Question about Panasonic CT-34WX54 34" TV
Panasonic CT34wx54 TV remote SENSOR not working.
The remote sensor in our 3 yr old TV has stopped functioning. It is not the remote control itself, but the sensor in the television. What part would need to be replaced and how easy is this to do myself?
Thanks.
  • Tyler Hammond Jan 30, 2009
    Same problem here. Just looking for a part numbers.
  • Anonymous Mar 12, 2009
    I'm on my third fix with this. Twice under warranty. The part you need is the following:
    #PNA4701M05
    Repairing it is another issue. I have a TV Repairer willing to guide me over the phone.
2 Suggested Answers
ShadeTek
  • 79 Answers
SOURCE: Can't change our Panasonic TV channel to watch DVD input
Buy a 21 way scart.This will have an 'AV' enable connection built in. After fitting, turn on the TV, then turn on the DVD player. It will automatically enable the DVD through the scart socket.
Posted on Nov 10, 2008
Im trying to program a Panasonic universal remote to clear tunes tv
Search Results
    Need codes for ct-300 clear tunes universal remote - Fixya
    www.fixya.com/.../t17341079-need_codes_ct_300_clear_tunes_universa...
    Mar 26, 2013 - need codes for ct-300 clear tunes universal remote Need codes - Symphonic ST419E TV ... Universal remote code for a panasonic ct-27g14a.
    I have a clear tunes tv and trying to program my RCA universal
    www.fixya.com/support/t25649135-clear_tunes_tv_trying_program_rca
    Apr 16, 2015 - ... a clear tunes tv and trying to program my RCA universal remote to it ... "I need to program an old Panasonic TV with a RCA universal remote ...
    I need the codes to a clear tunes remote for a rca - Fixya
    www.fixya.com/support/t3026751-need_codes_clear_tunes_remote_rca
    Sep 26, 2009 - I need the codes to a clear tunes remote for a rca tv. ... "I need toprogram an old Panasonic TV with a RCA universal remote model RCR311St ...
    Radio Shack panasonic remote control codes clear tunes tv ...
    www.fixya.com > ... > panasonic remote control codes clear tunes tv
    ...remote. the panasonic codefor my radioshack 3-in-one remote is 0250 I need a codefor a VCR Durabrand (DCV603) for the Sony universal remote control or a ...
    Clear tech tv 4 digit code - TV - Other Consumer Electronics
Jan 25, 2016 | Panasonic Televison & Video
Remote sensor on Sharp LC37D44U not working
I have same issue. I see there is a replacement IR board that is covered (i think) for me under 3 yr parts warranty. If you are out of warranty, i found it online for 19$ 8)
http://www.discount-merchant.com/SHARP-NE264WJ-IR-Remote-Control-Sensor-Board-p/1157614.htm
Apr 08, 2010 | Sharp Aquos LC37D44U 37 in. LCD HDTV
My tv won't turn on with the remote. The remote works fine
You can try www.encompassparts.com The remote sensor is located on the main board up close to the buttons. It is a 3 legged part that is exposed to a small window in the front cabinet. Thanks for using fixya.
Feb 23, 2010 | Panasonic Televison & Video
It turns itself off automatically.
There can be several causes for this, few of which you can do anything about. However, a few things to try:
1) Replace the batteries on your remote control.
2) Try resetting the logic functions on your tv by unplugging it for a minute, then plugging it back in.
3) Try covering up the infra-red receptor on the front of your TV to see if you're getting unwanted signals from the receptor. taping a piece of foil over that area is perfect. If it doesn't stop after doing these two things you'll probably need to take it to a shop.
4) If this does stop it, then look for unexpected signal sources. Have you added a remote control extender? Added a new device to your audio-video system? Changed to a new remote?
I hope this helps. Joe
Jan 26, 2010 | Panasonic PT-51HX41 51" Rear Projection...
Cannot get channels with remote stuck on AV2/3/4/5/6
The TV button on the remote is to select TV mode for the controller. STB, VCR & DVD do the same for their respective devices.
The A/V should select the external inputs by itself. If not try each of the Panasonic codes in turn:
0011, 0021, 0027,0029,0039,0072, 0102
Enter the codes as follows:
Press and hold TV for 3 seconds until the TV key flashes and then stays on.
Enter one of the codes (above)
TV key should flash twice. (if not go back to the beginning)
Try pressing the buttons on the controller. If all the functions do not work, try the next code.
Aug 03, 2009 | Rio Go Video DDV9475 Dual Deck VCR
Not receiving commands from the remote. (Panasonic Panasonic CT-34WX54 HDTV)
Your using a universal remote from what U am understanding, Two solutions for ya
1)diffrent remote all togeather from radioshack
or
2) the Tv's IR is not working
Apr 22, 2009 | Panasonic CT-27SL14 27" TV
Panasonic 42 inch HD Plasma TV (2 years old) remote sensor
take your tv and remote to a technician to check on your emitting diode and a photo senser, both are working but not very sensitive. the components are not gone but about to go. if you remove a senser from tv it can not receive, so that senser is sensing some thing, also check an amplifier just after a senser plse do that.
Nov 16, 2008 | Panasonic TH-42XVS30U 42 in. Plasma HDTV
Nov 10, 2008 | Panasonic CT-32SX31 32" TV
Panasonic CT-34WX54 34" TV Logo
303 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
