Question about GE GBS18HBM Bottom Freezer Refrigerator
Freezer works but refregerator is warm
I have a GE refrigerator with freezer on the bottom.Model GBS18HBMBWW,Serial is SD902730V.The refr.Section does not cool but the freezer section section still freezes.I do not hear or feel a evap fan running.We would like to get to the fan but can not figure out how.Would you please help.Thanks Ernie
  • erniecarrier Jan 27, 2009
    Thanks for your help but not knowing how to get to the vent my son called a service tech and he found just what you said it was a broken part of the vent system that was blocking the air from moving and then freezing the evap coil.Thank for help
  • Anonymous Mar 07, 2009
    refrigerator is 52/freezer is 18.
  • 979 Answers
If this is the model I am thinking about, you have the same compressor for each side. There should be a vent or opening that you can adjust to let cool air inside the refrigerator. Find it and adjust. You may have this opening blocked by something. Let me know if this fixes the problem.
Posted on Jan 24, 2009
12-14 yr old ge bottom freezer. freezer is working, fridge is warm.
not all refrigerators are the same can you look inside the fresh food section around the door or on the back of the refrigerator and provide a model number?
Appliance 911 Sea Breeze
Sep 30, 2015 | GE Refrigerators
GE Profile, bottom, freezer Freezer does not stay at 0 degrees. With uses during the day it gets up to 20 degrees. Ice cream does not stay frozen. This happens mostly in the summer. Once it get cold...
most refregerator..usually open the door at day time..so it will not keep on required temperature o degreefrequent opening refrigerator,must be adjust the thermostat to higher setting..
Jul 11, 2011 | GE Refrigerators
I have a GE refrigerator GFSS6KKYSS Model. Serial #: LS900091 It appears that there is ice on the back of the refrigerator and water is collecting on the floor of the compartment. What is the problem and...
This is a rather unique refrigerator in that there is a seperate evaportator (cooling coil) for the refrigerator section and the freezer section, where as almost all other refrigerators only have coils in the freezer section and use a fan to blow some of the cold air into the refrigerator section. This design will prevent cross contamination of odors between fresh foods and freezer sections, and allow lower humidity freezer at the same time as higher humidity fresh foods. All good things.
That said,..... you need to take the cover off the back wall from inside the fresh foods section and thaw out the defrost drain locted at the bottom of those cooling coils. If I remember correctly, there are a couple hidden screws, and the back panel needs to be pryed off using a putty knife, I think you will find 4 small arrows / pointers for the spots to pry at. With cover removed, use a turkey baster with warm water until the water flows out the drain.
Apr 03, 2011 | GE GFSS6KKYSS
GE Model TBX18JISERWH This refrigerator is a freezer on top/refr on bottom.....the problem is that the freezer section is working fine,but the refrig isn't cooling enough. The temo gets up to 48/49...
Sorry to hear about your problem. Sounds like you have a defrost issue. Hence your unit is not defrosting. All of this apply's if your freezer side has ice or is cold . If not. you have other issues, this does sound funny, but this is why your refrigerator side is warm, or not cooling.
Here is a list of some things that can go wrong.
1. Defective heat coil
2. Defective defrost timer
3. Defective defrost sensor
4. Defective Fan
5. Defective compartment inlet damper (on some models)
You should call a service company to resolve your issue.
Since I tried to help you, Please help me and Rate/Vote on the response. Thanks
Dec 29, 2010 | Refrigerators
Whirlpool Model # GB2SHTXTS00 refrigerator not cooling. it has bottom freezer...coils in the freezer are icing up... I checked the heater, and stat ohmed ok.i ran the service test everything appeared...
Sounds like the defrost timer is not tracking the time properly. The unit needs to defrost once every 6-8 hrs. in order to work. Make sure the inside (evaporator) fan is running ok. If it rund for a few days and then warms up in the refrigerator section (coil iced), then the defrost timer is the culprit.
May 28, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
GE side by side refrigerator and freezer not working
Time to unplug the refrigerator. We need to check the compressor, start capacitor and start relay. If you do not unplug until we solve the problem the internal overload inside the compressor will be damaged. I am ready to help you on this just let me know, Sea Breeze
May 20, 2009 | GE Refrigerators
Bottom Freezer
This is the way it is supposed to work. Modern refregerators are designed to keep the freezer temp between 0 - 10 degrees. As long as it is not freezing food in the refrigerator compartment all is well. On most units the only real cooling control is in the refregerator. This is the one the cycles the compressor. The freezer control usually only controls the amount of cold air allowed into the fridge. All cooling coils are usually in the freezer. it just pushes cold air into the fridge
Jul 04, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Ge profile leaks from front of freezer
your drain will be plugged under the tray. there is a hose that runs to the drip tray. the back cover comes off you can then get at the hose
Sep 05, 2007 | GE GSS25JEMWW Side by Side
GE GBS18HBM Bottom Freezer Refrigerator Logo
241 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
RepairNinja
RepairNinja
