Question about Water Dispensing & Filtration
How do i replace my in-line water filter? - Water Dispensing & Filtration
    New Friend:
  • 152 Answers
Here you go
http://www.youtube.com/watch?v=uyg8Vl3m9U0
Posted on Jan 16, 2013
  • justin Jan 16, 2013
    here you go
    http://www.youtube.com/watch?v=uyg8Vl3m9...
How to replace water filter Housing?
most of the time when you get a filter it has its own housing and they are and in the water line filter, just unscrew the water line and replace, just make sure the arrow is going in the right direction
Dec 02, 2015 | Samsung RF267AB (25.5 cu. ft.)...
Water coming out of fuel line after cleaning out fuel tank and replacing fuel filter
Take the fuel line off at the throttle body and at the filter, then blow the line out backwards-push all the water out of the lines.
Dec 12, 2013 | Ford F-250 Cars & Trucks
Frigidaier Side by side Fridge FRS23R4A water leaking from filter casing and no water to water dispensor
Cracked filter head our water line. Best bet is to pull filter head down and inspect water lines and head. Replace if needed
Aug 17, 2012 | Refrigerators
No water coming out of the dispenser
Hello there and welcome to fixya
Dispenser Does Not Operate
  • 1 Ensure that the water supply line is installed according to the manufacturer's directions. Turn the water supply shutoff valve counter-clockwise to fully open it.
  • 2 Replace the water filter or remove the filter and install the plug. A clogged filter will prevent the water dispenser from functioning properly.
  • 3 Place a large container under the water dispenser. Press and hold the dispenser lever for at least two minutes to remove air in the water system.
Does Not Dispense Water
  • 1 Inspect the supply line and shutoff valve for clogs. Call a plumber to remove clogs in the line or shutoff valve.
  • 2 Replace the water filter cartridge or remove the filter and install the plug.
  • 3 Ensure that the filter cartridge is installed properly. Remove it and reinstall the filter cartridge. The cartridge will lock into place when installed correctly.
Read more: Troubleshooting GE Refrigerator Water ' eHow.com http://www.ehow.com/how_7170675_troubleshooting-ge-refrigerator-water.html#ixzz1XoEkLTk8
Sep 13, 2011 | Refrigerators
Replaced DA29-00003B water filter in Samsung Refrigerator (RS2530BBP), with DA29-00003G filter. Water comes out extremely slowly....any suggestions? Tried holding ice type button for 3 seconds and...
Recheck you steps and see the warnings:
1) Turn on the main water supply & shut-off valve of the water
supply line.
2) Run water through the dispenser until the water runs clear
(6~7 minutes). This will clean the water supply system and
clear air from the lines.
3) Additional flushing may be required in some households.
4) Open the refrigerator door and check if water leaks around
the water filter.
Remove any residual matter inside the water supply line after installing filter.
NOTE :A newly-installed water filter cartridge may cause water to briefly
spurt from the dispenser.
Jun 04, 2011 | Samsung AquaPure DA2900003A Refrigerator...
Water dispensing problem.origional filter worked for 8 months. installed new filter unit worked properly for 1 month. replaced filter again filter unit worked for 3 days. replaced filter again. filter...
Is there a filter on the back of the refrigerator that the water line hooks to? I can't remember if all of them have one or not. It sounds like either your water line is clogged or the valve feeding the line might have been turned way down. I would turn the valve off, disconnect the hose from the refrigerator and put the end in a large bowl or bottle and have someone turn the water on to see if you have good flow through the line. Best of Luck
Mar 10, 2010 | LG LFX21971ST Stainless Steel Bottom...
Water problems
Hi. the first action is to check the water filter(If Equipped). Once a water filter reaches its filtering limit, it will stop the free flow of water immediately. This will require you to replace the filter asap, if needed. Once the filter is replaced, the water will flow freely once more. I would also advise to check the integrity of the lines. If the lines are frozen, this will cause a no-flow situation , as well. check to make sure that the lines are not frozen.
Ok, if the lines and filter are not the issue, kindly,proceed to the inspecting of the water inlet valve assembly.
The water inlet valve is located behind your refrigerator. Find the water supply line coming into the valve and turn it off at the source (typically under the sink, or behind the unit). Disconnect the supply line. Remove the screws that secure the inlet valve in place.
The water inlet valve is connected by two wires. Label the wire placement on the water inlet valve before disconnecting the wires. The wires are connected to the terminals with slip on connectors
Firmly pull the connectors off of the terminals (do not pull on the wire). You may need to use a pair of needle-nose pliers to remove the connectors. Inspect the connectors and the terminals for corrosion. If the connectors are corroded they should be replaced.
Inspect the filter screen where the supply line connects. Remove any debris or deposits that may have built up using a toothbrush, or warm running water. If you cannot clear the clog, it will be necessary to replace the valve (the filter is not removable on most inlet valves).
Test the water inlet valve for continuity using a multimeter. Set the multimeter to the ohms setting X100 (if available, otherwise use the nearest ohm setting). Place a probe on each terminal. The multimeter should display a reading of 200 to 500 ohms. Close inspection of the inlet valve and especially the coil may reveal the exact ohm resistance rating to test for. If the water inlet valve does not pass this test, it should be replaced.../
Nov 16, 2009 | Refrigerators
Water will not flow out of dispenser
This is common when the water filter needs to be replaced. GE recommends:
Water filter clogged. Replace filter cartridge or remove filter and install plug. Air may be trapped in the line: Press the dispenser arm for at least two minutes.
Dispenser is LOCKED. Press and hold the LOCK CONTROL pad for 3 seconds.
The water line may be turned off or disconnected.
Sep 07, 2009 | GE Refrigerators
Metallic tasting water from new water dispenser
Was the water filter also replaced. Was the water line replaced
Jul 12, 2009 | Refrigerators
I have a 2004 whirpool side by side refrigerator and i was wondering if ther is a way to increase the water volume at the water despencer?
The dispenser has a designed specification flow from the manufacturer. There are filters installed inside or outside of the unit. If the water flow appears to have decreased over the years, it may be 1 or all the filters that may nedd to be replaced. Check your user's manual to see what filters are installed as a servicable component, and replace them. An installer may have also placed an in-line filter on your water supply, so look for this also. The water supply line is only a 1/4 inch line, so anything larger than that in the line may be construed as a filter. All filters should be replace every 6 months at the least, unless their specifications say otherwise.
Dec 03, 2008 | Refrigerators
Water Dispensing & Filtration Logo
657 people viewed this question
Top Water Dispensing & Filtration Experts
ray gallant
Tom Chichester
Dwain Schmidt
Dwain Schmidt
Level 1 Expert
Are you a Water Dispensing and Filtration Expert? Answer questions, earn points and help others
