Question about Maytag PYE2300AY Electric Dryer
I have a maytag model # pye2300ayw while in the middle of drying a load a clothes it just quit i turned it back on now the timer is the only thing clicking nothing else is happening
  • mcaminos86 Feb 22, 2009
    i have the same problem, it stopped in mid cycle and wont turn on. nothing works, i checked breaker, fine, i checked cables and they are fine
  • 979 Answers
Check your breaker, then the wiring in the back. It sounds like it could be your thermal overload switch is bad. Does the drum turn on even though it may not have heat? This will help me analyze it.
Posted on Jan 24, 2009
Maytag electric dryer (PYE2300AYW) does not stop on auto cycle.
Either the control board or the humidity sensor is bad.
Jan 11, 2010 | Dryers
Maytag electric dryer is drying inconsistently.
you may need to check the lint trap and clean it .. also try cleaning out the dryer vent... if this doesnt work , try changing the drine belt...
good luck
Oct 12, 2009 | Dryers
Maytag Dryer model number PYE2300AYW will not start.
check your fuses in the dryer their is only one fuse that could shut down the whole dryer like that. Open back panel and get a volt meter and check for continuity on the fuses. HOW? first un plug it then open back then you will see the heating element their are 2 fuses on the heating element take off wires and check those.Then if those are ok look down thier is another fuses its long white with 2 wires comming out of it with a black center that should be your problem check it repair it run it . GOOD LUCK
Oct 12, 2009 | Maytag Dryers
Maytag Dryer quit working mid cycle
sounds like the timer,the only thermal fuse i know of is to protect from overheating which cools and resets itself
May 10, 2009 | Maytag PYE2300AY Electric Dryer
My maytag performa pye2300ayw dryer will start but will not heat up. No matter how long I leave it on, it just won't heat up. what could be the source of the problem? the model number - pye2300ayw rev - 10...
You have a thermal overload switch that may be bad. It is located under the top of the dryer. Check first the breakers. Turn them off and then back on, then check the wiring in the back of the dryer and then the element itself. It may take 30 minutes to do all of this, but it will save you a lot in the long run.
Mar 04, 2009 | Maytag Dryers
Dryer runs but does not dry my cloths.
Hello, If the dryer appears to be running ok but will not heat you probably have a bad heating element or switch. Usually the heating element.
I hope this helps
CYA Gator241
Feb 09, 2009 | Maytag PYE2300AY Electric Dryer
Kenmore dryer stopped working, start button does nothing
hi thanks for the question i would check the thermal fuse at the back remove back panel . by the air duct theres a small thermal fuse with 2 smaller blue wires to it check that it does cause this thanks appliance doc
Sep 13, 2008 | Maytag PYE2300AY Electric Dryer
Problem With Maytag Dryer(PYE2300AYW)
you check the igninter on the burner . does it glow red when started then go off . or nothing at all . it has to glow red for any gas to come out to start the heat to dry your clothes .???
Jul 31, 2008 | Dryers
Mytag Dryer ModelLdg4000Aw
I have a Maytag Atlantis Gas Dryer that will turn on, rotate, but will not get hot and dry the clothes. A load of clothes in the afternoon, didn’t dry, tried again but didn’t dry – went to bed after putting on auto dry - next morning the dryer was still rotating and didn’t turn off. No hot air – only cold air.
Jul 13, 2008 | Maytag Atlantis MDG7400AW Gas Dryer
Does the dryer dry fine? If your dryer is taking too long too dry you might have a venting obstruction that is not allowing the dryer too sense that the clothes are dry so the timer won't advance. Try disconnecting the vent from the back of the dryer and dry a load unvented and see if the timer advances.
Jun 11, 2008 | Maytag SDE3606A Electric Dryer
Maytag PYE2300AY Electric Dryer Logo
251 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
