Question about Home
I have a wood burning fireplace. How much moisture should the wood have? and what can I do if it's too moist?
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 28 Answers
There should be >20% moisure on the wood. If it's too moist, it needs to be seasoned (getting rid of the etxra moisture). The most common way this is done is just by waiting for it to dry out, but now-a-days people are using kiln ovens.
Posted on Jan 16, 2013
The fireplace no longer produces a flame, i do not have the manual to trouble shoot and fix it
Gas Fireplace Manual - Gas Fireplace Instructions: Mendota ...
mendotahearth.com/gas-fireplace-stove-owners-manual.php
Mendota gas fireplace manuals and gas fireplace instructions for Mendota ...Mendota Gas Fireplace Insert FullView Model FV33i PF2 - Installation Manual
[PDF]FIREPLACE HEATER - Crane
crane-usa.com/assets/.../Fireplace_Heater_2013.pdf
by C Care - ‎Cited by 2 - ‎Related articles
your fireplace heater, please contact Crane. Customer ... This instruction manualapplies to the following models of the Fireplace Heaters product line: Color.
Nov 29, 2015 | Heating & Cooling
I need to build a hearth for my Waterford 106 Wood Burning stove. How big should it be? Especially, what did Waterford recommend when it built this stove?
Anyone heard of a Waterford 103? ' Hearth.com Forums Home
www.hearth.com/talk/threads/anyone-heard-of-a-waterford-103.9653/
Nov 28, 2007 - Hello, I'm new here and I have a stove in my house that arrived with no... Does anyone know anything about this stove? Coal? Wood? Age? Make? ... The 103 was a wood-burning "Fireplace Stove" from the mid-80's. Installing an insert without using 6" flue liner tube because of ...
Sep 23, 2014
Looks like it's officially 24/7 burning time...
Dec 10, 2009
More results from www.hearth.com
Wood Stove Hearth on Pinterest ' Corner Wood Stove ...
https://www.pinterest.com/explore/wood-stove-hearth/
Pinterestfrom My Paradissi ... decorating around a wood stove ' Cosy wood burning stove fireplace: how to decorate around it. love the ... 893 106 ... wood burning stove hearth ideas ' old wood stove on brick hearth by Brian Powell - Stocksy United . .... Corner Wood Stove Surrounds ' How to Build a Hearth for a Wood Burning Stove.Missing: waterford
Oct 21, 2015 | Home
Even if it was a wood burning fireplace from the beginning & was converted to gas ?
Now that's a LOT of additional information. I hesitated to answer your question the way it was worded originally.... IF in fact it is a masonry chimney and originally built to burn wood, you should have a chimney sweep do a thorough inspection of the flue to ensure it is safe to use again. Flue temperatures, while burning wood, EASILY exceed 1200 degrees whereas natural gas flue temps are in the 450 degree range.
It also should have a clay tile liner and not be fabricated of brick only. The unsafe thing of an unlined brick chimney or a chimney with a severely cracked liner has to do with unburned gases condensing within the inner surfaces of the chimney. Some of those gases are moist and will condense on the inner surface and eventually have an unsafe build up that can be ignited by an oversized flame or excessive sparks causing a flue fire. During a flu fire, temperatures exced 2000 degrees and an unlined BRICK flue of that age could have lost some mortar allowing superheated gasses to seep into the crevices. Those superheated gasses then explode when igniged by the flue fire and either do extreme damage to the flue, blow the entire chimney apart or in the worst case scenario burn your house down.
I'm sure you've seen houses burnt and the chimney was left standing....but you have also seen damaged houses with the chimneys blown off the end of the house and laying in rubble toppled out into the yard. The latter visual picture was an example of the end result of the gasses exploding. If the chimney was inside the house instead of on the end of the house, the house would have been burnt also.
There is a lot to be careful about when heating with wood and to start off safely you need to have your chimney inspected and the gas components removed with the gas line capped EXTERNAL of the fireplace.
Dec 08, 2014 | Home
Can I burn wood in a gas fireplace if the gas is not on?
