Question about Tools & Hardware - Others
Can a bending machine bend wrought iron? - Tools & Hardware - Others
    President:
  • 2,976 Answers
It depends on the type of bending machine you are talking about, the thickness of the iron and how much of a bend do you want.
You can also heat the iron to very red hot and bend it without a problem.
Posted on Jan 16, 2013
    New Friend:
  • 152 Answers
Yes, you can find benders that will bend wrought iron. some are only meant to be used on steel, but wrought iron benders do exist
How do I mount a 32" Wrought iron pendulum wall clock?
studs r on 16" centers (usually).
hanger needs to be secure in a stud and sized for clock weight.
hanger arrangement depends on clock config
plan on removing clock from wall to replace batteries.
Sep 21, 2014 | Sterling & Noble 20 Wrought Iron Wall...
My wrought iron door has a tamper proof screw missing. Can I replace it with another type of screw like a flathead or phillips head?
You can replace it with any type screw head. I would recommend however using a screw with the proper shank size. That is to say, a srew that is the same diameter.
Oct 07, 2012 | Smedbo Door Knob in Wrought Iron
How should I maintain my Wrought Iron outdoor chair?
In order to maintain a wrought iron outdoor chair you should use paint to touch up the cracks and afterwards apply rust protection. Moreover, you should wash the chair with a mild soap and rinse once a week.
Sep 02, 2012 | Alpine Garden
What are the benefits of Wrought Iron outdoor chairs?
Wrought Iron outdoor chairs can be mounted on wheels, they are very sturdy and durable and they are available in a wide range of designs.
Is it possible to paint over my grandmothers old wrought iron bed frame? It is in great condition and the size is right, I would just rather something a little brighter.
You need to buy a special paint for metal with special additives that prevent rust. Make sure to also buy a primer that is compatible with the paint you have selected. I found you some great instructions that should help you out.
Wipe the wrought-iron bed frames with a rag that was dipped in mineral spirits. That will help you to remove all traces of oil and grease from the frames.
Scrape rusty areas with a putty knife or scraping tool. Remove all loose rust scale. Rub the surface with steel wool, too.
Apply an oil-based primer. The primer needs to be designed for use on metal surfaces such as wrought iron. Roll on the primer with a small roller. Spread the primer with a paintbrush. Cover the whole surface with one coat of primer.
Paint the bed frames with a finish paint that has a rust inhibitor within 24 hours of priming them. That will help the primer and paint bond.
Roll on the paint in the same way you applied the primer. Use a paintbrush to make smooth, sweeping strokes to distribute the paint. Switch to a paintbrush with synthetic bristles if you decide to use a water-based paint.
Read more:
How to Paint Wrought Iron Bed Frames ' eHow.com http://www.ehow.com/how_7794293_paint-wrought-iron-bed-frames.html#ixzz232Q8GYhr
Aug 16, 2012 | Furniture
Need a carafe replacement model #5813 for west bend coffe/expresso machine model #55108
If you need to find parts for your West Bend slow cooker, West Bend coffee maker, West Bend Blender, West Bend popcorn maker, West Bend breadmakers, West Bend rice cooker/steamer, West Bend griddles/skillets/grills, and West Bend toasters/ovens the best place to go is www.westbend.com.
Also checkout this tip as it will help you to find what you are looking for on the website.
West Bend Kitchen Appliances Parts and Manuals
heatman101
Jan 21, 2011 | West Bend 55108 Espresso/coffee Maker
I need a replacement lid for a West Bend #58030 urn. Where can I buy one?
heatman101
Jan 18, 2011 | West Bend 58030 Coffee Maker
Blown head gasket
yeah probably aluminum heads too. Finding a good used head is pretty hard. Some /most machine shops will mill the bottom of the head but ignore the top where the cams are. so the warped head now has a flat bottom that will likely bend some more and the cams are on a super high wear streak due to binding from the warpage. Make the machine shop bend the head back flat first and then touch up the bottom with the milling machine. Make them show you that the cam fits perfectly flat(no rocking) with the caps OFF and the lifters/rockers removed.
Then use a Corteco headgasket NOT Felpro.
You will love the result. and it will last. Keep in mind that cars with aluminum heads can't tolerate overheating like the old iron heads could.
Apr 09, 2010 | 1999 Ford Escort
WEST BEND BREAD PAN LEAKS THROUGH PADDLE SHAFT SEALS
Replacement parts for all West Bend Bread Machines (and other products) are available online at Focus Electrics, which now handles the West Bend line of products.
If you do not know what model of machine you have, the model number can be found in the middle of the sticker on the back of your machine. The number will be somewhere in the range of 41026 to 41200 and it may be followed by one or letters.
West Bend Replacement products at Focus Electrics
(In 2003, The West Bend Company was acquired by Focus Products Group, LLC, an investment and growth oriented holding company headquartered in Vernon Hills, IL, and renamed West Bend Housewares.)
Nov 09, 2008 | West Bend 41053 Bread & Dough Maker
Tools & Hardware - Others Logo
134 people viewed this question
Top Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
