Question about Logitech -9536890403 Mouse
Jumping mouse cursor
My mouse cursor keeps on jumping.i cleaned the mouse thoroughly.but it didn't solve the problem.i have noticed that by keeping the connecting cable in certain positions the mouse starts working just fine.the connection between the mouse and the computer is not loose.i have the following doubts: -could the connecting cable be the reason for the jumping? -or is the drive to be blamed for it? can anyone suggest any useful measures?
  • elsa thomas Jul 13, 2007
    thanks for the solution.
    i tried the first two suggestions and came to the conclusion that the problem is neither with the cable nor with the mouse connector.i guess there's some problem with the mouse.
    now i would like to know if anyone knows why this problem has occurred?as i said i have cleaned the mouse.what else could be the problem with the mouse?
  • Julez Feb 20, 2008
    cursor jumps during typing when using mouse or pad in word and e-mail etc
  • 3 Answers
I recommend StopMouseJumping to fix this problem. This software is able to tell apart normal mouse movements from jump-outs. Normal mouse movements are allowed, jump-outs are filtered out.
Try it:
http://www.stopmousejumping.com/
Posted on Jul 27, 2011
Mice cursors keep blinking how can i stop it hp pavilion a6230n
Posted on Apr 06, 2009
  • 624 Answers
Elsamma, If you are positive keeping the cable stationary prevents the problem try this: Try holding the mouse connector stationary and wiggle the cable. If the problem occurs then the connection between the mouse connector/cable is defective, due to the low value of this mouse the fix would typically be replacing rather than repair. If that doesn?t work try wiggling the mouse connector where it plugs into the PC. If this causes the problem to reappear then either your mouse connector or the PC socket is damaged. Try another mouse and if the problem goes away, again the fix would be to replace the mouse. If a new mouse doesn?t fix the problem then there is a good chance the PS2 connector is damaged. At this point I would purchase a USB mouse which should solve your problem Let us know how things go and if you need any more assistance.
Posted on Jul 11, 2007
  • tomj23 Jul 13, 2007
    Your mouse is an optical one which means it has no moving parts; however, there are other things which can affect tracking:
    -wrong driver or driver problems
    -defective movement tracking components inside the mouse.
    -surface the mouse rides over does not work well with it. Some surfaces do not reflect the light generated by the mouse well. Try a cloth or hard surface mouse pad to see if it changes the behavior.
How do i fix keystrokes that jump backward as I type?
Some Lenovo touchpads are over sensitive and they cause the cusor to slip or jump around. In Control Panel select Mouse or Touchpad. A box will open and you can locate touchpad Properties and adjust the sensitivity. Lenovo also has updated touchpad software/drivers for one or two of the most troublesome models. i was able to reduce the cursor jumping around quite a bit by adjusting the sensitivity, but i still don't think it's a good design.
Aug 12, 2014 | Lenovo Computers & Internet
Jumping cursor
Keep your hands away from the mouse pad when typing on the keyboard.
Apr 28, 2014 | Dell Inspiron Computers & Internet
Jumping Cursor
Make sure your palm or more than one finger is not covering the touchpad. Laptops manufactured before 2013 did not understand "Multi-touch" on touchpads. Use only one finger on the touchpad and problem should be solved. If it doesnt, the touchpad is damaged. Buy a mouse.
Nov 01, 2013 | Dell Inspiron Computers & Internet
My cursor in windows 7 keeps jumping all over the place when I type or try to click on an icon how can I fix it?
Swap out the mouse.
If there is a ball underneath, remove it and clean the X and Y rollers.
Oct 16, 2012 | HP Computers & Internet
Jumping cursor on laptop
clean the mouse pad ,,, if doesn't work uninstall pad's driver and re-install the correct one... some laptops comes with joystick if yours have one clean it with a contact cleaner or disable it by unplugging it's cable ,,, if it didn't solve your problem replace the mouse pad or use a usb mouse ... :)
Mar 06, 2012 | Sony Computers & Internet
Mouse Cursor Jumping while typing causing major typing errors
Reinstall the Mouse Drive rplease and it should work.
Please write abck if you still face problems.
Jul 01, 2010 | Lenovo 3000 Y410 Laptop
When typing cursor keeps jumping
Generally there is a setting (CONTROL PANEL, MOUSE, Touchpad Tab) to either enable a feature like PALMCHECK or to disable the touchpad while typing. If neither option is shown, then try updating your touchpad driver
Dec 27, 2009 | ASUS Eee PC 1000H Laptop
Microsoft Mouse cursor jumping around
maybe u can use mousepad, with fabric material
May 28, 2009 | Microsoft Windows XP Home Edition
I think some where in the cable there is a broken wire, it is inside the cable, cause there is a certain position that it work properly. You can also test it by tyring other mouse if the problem still the same.
Oct 16, 2008 | HP Wireless Optical Mouse
check the battery if any,maybe its leak,try another mouse,maybe the one you have is already defective.
Mar 17, 2008 | Computers & Internet
Logitech -9536890403 Mouse Logo
862 people viewed this question
Top Logitech Computers & Internet Experts
micky dee
Damen Wong
Damen Wong
Are you a Logitech Computer and Internet Expert? Answer questions, earn points and help others