No, the gas liner is not adequate for solid fuel, it won't draft properly,
Dec 08, 2014 | Home
Can't keep the wood burning in stove. How does the buck stove take in air?
To burn properly, it needs proper combustion air and proper draft. Draft is effected by the size and height of the flue the appliance is connected to and by how much combustion air is available. The appliance flue connection should not be reduced to fit a smaller chimney size. That is, an 8" flue should not have an 8 x 6 reducer to vent it into a 6" chimney.
The wood you are burning could contribute to a poorly burning fire. To burn properly, the wood needs to have been "seasoned" for a minimum of 1 year or close to it. Two years is even better. "Green"
or freshly cut wood contains an unbelieveable amount of moisture in it and a tremendous amount of the heat is wasted just "preheating" the wood to the temperature that causes it to release gasses for ignition.
I don't know the style or model of your Buck, but all wood burning appliances should have combustion air dampers of either a sliding design, rotating round design or hinged design with handle at the bottom front of the firebox. I'm sure there are some fancy new designs that have air piped in from outside the structure.
Every wood fired stove, fireplace or furnace has its own idiosyncrasies and its up to the user to determine what's required for making it operate as designed.
Dec 06, 2014 | Buck Stove Home
Yes, i can seem to get an answer on weather my Marco fireplace model # 7927740 can burn gas or wood. I was told it could do both?
The best answer would be to contact Marco or their distributer directly. I have never seen a fireplace that would burn both. I have seen dual-fuel central heating furnaces.
I would not attempt burning wood without input from Marco.
Nov 19, 2014 | Heating & Cooling
I have a Marco wood burning fireplace built in 1980, can't close off vent on bottom of firebox...lets in ALOT of cold air. Help
TRY TAPPING ON IT WITH A SMALL HAMMER LIGHTLY, & QUICKLY 15-30 TIMES & SEE IF IT COMES LOOSE AND SHUTS FOR YOU.
Dec 27, 2012 | Leisure HOMEPRIDE Electric Fireplace...
I have a gaz fireplace Marco DWF36CF-3 vented and would like to know if i can burn wood in it
My name is mike. YOU DO NOT want to attempt to burn wood in a gas fireplace. The reason for it, is the venting is not designed for the fumes and high heat the wood produces. Only way you can safely burn wood, in a gas fireplace is have to make sure the piping and venting is set up correct to burn wood. Your problem is not most likely your stove or fireplace for the safety, it would be your venting. Thanks Mike
Oct 22, 2011 | Heating & Cooling
Can one use unvented gas logs in a superior CF3860 fireplace?I
Little documentation on this fireplace but it appears to be a vented wood-burner(?) If vented, there should be no problem using gas logs. If burning correctly, you may consider cutting back on the flue and intake air, as moisture build-up is the biggest drawback to gas fireplaces. Too much air is just wasting gas.
Dec 03, 2010 | Heating & Cooling
How do we install a burner on a fireplace?
Thinking of adding a fireplace or wood stove to your home? If so, proper installation and maintenance is absolutely critical to ensuring the fire stays inside your freestanding fireplace or wood stove and doesn't venture outside of it.
If your manufactured home already has a fireplace or wood stove, it's a good idea to go look over these safety guidelines to confirm that it was installed correctly. If you plan to install a fireplace or wood stove, follow these safety guidelines carefully.
First, don't try to tackle this project yourself. While installation manuals usually provide all the instructions necessary for a manufactured home owner to install a wood-burning fireplace or wood stove, the consequences of a mistake are so disastrous, it's a task best left to experts.
It's a good idea to first check with your insurance company for their guidelines before installing these items. Your insurance policy may not cover damages if a fireplace or wood stove was not professionally installed. Plus, the manufacturer's warranty on the fireplace or wood stove may not apply unless the unit is installed by a professional.
Also can check this ARTICLE for other details.
Hope helps.
Jun 02, 2010 | Heating & Cooling
Home Logo
123 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
