the dishwasher drain hose connected an undersink garbage disposer? If yes, make sure it is run periodically so it does not clog up.
Aug 09, 2008 | Dishwashers
Exercise & Fitness Logo
97 people viewed this question
Top Exercise & Fitness Experts
Howard
Howard
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
