Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Mitsubishi 52525 dlp capacitor problem red light after lamp chang
I removed the PWB-POWER LAMP board which has the leads going to the lamp is this the board that usually has the problem capacitors.
  • Mitsubishi Master
  • 8,617 Answers
No the board youre refering to is the Power PWB which is encased inside the metal chassis block. You can get the kit that is for your model that has the capacitors and step by tep instructions on how to disassemble the chassis to accesss the Power Pwb. Heres the link to the kit you need if the lamp led is red.
http://servicemanuals.vstore.ca/product_info.php/pName/mitsubishi-v26-dlp-power-pwb-repair-kit/cName/repair-kits
Posted on Jan 26, 2009
Changed lamp where is reset button to get rid of red light?
if the lamp led is still red after replacing the lamp. The problem is the Capacitors on the power board have failed. You can get the V26 Power board repair kit which contains the replacement capacitors and has a cd with step by step instructions on how to do the repair. Heres a link to the correct kit for your model.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Replaced lamp ,have sound but no pic,shuts down
Thats the code for whats known as lamp abnormality which is actually caused by failed capacitors on the power board. Heres a link to the repair kit that will usually fix that issue. The kit contains the replacement capacitors and also has step by step detailed instructions with photos so you can easialy do the repair yourself.
Jun 13, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Lamp Indicator is Red
Its much more likely that your getting a 34 error which is a lamp abnormality vaused by defective capacitors on the power board. You can get the V26 DLP power PWB repair kit at the following link that should repair the issue. Chances are your old lamp is still good.
May 19, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Red light stays on after lamp replacement and reset
if the lamp light still remains solid red its most likely needing the capacitors on the power pwb replaced very common problem with the V26 Chassis DLP. You can get the V26 power pwb repair kit at the following link which contains the replacement capacitors and step by step instructions on how to do the repair.
Feb 01, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-52525 52 in. Rear Projection - no picture lamp light goes red
yes the capacitors go bad on the power pwb . You can get the V26 Power PWB repair kit at the following link which has the replacement capacitors and instructions. Heres the link its listed under the repair kit category.
Dec 03, 2008 | Televison & Video
Green status light keeps blinking after lamp replacement
continuous blinking green light indicates that the capacitors have failed on the DM pwb. You need the V26 DLP DM repair kit which is available at the following link under their repair category.
Sep 07, 2008 | Mitsubishi WD-52525 52" Rear Projection...
WD-52525 Red lamp Indicator
usually with that model when you get a 34 eror code for lamp abnormality, its directly related to the capacitors on the Power Pwb. You can get the V26 Power PWB repair kit at the following link which repairs that issue. It contains the replacement High temp capacitors with the board location numbers and PWB identification as well as the service manual on CD. Heres the link its under their repair kit ctegory.
Sep 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 red light no picture or sounds, lamp has been replaced.
The hardest part is getting the chassis block out. But if youre mechanically inclined and follow the illustrations and label all the wires you unplug, its not that difficult a job. The soldering isnt very difficult as theyre just capacitors. The chassis is contained inside a metal container and has to be removed as a unit then opened up to get to the PWB PC board.
Jul 06, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Wd-52525 no image
have you replaced the lamp? If so and it still lights up as red you need the V26 DLP PWB PCB kit to replace the defective capacitors on the PWB the kit has all the capacitors and instructions on CD
Here is the link.
Jul 02, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Red lamp light with newbulb, won't come on error code 34
There are two 1000uf 16V capacitors on the PWB that cause that problem code 34 lamp abnormality. If you need more info let me know.
May 04, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
618 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
