Question about Dell Inspiron Computers & Internet
When I boot My Dell Inspiron 531, it goes to a screen that says it can't find the Floppy Disk Drive, and says, at the bottom, to press F1 to reboot, or F2 to change the settings.
When I press "F1" it reboots with no problem. When I press "F2," it has a lot of settings. Not knowing the best settings, I chose default, and it still doesn't boot right.
    Scholar:
  • 144 Answers
Simply press F2 and the screen probably a blue color with lots of settings you are talking about is BIOS setup. In this setup find a tab named "Boot setting" or something similar and go inside this menu. You will find devices and look for floppy drive and set is "Disabled". Save and exit. Error will disappear.
Posted on Jan 16, 2013
  • Peter Shepherd
    Peter Shepherd Jan 16, 2013
    Thank you very much for your suggestion. I'll try it first thing in the morning when I get home.
5 Suggested Answers
  • 154 Answers
SOURCE: Reload now will not boot show F1 reboot or 2 setup
Since the hard drive was wiped, it's unlikely you will get the function keys to operate exactly as they did from the manufacturer without performing a re-install using Dell's proprietary installation discs.
If you want the pc to work exactly as it did before the discs were wiped, your best option is to order a set of backup discs directly from Dell.
The Dell online backup disc request form can be found at the following location. You will see a "Request Backup Disc" button toward the bottom of the page.
http://support.dell.com/support/topics/global.aspx/support/dsn/document?c=us&l=en&s=gen&docid=3A1C590C9132AB20E040A68F5B28350B&journalid=72452E05A7CD7622E040AE0AB5E15C37&Query=&SystemID=&ServiceTag=&contenttype=&os=&component=&lang=&doclang=&toggle=&dl=
Before you order the discs, you will need to call Dell's customer support number at 1-866-234-9297 to have the ownership information changed.
If you feel this information is helpful to you, please take a few minutes to rate this response.
Posted on Aug 29, 2009
  • 115 Answers
SOURCE: dell optiplex gx 240 cannot boot from CD rom every
at the same time goto set up screen by pressing f2 and then change the boot sequence as cd drive to be first boot device and then try to boot from cd and as soon as you restrt and after dell logo it giuves you a message press any key to boot from cd at the same time press space bar be very quick as you have only 2 seconds to press the key or it wont boot if that does not work then the problem is with the cd drive.
Posted on Oct 27, 2009
gotgeek2
  • 565 Answers
SOURCE: Turn on my computer Inspiron 530S starts to boot
Sounds like someone may have left a non-bootable floppy disk in the drive. Check to be sure there isn't a floppy in the drive. Also, when in setup, it's the boot order that you'll want to change.
Posted on Nov 27, 2010
ceo007m
  • 49 Answers
SOURCE: On the Boot-up screen I get the message: "Diskette
I think you should press F2 to go to the setup page.
There, you should change the order of your boot device.
set the first boot device to hard disk
set the second boot device to cd rom
and the third to floppy.
follow the instructions and click save and continue
Posted on Dec 22, 2010
Boot up problem with Dell Precision 380 P4 Dual Core 3 GHz
Your computer is trying to boot from a floppy drive. Do you even have one? If not, then you need to go into the BIOS (set-up) menu and disable it. Be careful though, you could loose all your data on the computer if you make a wrong selection. As for an array message, you must have have a RAID disk configuration. That means you have 2 or more disk drives that mirror each other.
Mar 17, 2013 | Dell Precision 380 P4 Dual Core 3 GHz...
Computer won't boot error code sata disk s/n 0F00-136B and many more???
looks like hardware failure.
find out what harddisk exactly you do have in the bios :
- press Del or F1 or F2 during booting, goto IDE devices, look for the model, size (in GB) etc.,
write down (the manufacturer could be: samsung, seagate, maxtor, fujitsu...)
- then change order of boot devices so that cd/dvd-rom drive and /or 3,5 '' floppy drive boots
before the harddisk, exit saving changes (F10 or Esc)
- then get diagnosis program from the harddisk manufacturer's homepage,
copy that to a bootable floppy disk or burn it to a cd-r/cd-rw which must be bootable
- boot from the cd or floppy, run diagnosis tool, both short and long test, what does it say then?
- if hardformat is available, perform one
- might work now, at least the hd will be recognized
-setup new windows installation.
have fun
Source : STAT DISK S/N 0F00-136B
Aug 16, 2012 | Dell Computers & Internet
My inspiron 531 says no boot device available
Computer is not configured to boot from your hard disk drive (SATA 0),
you need to go into the BIOS (set-up) menu and make that drive the fisrt boot device.
Feb 15, 2012 | Dell Inspiron 531s Desktop Computer
Dec 22, 2010 | Dell Inspiron 530 Desktop Computer
Turn on my computer Inspiron 530S starts to boot up gives the dell booting page then goes to 0 Diskette error choose F1 to continue and F2 to start setup. I have tried F2 and change it to no floppy disk...
Nov 27, 2010 | Dell Inspiron 530s Desktop Computer
On startup a black screen with message "diskette drive seek failure" what does it mean? Then it says press F1 to continue or F2 to enter setup. I always press F1 and it starts up ok. this has only just...
This indicates that your computer is configured to boot on the floppy drive.
1. At the start of the computer Press F2
2. Go to the Boot Device Configuration.
3. Enable Hard Disk Boot Priority.
4. Set the First Boot Priority to Hard Disk
5. Save and Exit.
Please let me know of the outcome. Thank you and regards.
Aug 28, 2010 | Dell Inspiron 530 Desktop Computer
Show a blue screen
You need to go into the Setup Utility or BIOS when the computer boots. You need to enable the computer to boot from the CD drive, and set up boot priority with CD Drive first, then Hard Drive HDD.
Then it will boot the disc.
Dec 17, 2009 | Dell Inspiron 531 Athlon 64 X2 4400+...
Can't factory restore dell inspiron 531 (windows xp).
You might want to try going into setup and setting your boot drive options to DVD drive as your 1st, HD as 2nd and Floppy as 3rd. Put your windows disk in the DVD before boot and run the program from DVD.
Jun 23, 2009 | Dell Inspiron 531s Desktop Computer
Dell Inspiron 531s Windows Vista
If you are given the option to go into the setup (F2) try to disable the floppy disk drive or move the hard drive up in the boot order.
Feb 21, 2009 | Dell Inspiron 531s Desktop Computer
Computer looking for a non-exsistant drive
Hi, the reason why you are getting the message is because the bios is set to seek the floppy disk and the setting is enabled and to resolve that you just need to disable the option on the bios
Entering the System Setup Program
  1. Turn on (or restart) your computer.
  2. When the DELL™ logo appears, press <F2> immediately.
  3. If you wait too long and the operating system logo appears, continue to wait until you see the Microsoft® Windows® desktop. Then, shut down your computer and try again.
Set the boot order to boot to the hard drive
And for the complete manual please visit http://support.dell.com/support/edocs/systems/xlob/dtg/en/systemse.htm#wp1211060
Jan 29, 2009 | Dell Inspiron 530 Desktop Computer
Computers & Internet Logo
mukhtar21 shaikh
mukhtar21 shaikh
