Question about Olevia LT32HVM 32 in. LCD Television
Blue spot on screen plasma tv
There is a dark blue spot on the screen in the same spot all the time yet it goes on and off and as the tv warms up it gets worse.
Dark spots appear on edges of tv. Also across entire lower 2/3 at times. 45inch LG. No cable antenna only but worked great until about a week ago. Thank you for your help.
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
May 03, 2017 | Televison & Video
Picture adjustment guide form a 32" LCD TV Dark Spots, shadows, etc. Thank You!
If you wish to get some details; check the site linked here. Pull up older posts.
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Jul 24, 2016 | Toshiba 32AV500U 32 in. LCD HDTV
My vizio 32in. tv. year 2007 has a dark faint cloudy spot. whats the cause and how to fix
Jun 25, 2016 | Vizio Televison & Video
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Blue spots on vizio plasma tv
Going to be hard to determine which board is bad since it does it when it gets warm---could be main signal board or?
Mar 31, 2012 | Sony Televison & Video
I have Lg 50pc3d-ud and it has very dark spots on the tv that moves around. The screen is also very dark no matter the settings. The dark spots aren't always there, they go away sometimes but if...
This problems ur tv are having only can be two causes 1) The Y-Sustance main tuner logic board or 2)The tv Plasma screen panel itself it is slowly leaking radiaton and dying,if it is the tv plasma screen panel itself it is dying than the tv not worth repairing because by replacing the plasma screen panel itself will cost the same as a new tv itself.The Y-Sustance board-that the tuner main logic board that take in the tv incomming broadcasting signal cable.Tries websites like Shopjimmy.com,Ebay.com to buy a whole new refurbish Y-Sustance main tuner logic board for replacement.This tv problems are 50/50 between the Y-Sustance main tuner logic board or the very exspensive plasma screen panel itself.
Oct 27, 2011 | LG 50PC3D 50 in. Plasma Television
Samsung HP-R4272 42" plasma. 3" blue/ green ribbon
This is caused by the LCD panel shifting in it's mounts. You will need to disassemble the frame holding the LCD screen in place and re-center it.
The lines will take some time to go away as the set warms up, but be patient, they usually disappear over time.
Oct 26, 2010 | Samsung HP-R4272 42 in. Plasma HDTV
My plasma tv has blue or black spots (scattered on tv screen) when it is on about 30 mins to 1 hour then as it on for long hours it becomes black spots and covered whole screen
I am facing the same problem with my LG 32 inch plasma TV. There is also a big 2inchX4inch oval black spot at the top centre of the screen. Please suggest any remedy and also the cause. mbkhurshid@gmail.com
May 17, 2010 | Televison & Video
My 2 yrs old granddaughter sprayed freeze on my tv screen, now has dark grey spots on it. What to do.
if its an lcd be carefull plastic front layer on them it may have marked the plastic try warm diluted soapy water on a cloth but only damp not soaking or were water is running down the screen.
Feb 11, 2010 | Panasonic Viera TH-50PX80U Plasma TV
Blue static on screen
I have the same tv with the same blue spots. Called Samsung and they directed me to Samsung Canada. Samsung Canada referred me back to the US and the US wants me to make a copy of my purchase order and send it to them. What a pain!
Oct 10, 2008 | Samsung HP-S4253 Television
Olevia LT32HVM 32 in. LCD Television Logo
128 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
