My lg flat screen won't stop displaying the picture wizard it just keep popping up on the left side of the screen
  • 458 Answers
SOURCE: I have an LG flat screen no picture or sound
As your TV is three years old, I would suggest you contact your LG dealer to arrange an engineer to call to do a software upgrade on the it. The current software will be out of date & if you are connected via the HDMI connector then this can give audio/video problems.
Posted on Oct 28, 2009
roety
  • 585 Answers
SOURCE: I have an AOC 32
Hi my name is Roety,
I can help you with your issue ,
Sorry to say , but these LCD TV Screen do go bad.
There is a board thats part of the screen called the Tcon
You can check the ribbon cables to the tcon board or try to get AOC to warranty the TV under the 1 year warranty.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Posted on Dec 01, 2009
budmrtn
  • 11361 Answers
SOURCE: Picture is out on LG LCD TV
The problem can be blown up components in the back lights inverter board or in the 24VDC power supply section. You need to open up the back look to see if you can locate blown components. There should be 24vdc on one of the power supply output connectors pins.
Parts: http://www.shopjimmy.com/catalogsearch/result/index/?q=LG+42LC2D+&limit=200&stock=all
Posted on Jan 02, 2010
  • 629 Answers
SOURCE: The left side of the LG 42" plasma TV has no
try to check the aspect ratio and input source to make sure they are correct. for the aspect ratio, make sure it is set either at 16:9 ratio or try the zoom options. if it is set at zoom, you can move the screen left to right or up or down through the zoom settings. make sure you are also using the correct cable. hope this helps
Posted on Nov 25, 2010
vinceisaac
  • 2432 Answers
SOURCE: Hi, My LG37LG3000 Has no
hi this is how are you going to isolate or trouble shoot if where the main cause of voltage drop.unplug the unit then disconnect first the connector going to the inverter board as well as going to audio board. 24v which supply the inverter board and drive by 3.3v coming from processor and then 16v for audio. now after you disconnect all the connectors try to plug again the tv unit and turn on check the 24v line and 16v if no drop voltage. if you trace all the voltages present no drop possible your back light has a problem or inverter board has shorted part like transistor which can affect other voltage to drop.just make sure all the regulator for 24v and 16v you have been already check and good. good luck i hope this will help you thanks for consulting fixya.
Posted on Jul 09, 2011
LG vertical line
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
May 15, 2016 | LG 47LV5500 47 Class LED TV with SmartTV,...
LED screen comes on and goes black
LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW ...
? 5:29
https://www.youtube.com/watch?v=PWoz_-3OHIM
Jan 25, 2013 - Uploaded by Tampatec
Common LG LCD TV REPAIR - NO PICTURE OR BLACK SCREEN FIX ... I have a LG 42PM4700-UB plasma tv that justwent black. The red ... I had to keep turning on and off the TVseveral times for the screen to come back.
LCD & LED TV Repair - No Image & Blank Black Screen ...
? 5:56
https://www.youtube.com/watch?v=xUzCLgoSPGM
Sep 15, 2014 - Uploaded by ShopJimmy.com
LED & LCD TV How to Diagnose Symptom of No Image on theScreen CLICK ... Tv was working fine when left to go to store and came back to blank picture and ... my samsung tv it turns on but its completely black and no sound at all ... LG LCD TV REPAIR - NO PICTURE SCREEN FIX REVIEW - Duration: ...
LG LED TV has no picture (black screen) but still sound ...
Dec 09, 2015 | LG 47LS4500
How can I change the screen to wide when it doesn't appears in the Picture menu?
first pull off powersuply and out it back in,then set up wizard will start.
after you set your your connection comes picture wizard.there you choose in the right below corner sreen you want.after that you ger page to see from all your settings and your done.
Jul 26, 2012 | LG 42LC2D 42 in. LCD HDTV
Picture won't refresh on left 1/4 edge of screen
It may and likely is a defect inside the display panel itself.
Jun 16, 2012 | Sony BRAVIA KDL-52S4100 52 in. HDTV LCD
Powers on but screen won't produce a picture
The Problem is in either power supply or the Y-Sustain board.
The Y-Sustain is a relatively large board out of which go connections to the side of the display; it's therefore closer to either the left or the right side of the display, has at least one rather large heat sink on it and fat power cables connecting it to the main power supply.
Often there are fuses on that board - one or more. Check those.
if they are blown you can try to replace them, but expect them to blow again - usually the whole board needs to be replaced.
Hope this will help in solving the problem....
May 16, 2011 | Televison & Video
42" television that won't display
You have the picture mode set ion 4:3 if its not the TV it will be any cable or satellite you have connected, you need 12:9
May 15, 2011 | LG Televison & Video
I opened my X018 Camera package and there wasn't any software or instruction book included. Please help. drypete@aol.com
-Using the USB cable that came with the camera, connect the wider end of the cable to your computer and the smaller end to your camera, on the left side.
-Power on the camera. After a few seconds a new window will appear on the computer screen. The new window allows you to use the Scanner & Camera wizard to move your pictures to the computer. Select the wizard and follow it's steps to approve the new location for your pictures and then proceed.
If you don't have the USB cable, remove the memory card from the bottom of the camera and find the part of your computer labeled Media Cards. Insert your memory card into the slot labeled SD. After a few seconds a new window will appear on the computer screen. The new window allows you to use the Scanner & Camera wizard to move your pictures to the computer. Select the wizard and follow it's steps to approve the new location for your pictures and then proceed.
May 09, 2011 | Vivitar Cameras
Pop sound then no picture, just sound
I assume this is a plasma TV? You will have a fuse blown on either the Y or Z sutain board, there is also a possibility one of the driver IC's has blown on the buffer board, this will shut down the screen & leave the audio working normally. You can check these boards which sit on the left & right hand sides of the screen.
Sep 23, 2009 | Televison & Video
Televison & Video Logo
261 people viewed this question
Top Televison & Video Experts
Electro Med Services...
