Question about SanDisk Sansa Clip MP3 Player
Turning off Sansa clip
I don't know how to turn the Sansa clip off without disconnecting it
  • 161 Answers
Push the sliding switch on the side up and hold it for a minute
Posted on Mar 21, 2009
  • 34 Answers
There is a switch on the left side slide it upwards
Posted on Apr 13, 2009
4 Suggested Answers
  • 14 Answers
SOURCE: sansa clip is stuck on Refresh Database Screen.
1ST: Just try to 'reset' by holding down the main center button AND pushing UP on the lock/off-on button, for about 8-9 seconds,
It will then 'refresh' the database, shouldn't lose anything,
OR:
MANY problems can be fixed ultimately by the following;
REFORMAT the SansaDisk Clip by finding it in My Computer and right click then just 'format' the thing. THEN drag and drop new music into it (or books), DRAG and DROP, you apparently erase the thing with a 'FORMAT' ....BUT - it's .sys files remain and it is like new {as in empty}
This usually fixes almost anything, should even erase a virus (I'm guessing) but shouldn't hurt it.
Good Luck!
-simple 'drag and drop' from my MUSIC folder seems to work just fine for me...
Posted on Jan 05, 2009
  • 9 Answers
SOURCE: My Sansa Clip is stuck on disconnected
i'm not sure on this one, but reseting it might help. to do this you hold the power button in the on position for 20 seconds, release it and then try turning it off. good luck
Posted on Apr 12, 2009
SOURCE: Sansa Clip will not turn on
I had the same problem, and found the solution on the Sansa Clip forum page at sandisk.com
Here it is: Simply push the on switch up and hold it for 15 seconds, this initiates a soft reset, which resets the device to the state it was when last turned on
Posted on May 13, 2009
My sansa sanclip just froze.iit was charging and
Hi.
You have two Solutions.
Solution 1:
Resetting the player:
1. Slide and hold the Power switch up for approximately 20 seconds.
2. Release the Power switch.
3. To turn the player on, slide the Power switch up then release instantly.
Solution 2:
Updating the Sansa Clip Firmawre:
  1. If it's not installed yet, download and install the Sansa Firmware Updater.
  2. Connect your Sansa Clip to the computer.
3.1. Assuming there's a new firmware available, the following message will appear on your lower right task bar. Click on the balloon message:
3.2. 3b. OPTIONAL: You can also manually run the SansaUpdater from your programs files. Most likely it will be under All Programs > SanDisk > Sansa Updater > Sansa Updater.
4. Select the Firmware check box.
5. Click Download Now. Firmware downloads and updating starts.
6. Click Finish after the firmware has been downloaded.
7. Disconnect your Sansa Clip from the computer.
8. A "Firmware upgrade in progress" message will appear on the Sansa Clip's display screen. The device will turn itself off after the firmware is updated.
Additional Help:
Sansa Clip Manual Guide.
If you need any Further Help Just don't Hesitate Asking me.
Thank You For Using Fixya.
Good Luck.
Nov 03, 2009 | SanDisk Sansa Clip MP3 Player
May 11, 2009 | SanDisk Sansa Clip MP3 Player
Apr 10, 2009 | SanDisk Sansa Clip MP3 Player
I was charging my sansa mp3 player and now it does not work!!!!!!
the problem is when the computer freezes it sometimes can wipe the hard drive and can damage the mp3 player for good thus freezing it from turning it on and clearing the memory and thats it
Dec 27, 2008 | SanDisk Sansa Clip MP3 Player
My Sansa clip player was hang & shutdown, its not working right now what i do?
Your Clip never turns on at all? Even when you plug it into the computer?
Oct 04, 2008 | SanDisk Sansa Clip MP3 Player
Won't turn on
What you need to do is first make sure that you are safely disconnecting your sansa clip and not just taking it off the computer. Second you may have a virus in your sansa clip I would prefer you call Technical Support for Sansa clips, the number is 1-866-726-3475, they are open 4am-10pm PST
or 7am-1am EST. Hope this helps
Sep 07, 2008 | SanDisk Sansa Clip MP3 Player
Sansa clip not coming on
try turning it o while its on the computer
May 30, 2008 | SanDisk Sansa Clip MP3 Player
Sansa Clip not turning on
Get the latest firmware for the player - should solve the problem (may require a restart of your computer after upgrading).
Apr 20, 2008 | SanDisk Sansa Clip MP3 Player
SanDisk Sansa Clip MP3 Player Logo
32 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
