Question about Cell Phones
NEGATIVE AN POSITIVE ON PALM TREO700WX BATTRY
    President:
  • 2,976 Answers
Negative has a - negative and positive has a + plus sign.
If you have the proper battery, it will only fit one way.
Posted on Jan 16, 2013
What cause battry to die over night?
If test light is a 12 volt light tester AND ILLUMINATES BRIGHT it shows that a component is actively trying to complete a circuit and yes drawing power causing a drain on your battery, now if test light illuminates low, possibility could just be ecm memory or antitheft system active . either way this test should only be done with a 12 volt test light as if you use a 5 volt (computer friendly) tester , false light will have you chasing a ghost. trust me. that trick helps by checking for parasitic draws a 12 volt tester does not illuminate when keep alive memory voltages are present . those voltages are not enough to drain over night. good luck
Nov 28, 2017 | GMC Cars & Trucks
My truck want crank?
you can charge with the cables connected
Sep 07, 2016 | Cars & Trucks
My klipsck kw-100 subwoofer will not power up i,v checked fuse it,s not blown want migth i do next
u can eanny 1.5 volt battry ,get 2 length wire .strip both ends.stick 1 strip end in the speaker box on positive or red connector .then you do the same on the negetave or black connector .now you should have one strip end for positive one strip end for negetave now connect negetave to battry .then brush the positive wire to battry positive .if you hear a thumping sound that mean that your subwoofer is good if you dont hear eanny sound that mean it is dead.i have done this for the past 50 years.bye..
Apr 13, 2012 | Klipsch KW-100 Subwoofer Speaker
Dont know which wires hook up to positive and which are negative
red - positive switched
yellow - positive constant
black - ground
grey w/ black - right front negative
grey - right front positive
white w/ black - left front negative
white - left front positive
green w/ black - left rear negative
green - left rear positive
purple w/ black - right rear negative
purple - right rear positive
Aug 09, 2011 | Kenwood KDC-422 CD Player
I need to reattach two deep cycle batteries to my fleetwood rv. Do I attach to one battery ms then attach the extra leads to the other battery , or do I attach the positive lead to one battery and the...
It should be positive to positive, negative to negative - parallel, not serial.
The simple way to tell is by how many cables you have. If you've got one positive and one negative, and only one jumper, it's a 24 volt system and should be connected in serial. If you've got one positive and one negative and two jumpers, it's a 12 volt system, and should be connected parallel.
If in doubt, connect up in parallel and test things. If everything works, it's a 12 volt system and you're good to go. If everything doesn't work (lights are dim, inverter doesn't give AC, etc.), it's a 24 volt system and you need to change to serial.
Serial - positive to system connection on battery 1, negative on battery 1 to positive on battery 2, negative on battery 2 to system negative.
Parallel - positive on battery 1 connects to positive on battery 2 and the system positive, negative on battery 1 connects to negative on battery 2 and the system negative.
Jul 06, 2011 | GPS
Hi, I wanted to start my Jaguar S typ, but the battry which is in the luggage compartment is dead & it is not possible to oppen it by key, but a buuten which is not working because of battry. How can I...
hi.
it is a little awkward but it can be done.
if you go under the car with jump leads, connect the positive lead to the thick wire on the starter motor. connect the negative to the body or chassis.
the starter lead is connected direct to the battery so it will give enough power for you to open the boot using the button or the remote.
hope this helps
Apr 02, 2011 | 2000 Jaguar S-Type
Positive cable to the negative battery post
hmmmmmmm you maybe burrned the starter motor because its connected directly to the battry
May 31, 2009 | Ford Thunderbird Cars & Trucks
I want the driver for mi palm treo 700wx
You should be able to find what you need at www.palm.com/nz/support/treo700wx/ including software, setup guides etc.
Mar 27, 2009 | Palm Treo 700wx Smartphone
Transfering picture files into an existing file
Connect your treo to your computer. Access it from "My Computer." You should be able to move files around easily from here.
Sep 10, 2007 | Palm Treo 700w Smartphone
Cell Phones Logo
18 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
