Home | Toshiba | 27AF41 27" TV | Default service menu cod...
Toshiba 27AF41 27" TV
Problem for Toshiba 27AF41 27" TV
Default service menu codes
By nitegoat on Jul 11, 2007
I recently purchased a used Toshiba 27af41 and noticed when I ot it home that the picture geometry was somewhat off. I accessed the service menu and tried to make adjustments. Unfortunately I didn't write down the original settings. Does anyone know the original default service menu settings?
Same Problem
Apr 26, 2009
-   no hay senal de video -   Guest
Apr 14, 2008
-   NO PICTURE-   Guest
Solution #1
posted on Jul 11, 2007
Somewhat Helpful)
techman
Rank: Guru  Toshiba Expert
Rating: 86%, 7606 votes
They are all different, in every set. Why do peeps not remember to leave these settings alone! sorry but now you will need to have the set serviced.
Was this helpful?
Yes
No
Solution #2
posted on Nov 05, 2008
Not Rated)
jrqwerty
Rank: Apprentice
Rating: 0%, 0 votes
http://www.audiolabga.com/pdf/27AF41.pdf is the Toshiba service manual. The default values are listed on page 17. If necessary I can read out the values in my set. DO NOT change the data listed under DESIGN MODE because Table-3 is incorrect. I don't have the source of correct info available as I write but I can get it if you need. I work on missile control systems & radars with little experience in commercial electronics.
Was this helpful?
Yes
No
Popular Solutions for Toshiba 27AF41 27" TV
Questions and Unsolved Problems for Toshiba 27AF41 27" TV
Do you recommend Toshiba 27AF41 27" TV?
Answer
Answer
My television keeps having a flashing red light when I try to tun it on. Is there anyway to turn it... (More)
Answer
The tv won't turn on when I press the poswer button. The red light blinks, but won't turn off when I... (More)
Answer
The tv won't turn on when I press the power button. The red light blinks, but won't turn off when I... (More)
Answer
cant gat my older rca direct tv remote to operate my toshiba model 27af41 tv
Answer
i need an unlock remote code for a universal remote
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Toshiba 27AF41 27" TV:
Top Standard Television Experts
Rank: Guru Guru
Solutions: 1493
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Standard Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
