Question about Sunbeam Blenders
While mixing anything the mixer will slow down and usually stop.
Sometimes it will start speeding back up and sometimes I shut it off and then back on. Has anyone else had this same problem?
  • 4,654 Answers
This is normal for household type blenders. Sounds like you do a lot of blending. Commercial blenders provide more power and can withstand lots of blending projects. Thicker the material the more load on the motor. As the motor heats up the winding become hot and the motor begins to breakdown,
I really hope this helps answer your question. If not please let me know... Thanks, Sea Breeze
Posted on Feb 01, 2009
Can I upgrade motor on vitamix 4500...it wont make almond butter...
Contact Vitamix, find a service agent through them and have it looked at. You are only going to be able to get your motor (if you need one) through someone associated with Vitamix anyway.
Aug 27, 2012 | Vitamix Turbo Blend 4500 - Heavy Duty Vita...
I was using my blender and stopped to add more ice for a smoothy mix, but when I tried to start it up again the lights began flashing at random but the blender would not work. Why?
It sounds like it may have overheated. Firstly, Switch it off and let it cool down for a few hours. Quite often it will burst back into life. If not, you will probably need a new control board. These come in several variations:
9708845 Silver 110v 9709339 Black 110v W10291857 Silver 240v
Mar 25, 2011 | KitchenAid KSB560 5 Speed Blender
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Mar 21, 2011 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
I have a new b&d Cyclone blender that I use daily to mix protien shakes (nothing hard). Two or three times a week it shuts down and flashes "ee" on the screen. Ihave to uplug it for several hours befor...
No expert, but I think here the safety shut off works much much more broadly than just dangerous overheating, possibly to avoid all physical harm lawsuits for anything imaginable. The reason could be any glitch, anything that affects the unimpeded speed of the blades, any maladjustment of the seated load. If the resetting takes hours something is definitely too sensitive or on the verge of crashing the safety alert again. Or this unadvertised extra sensitivity is a faulty device set way beyond specs or just plain broke.
Jun 28, 2010 | Blenders
How do you take the mixer off of the wand to clean it?
YOU DO NOT NEED TO ,TO CLEAN MIX WATER AND CLEANING FLUID AND BLITZ THIS UNTILL CLEAN.
Oct 13, 2009 | Williams-Sonoma Stick Blender Handheld
Oil Leak-Stand mixer
Leaking of oil in a stand mixer is not necessarily indicative of a large problem.
Kitchenaid stand mixers are overpacked with oil to last the lifetime of the motor. If the motor sits idle for some time (is not used), the oil may begin to drip from the gears and settle. Oil leakage may primarily be seen from around the beater shaft or planetary action.
A stand mixer can lose up to a 1/4 cup of oil before it needs to be serviced.
It is recommended to run the mixer on speed 10 for 2 minutes in order to redistribute oil back into the motor. In order to prevent future occurences, this is recommended to be done every 3 weeks if mixer is not being used.
Jun 18, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Mar 23, 2009 | KitchenAid Kitchen Aid Kitchenaid 5-speed...
Blender performes poorly, if at all
Hi, cauliflour is not compact no water mix, I have suggestion , cut it 1/2" long make it fine put in blender mix w/small amount of water then start. shut off mix with wooden mixer and start again then okey.
Jan 14, 2008 | KitchenAid KSB5 Professional Stainless...
My hand mixer stopped working.
Have you tried greasing it near the blade. I read in my instruction book that sometimes they seize if they aren't used often. They also suggest trying to soak the wand in a pot of hot water for a minute or two and then trying to use it in the water. Hope this helps
Aug 30, 2007 | Bamix Gastro 200 Handheld Blender
Blenders Logo
166 people viewed this question
Top Sunbeam Blenders Experts
John Tripp
John Tripp
Mike Cairns
Mike Cairns
Are you a Sunbeam Blender Expert? Answer questions, earn points and help others
