Question about Sharp AR-5316 Advanced Digital Imager Copier
Error code 4h ar 5520 sharp fotocopy all button are not respons
SOURCE: error code 4H on sharp ar 5316
WHEN THE SHARP AR-5316 PHOTOCOPIER IS SWITCHED ON THE ERROR CODE 4H APPEARSAND THE MACHINE CANNOT BE OPERATED. IHAVE TRIED THE SOLUTION SUGGESTED JUNE THIS YEAR BUT IT DID NOT WORK. WHAT CAN I DO TO GET THE MACHINE TO WORK? IT IS VERY URGENT.
Posted on Jan 07, 2009
  • 3 Answers
SOURCE: error h4
it is on you fusing unit of your copier, check the fuse maybe it is open already and need for replacement... H4 means that your heater lamp is not functioning
franklin
Posted on Feb 03, 2009
  • 26 Answers
SOURCE: sharp ar 5520 fault code
F2 40 = ATC sensor abnormality
Check e remedy :
Remove/Install the toner cartridge again.
Replace the toner cartridge with a normal one.
Posted on Sep 07, 2010
rezazadeh
  • 328 Answers
SOURCE: i have 4H Error in my SHARP AR-5516N.Please give
iput code (# interrupt C interrupt) led turns off .input 14 press copy
Posted on May 30, 2010
  • 255 Answers
SOURCE: Get F2-40 error on sharp ar-5520 Im a newbie in
How are you , this problem occurs when there is very low toner concentration on the unit or low developer.
solution
  1. Replace a toner cartridge and make sure it is smoothly running as some come with hardened toner or
  2. Replace a new developer which is Sharp Ar 205 dv Check that the toner motor is rotating well
This error is self resetting so no need of simulation code. Bye.
Posted on Oct 23, 2010
HOW TO FIX ERROR CODE 444 BLINKING FOR SHARP AR-5516?
http://www.sharpmea.com/cps/rde/xbcr/documents/documents/om/34_ppc/AR5516-D-5520-D_OM_GB.pdf
May 20, 2014 | Sharp AR-5320 Black and White Copier
solution
Oct 21, 2010 | Sharp AR-5316 Advanced Digital Imager...
Sharp ar 5516 printers error h5. h4
hi,I have error code L h on my coppier sharp 5516. your help please.
Aug 05, 2010 | Sharp AR-5316 Advanced Digital Imager...
F2 40 error code on Sharp 5516s copier
you must use ar-202 developer.205sd used for 5516 or 5520
May 23, 2010 | Sharp AR-5320 Black and White Copier
My sharp copier AR-5316 has the problem. Error code 4H appear and cannot copy.
Hello sir; You need to do a reset procedure as follow; Press "#", "interupt", "C", " interupt". then enter 14 press start, machine go back to normal.
Oct 09, 2009 | Sharp AR-5316 Advanced Digital Imager...
Code H4 comes up when the sharp copier ar-5316 is switched on. it cannot be use. what shall I do to solve this problem of error code H4.
Hello sir; H4 code require reset procedure as follow;
1, press"#" "interupt" "c" "interupt" these 4 keys.
2, enter 14 , then press start
3, turn power off and back on .
Jan 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
Lost key operator code for Sharp Copier AR-M207.
The default is 00000
Simulation 22 - 07 will display the Key operator code.
Perform the following procedure to enter the simulation mode.
"#" key -> “*“ (star) key -> "C" key -> “*“ (star) key (do this in quick sequence order, the display should change, then enter below)
Main code {22} ->
(Green Copy Button) Start key ->
Sub code {07} ->
(Green Copy Button)Start key
Press the "CA" button to go back to Copy mode.
Jan 24, 2009 | Sharp AR-M237 Copier
Error code 4H
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Apr 15, 2008 | Sharp AR-5316 Advanced Digital Imager...
Error code 4H on sharp ar 5316
Feb 18, 2008 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-5316 Advanced Digital Imager Copier Logo
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
