I have ardo machine when I connect to the water supply and turn machine on and I select the program which I need it on get water the motor had no rotation and the program ended and the drainage pump working and draining the water with out washing may be it work one wash only the motor is good the drainage pump is good the control boards is good the selector switch is good where is the problem it may been
    ????????? ??????? Jan 16, 2013
    SORRY BUT THE DRAINING PUMP WORK PROPERLY AND GET THE WATER OUT MY PROBLEM IS IN THE MAIN MOTOR IT HAD NO ROTATION IT NOT WORKING I tested the motor its good but it dont take order from the control board to run and control board tested its ok the hose of drain keep up it not failed on the ground the motor get one order only the second working dont get the order is there sensors that can be check
  • 38 Answers
SOURCE: Hoover Aristocrat Front Load Washing Machine
i think you will find the carbon brushes r worn out they r mounted on the side of the motor held on by 2 5.5mm nuts or 2 screws 1 brush on each side of the motor switch off at the mains b4 you start work good luck
Posted on Aug 19, 2007
  • 1294 Answers
SOURCE: ariston margherita wont drain and selector knob keeps turning
Plug off the wall first. The spin normally does not work when the outlet filter is clogged; be prepared for a flood of water. If the filter is clean you should then check your pipe coming out from under the tub. Last check your outlet pump, could be blocked with something. Refit carefully, you might need a nice pair of pliers to get the grip clip on and off the pipes.
You can also drain water from the tub thru the rear hose in the wall. Keep bucket handy. The outlet pipe into the wall stands at a particular height, refit exactly to this height, about 3 feet from ground. Do not push the pipe too much down the stand pipe.
Posted on Nov 30, 2007
  • 734 Answers
SOURCE: No Drainage on my LG WD-8050F washing machine
hi friend,
If your washer won't drain, check these:
It spins, but doesn't pump
It doesn't spin or pump
It pumps, but the water returns
If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many
washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub
that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's
attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the
from the pump and pull the item out.
To remove the sock from the outer tub port, open the washer's main access panel and remove the
large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the port.
Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator,
top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might
be happier getting a qualified appliance repair technician to do the job.
If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be
turning, the internal impeller may be broken. If so, you need to replace the pump.
If your washer doesn't spin or pump water out but the motor is running, your washer probably
has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the
pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen
or stiff--replace it.
If the water that pumps out of the machine goes back into the machine after the spin cycle, your
washer may be siphoning the water from a laundry tub that has a slow drain, back into the
washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck
in the drain?) Also, check for these problems:
* If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess.
* If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Posted on Dec 12, 2008
  • 236 Answers
SOURCE: Washing machine is not completing it's wash cycle
either you have a blocked hose to the pump or the pump itself is either jammed or the impellor has come off the shaft. either way i think you will need to replace the pump. i presume you managed to get the water out? if so i would say the pump is favourite.
Posted on Mar 16, 2009
SOURCE: ARDO washing machine
i should set my machine for washing program manually or is it automatic?
Posted on Apr 04, 2010
Turned on electrolux washer while cold water was disconected. Now receive an E11 error. Have reconnected cold water machine will not reset
Make sure the cold tap is turned on properly - sometimes the handle moves, but the shaft does not turn - especially those blue plastic ones. E11 means no water supply. Turn the shaft on the tap with a small spanner if necessary - make sure water is flowing.May be blocked with limescale - or the filter in the tap bunged up. Or could be problem with cold fill valve on the machine I suppose - wire disconnected, or needs new valve. Can you hear the valve buzzing when you start the program and it should be filling? check water supply again. take hose off the machine, turn tap on and see if water flows, with pressure.
Sep 15, 2017 | Electrolux Washing Machines
Please use a multimeter and check the cycle outputs from the program controller units. After the inlet valve opens and then once the water level is reached the inlet closes , now the motor must start the agitation. acheck the motor directly connected to the supply , check the capacitor . If power is present after the inlet cycle. then the motor is faulty.
Jun 26, 2012 | GE Washing Machines
Hi there! i need a manaul to ardo flo126e washing machine. the problem is i cannot find it anywhere on internet or ardo site. plese help. Best Regards, Filip
I've just followed my own FixYa advice on obtaining various manuals and have found this for you ;-0)
(If!) this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C.
Jun 27, 2011 | Washing Machines
Water entering machine when no program selected?
The water inlet valve on the back where the water supply is connected to the washer may not be sealing good letting the water run.
Apr 07, 2011 | Washing Machines
I have a top loading Kenmore Washing Machine. I don´t have the excat model but looks like a KENMORE HEAVY DUTY SERIES 70 AUTOMATIC WASHER, MODEL # 110.92273100. The problem presents after finishing...
You may have 2 defective parts.
First,make sure the hot and cold water hoses are connected correctly and both turned on.
If the water fill problem is the same,the water temp switch is bad.
The not filling after the wash cycle could be a bad lid switch.
Set the machine for SPIN and turn it on.
If it does not spin,replace the lid switch.
Sep 20, 2010 | Kenmore 24042 Top Load Washer
Indesit WIXL143 stops part way through program
Technical Jargon error F02 Motor jammed / tacho detached: check motor & module connections
Basically the strong possibility of a faulty Motor
Mar 21, 2010 | Washing Machines
Power light and extra rinse rapidly flashing
Sounds like a cold water supply fault which could be the solinoid valve, the water turned off, a kinked or twisted cold supply pipe or a wiring fault. Check out the error code sequence here. You never said what make or model you have (the error codes are only for Hotpoint, Creda and Indesit machines)
Mar 20, 2010 | Washing Machines
Jul 06, 2008 | Washing Machines
Click on "washing machines" (below FIXYA)on this website, go to Ardo (if available) type in your model No & search. You will get a shortlist; click on your model,below the page u will get Manual/Guides. Click on the blue, you hav your manual on line.
And rate me pl.............. if helped
Jan 03, 2008 | Washing Machines
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
