Question about Toshiba Satellite A205-S4617 Notebook
My screen blackout out, or burned out, or just won't go on. It was just sitting on the desk when I left. When I came back a few hours later, it was black.
  • Anonymous Jan 28, 2009
    MY MONOTOR GOES COMPLETE BLACK AFTER 10 OR 15 MINUTES ON. I can hit the on button one time and it will pop on and then back off.
  • andyK0 May 11, 2010
    Check both power and video cables. See behind monitor and behind pc for anything loose. If the power light is on then is there picture? What type of monitor? If flat LCD type shine a light on it check for faint images if any that will determine if the backlight is dead.
  • 4 Answers
Backlight CCFL is burned and needs replacing. OR,...and Toshiba will not admit to it, but the LCD inverter has gone bad. The part is $200.00 bucks! Plus labor to install it. If you bought the three year warranty they push on you and try to have it repaired, they get out of it saying that you dropped it and thats what damaged it. I bought two A205 at the same time from the same store and they both have the same defective parts. Good Luck with this one. They wont admit that its a factory defect!
Posted on Feb 27, 2009
LG 55LF6300 Black spot and picture freeze every few seconds
If you wish to get some details; visit the site linked here. Pull up older posts.
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts
Sep 03, 2017 | LG Televison & Video
Why is it beeping sporadically?
It looks like it needs service of some sort. Have you referred to its manual?
May 13, 2015 | Liebherr CS1601 (15.5 cu. ft.) Bottom...
1997 Lincoln Towncar, cranks but won't start?
first you need to test for spark if there is spark then check for fuel if there iis no spark have your ignition module ckecked for fuel take the lifuel line off from fuel tank to fuel lilter it is not difficult.
Jan 24, 2013 | Cars & Trucks
No picture and burning smell from left side
Bad COF ic on buffer board. Can usually tell which one's bad. It will look overheated or a hole in top of ic. Look at upper and lower buffer boards to see which ic is bad. Can get from Encompas Parts, Recommended replace y sustain with buffer.
Nov 26, 2011 | SNK Magnavox 42MF231D 42 in. Plasma TV
Volume screen keeps popping up every few seconds, when I touch "menu" button it goes away, only to come back a few seconds later
michaelfoder, Because very strange things start to appear on the screens of cold cathode fluorescent lamp, back-lit, LCD monitors, I always investigate the "switch-mode-power-supply/ccfl inverter supply for very common occuring defects in the supply!!! You can find out about them here: http://www.lesliewong.us/blog/2005/05/02/hp-pavilion-f1703-flat-panel-display-blackout-solution/ Just remember to do a fixya rating and testimonial if this response helps you to find and correct problem in your 2-3year old unit. Problem could be an unstable +5v or +3.3v dc supply rail. 12fixlouie
Aug 16, 2010 | HP w1907 LCD Monitor
A sun spot on the screen?
Sounds like you literally burned the screen. You can get replacement parts here http://www.ifixit.com/iPod-Parts/iPod-touch
-=/ Daft Tech /=-
Oct 27, 2009 | Apple iPod touch
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
Blackout Mode On and Off
When Blackout mode is turned on, the monitor display will turn off to
reduce power consumption.
This additional power enhances the sound quality.
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
function will be displayed for 5 seconds to show the operation before
returning to Blackout mode.
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Monitor screen blackout
check for any DRY SOLDER , specifically around the INVERTER TRANSFORMERS on the PC board . hope it helps
Mar 28, 2008 | Computers & Internet
Toshiba Satellite A205-S4617 Notebook Logo
69 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
