Question about Armitron Chronograph Sport #204345BKBK Watch for Men
Active intent watch setting date - Armitron Chronograph Sport #204345BKBK Watch for Men
How to change date
Try to get inf contacting Ashford:
be the first to know
Esxplrore site. You have live chat:
Aug 09, 2015 | Watches
Star Wars rebels led watch how to set time and date
Hi,I had the same problem. Look on the side of the watch on the right, in between the two pressable buttons. There is a small black button, size of a Byro tip. Press that in for 5 secs then the date display will start to flash. Set with the lower big button then press the small button again to cycle through month, day, hour, minute.
Phew. Takes a bit of spotting.
Mar 14, 2015 | Watches
I cannot set the time on a wr165
here's a simple instructions of setting your watch
Watch setup instructions
for the Armitron Instalite All-Sport :
Mode B / \ C Date
Light A \ / D Alarm
_____________________________________
Set time time / date
Press and hold B (Mode) untill alarm hours flash
Press D (Alarm) to advance these
Press B (Mode) again, seconds will flash,
press D (Alarm) to advance these
Press C (Date), minutes flash, press D to advance these
Press C again, hours flash, press D to advance these
Press C again, month flashes, press D to advance these
Press C again, Date flashes, press D to advance these
Press C again, Date flashes, press D to advance...... [suggestion from Chikita]]
Activating/Deactivating Hourly Chime
1. From "Normal Time Mode", press and hold "D" (Alarm) and
at the same time press "C" (Date) once. Hourly chime symbol,
( a house shape) appears in "chime" windows to indicate
the hourly chime will beep every hour.
Activatin/Deactivating Alarm
2. With "D" (Alarm) still pressed, press "C" (Date) again. Alarm symbol
( a clock shape with waves above it) appears in the
upper right to indicate the 24 hour alarm is now activated.
[I assume this "toggles" between off and on states,
so performing it again should turn off the alarm]
i hope this will help you.
Jul 22, 2011 | Armitron All Sport Digital watch
How do I turn off the alarm on my Armitron watch?
I don't know whether this is what you are looking for, as the watch comes with no packaged instructions OR general support, on their website, XD,
Nik.
http://home.earthlink.net/~eldonenew/armitron.htm
or
http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Armitron All-Sport Watch Instructions By Brian Walker eHow Contributor 9 Found This Helpful The Armitron All-Sport is a unisex style of watch made by Armitron that features a digital readout and four buttons around the outer dial for adjusting various aspects of the watch. It can set alarms, keeps the time as well as the date, and has a built-in backlight. Accessing and adjusting these various settings is a fairly simple process.
Other People Are Reading
Setting Date, Time and Alarm
  • To enter the date and time setting mode, press and hold the "mode" button, located on the top-left of the watch. Continue holding this button until the display begins to flash. This first display is the alarm setting, should you choose to set an alarm to go off. If you'd like to set the alarm, use the "alarm" button on the bottom-right of the watch to advance the hours to the desired one. Then press the mode button again; this will cycle through the minutes and seconds of the alarm to allow you to set those as well. Once you have set the alarm, you can press the "date" button at the top-right of the watch to proceed to the regular time setting. These numbers, which will now be flashing, also are adjusted by pressing the alarm button to change them. Pressing the date button again will now cycle through the hours, minutes, seconds and the date. As you continue to press the date button, the All-Sport will continuously cycle through these options; don't worry if you forget to set one, you can simply press the date button a few times until you get back to the setting you need to change. Once the alarm, time and date have all been set, you can press the mode button one more time to exit to the normal watch mode that will display the date and time.
Using Chime and Alarm
  • The Armitron All-Sport features both an alarm and an hourly chime. The alarm function will cause the watch to continuously beep at the selected time until you turn it off by pressing a button. The chime will cause the watch to beep once every hour. You can turn both these features on and off by pressing and holding the alarm button and while holding it pressing the date button. The first time you do this, the chime will turn on and a small house symbol will be displayed on the watch face. Performing this button-pressing sequence again will turn on the alarm, which in turn displays a small clock icon on the watch face. Each successive pressing of this button sequence will alternate between the chime and the alarm, turning them either on or off.
Backlight
  • The All-Sport also features a built-in backlight to help you view the watch in dark conditions. This light can be activated by pressing the "light" button on the bottom-left of the watch. Pressing this button is the only way to activate the light, and doing so will only cause the watch to illuminate for a few seconds at a time.
Read more : http://www.ehow.com/way_5786808_armitron-all_sport-watch-instructions.html
Jul 20, 2010 | Armitron Round Digital Sport 408089 Watch
I cannot figure out how to set the time on my Puma watch.
mcdevito75 here, You can try www.puma.com They have an overseas number but also the option to find a Puma retailer in your area.
Jul 13, 2010 | Puma Active Collection Fluctuation...
Setting Armitron Watch model WR330
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all ARMITRON watch manuals. Rate me, please.
Mar 14, 2010 | Watches
I am trying to reset my T Touch watch from Tissot and can not find book. need to reset time and also how to convert from metric to US standards, like ferinhit and from meters to feet.
SET TIME:
1. Activate Crystal
2. Tap center of screen until digital time comes up
3. Press and hold top button (+) until watch beeps, display will be flashing
4. Use + and – key to adjust time. If several hours off, hold appropriate key and
after first hour passes, only the hour hand will move.
5. Make sure the digital display shows A or P for AM or PM
6. When finished, touch center of screen again.
SET DATE:
1. Activate Crystal
2. Tap center of screen until date appears
3. Press and hold top + button until watch beeps and display flashes.
4. Use + and – buttons to change date to correct one.
5. Make sure to set time first, if you set date first, you run the risk of the date
changing at noon rather than midnight.
Nov 26, 2008 | Tissot PRS 516 T91142651 Wrist Watch
Old model timex compact disc digital audio
Hi catlady05,
To set the digital time and date on your Timex Ironman, please follow the steps below.
1. press and hold the "set" button for two seconds.
2. Use the "advance" button to reach the correct hour.
3. Press the "mode" button, followed by the "advance" button to set the minutes on your Timex Ironman.
4. Repeat the procedure of pressing the "mode" and "advance" buttons to set the month, date, year and day of week.
5. When you are finished setting the time and date, press the "set" button to save.
Setting an Alarm
1. Begin by pressing the "mode" button until the alarm screen appears.
2. Press the "set" button and use the "advance" button to set the hour for your alarm.
3. Repeat the same procedure to set minutes and seconds for your alarm.
4. When you have finished setting the alarm, press the "set" button, followed by "advance" save and activate your alarm.
5. When you alarm sounds, you can deactivate it by pressing any button on the watch.
Hope it helps.
Thank you for using FixYa.
Oct 29, 2007 | Timex Ironman 53151 Wrist Watch
Armitron Chronograph Sport #204345BKBK Watch for Men Logo
66 people viewed this question
Top Armitron Watches Experts
Ansel Alberto
Ansel Alberto
Michael Vincent Cruz
Are you an Armitron Watch Expert? Answer questions, earn points and help others
