Question about AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
HP e6850 sound card driver - AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800)
Driver download sound audio
Not sure what your are asking but -- the audio is on the motherboard, not the processor. What motherboard are you using with your dual core processor?
Aug 24, 2013 | Intel E6850 - INTEL CORE 2 DUO PROCESSOR,...
(400745-001) Sound Card: Where do I download sound drivers for my hp comput...
Check it our HP official site, otherwise explain that which HP series computer you have?
http://www8.hp.com/au/en/support.html
Thanks
May 18, 2010 | HP (400745-001) Sound Card
How to download a sound card if you have no sound?
what you need is drivers for your sound card,, if you have a hp look for hp drivers, if dell look for dell drivers,,
when you find the right web site you can downlod the right drivers for your sound card.
a sound card is in your computer you need sound card drivers to make it work,,
post more info on this pc,, dell? hp? i can send a link for needed drivers if i had this info
Apr 26, 2010 | Computers & Internet
After restored cant detect Audio Device and Multi media controller. and the system is not connected to the internet.
http://h20000.www2.hp.com/bizsupport/TechSupport/DriverDownload.jsp?lang=en&cc=us&prodNameId=3429270&taskId=135&prodTypeId=12454&prodSeriesId=3429268&lang=en&cc=us&submit=Go%20%BB
all drivers can be found on link above.
if helped rate fixya
Apr 09, 2009 | HP xw4600 Workstation - 1 x Intel Core 2...
Sound card driver
for sound drivers for your hp compaq notebook go to the following link http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=447348&prodSeriesId=447371&swLang=8&taskId=135&swEnvOID=1093#113165 and download the audio driver you see there.this should solve your problem. just copy the link and paste it in your web browser
Mar 20, 2009 | HP Sound Card
Hp Pavillion dv9000 sound card driver for xp.
Go to NVIDIA website they have all the drivers.
Rate with 4 diamonds
Mar 02, 2009 | HP Computers & Internet
Sound driver hp g7000
http://welcome.hp.com/country/au/en/support.html?pageDisplay=drivers
check this site
Aug 04, 2008 | Compaq Audio card Sound Card
1333 FSB processor ( E6850 ) on a 1066 FSB motherboard, DDR2 667 memory
Hi proenza. you're making good sence! You're D945GCL MB should be able to run 1066 FSB. Not 100% sure you're memory will keep FSB up to 1066.
Here's the trouble though. The Intel Core 2 Duo E6850 will not run on the Intel D945GCL motherboard because it is not supported. Look here at Intel's web site. Supported CPU's.
http://processormatch.intel.com/CompDB/SearchResult.aspx?Boardname=d945gcl
Intel E6850 specs sheet. http://www.dealtime.com/xPF-Intel-Intel-Core-2-Duo-E6850-Processor-3-0GHz-4MB-Cache-1333MHz-FSB-Conroe-Dual-Core-OEM-Socket-77
Intel E6700 spec sheet. http://www.dealtime.com/xPF-Intel-Core-2-Duo-E6700-2-67Ghz
This CPU is supported by the D945GCL MB.
Intel Core 2 Duo E4700 Processor BX80557E4700 - 2.60GHz.
$149.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3826343&CatId=2396
In order to get 1066MHz (CPU can run at), you'll also need the memory support at 800MHz. The D945GCL MB can only run DDR2-667MHz.
Many people buy a CPU to run MB's specs (1333MHz) just to find the same MB does not support DDR2-1066MHz or DDR2-800MHz. Motherboard Mfg's are lagging. DDR3-1333MHz is out there now to support the 1333 MHz CPU FSB.
http://www.lagoom.com/KINGSTON_1G_DDR3_1333MHZ_PC3-10667/KVR1333D3N9_1G/partinfo-id-580235.html
I hope this has helped you make a decision proenza.
Good Luck!
Mike
Jul 17, 2008 | EliteGroup ECS 945GCT-M/1333 Motherboard -...
AMD Athlon 64 X2 3800+ Dual Core Processor - Socket 939 (AMDX23800) Logo
140 people viewed this question
Top AMD Computers & Internet Experts
David
David
rafnix
rafnix
Are you an AMD Computer and Internet Expert? Answer questions, earn points and help others
