Compaq pressario whenI turn it on, monitor goes immediately to power saver mode and I can't get it to work
  • 33 Answers
Sound like maybe video card has gone bad. You can get a cheapo video card at your local pc guys for around 20-30 bucks. If you install the card and hook up cable it will override the bad card (might be on motherboard) and should work
Posted on Jan 24, 2009
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Why no video
a HP monitor. as old as 2006... (o0ps)
read the manual yet? on "power saver modes" turn off them?
i bet you dont know spec, on caps. it's not published by HP ever.
most are +80% - 20% for filters. (ever seen that?)
so a 100uf can read 180uF, or 80uf and is IN SPEC.
but no caps stated, by you, lots there are...
my guess you are
looking for the caps used in china long ago that all failed, every one.
first off you never fully stated whats wrong, in DETAILS.
first have good running pc , with live VGA output (using VGA are you)>? unstated...
the MON, will now live sync, now , Horz and vert, on both pins
the OSD screen now works, if not the monitor is bad.?
or see No/syn, no sig, out of range or no input errors.
Monitor Going to Sleep
see page 34? in your manual yet?
and page 31, turn of power saver ?
if OSD is dead, say so first.
OSD can be locked. push mon menu button for 10sec, now unlocked
then go to OSD screen
http://h10032.www1.hp.com/ctg/Manual/c00834092
Power-Saver Feature
When the monitor is in normal operating mode, the Power li
ght is aqua-white or green (depending on model) and the
monitor uses the normal watts of power. For power us
age, refer to "Technical Specifications" (Appendix B).
The monitor also supports a power-saver mode that is
controlled by the computer. When the monitor is in the
reduced-power state, the monitor screen is
blank, the backlight is off, and the
Power light is amber. The monitor uses
minimum power. When the monitor is "awakened," a brief
warm-up period occurs before the monitor returns to
normal operating mode. The energy-saving reduced power stat
e activates if the monitor does not detect either the
horizontal sync signal or the vertical sync signal. The powe
r-saver feature must be activated on your computer for this
feature to work, << read that carefully?
turn this off ? first?
osd-vboix4tqi2kfzapulla5cn4x-5-0.jpg the early models of the monitor
had CCFL back lamps, and the 2 inverters are on the main power board. left side here
http://i.ebayimg.com/images/g/2-wAAOSwzSRZxoWH/s-l1600.jpg
Sep 28, 2017 | HP Compaq WF1907 19" LCD Monitor
WhenI turn my monitor on, a screen appears saying VGA input - no signal & DVI input - no siganl & then it goes to sleep
Do you have multiple Video cards installed in your computer?
Check the monitor on another computer to verify the Monitor works and so does the cable.
If Monitor works, cable works, and you have 1 video output from your computer, then your Video card is probably no good.
Jan 26, 2010 | Compaq fs740 17" CRT Monitor
LG 1750s monitor goes into power saver mode in 5-10 min
change the setting in the screen saver option (Power)
or look in Power in control panel...also check the hybernation time
Dec 18, 2009 | LG Flatron L1750S 17" LCD Monitor
Monitor goes into power saving mode. How do I
Go to desktop properties>screen saver option>power option & select the turn off monitor never.
Oct 15, 2009 | LG Flatron L1718S LCD Monitor
When PC is not used, screen goes black, then Check Signal Cable
right click on your desktop.go to properties.in properties go to the screen saver tab.click on the screen saver tab.under the screen saver tab you will a tab called power.click on power.change you monitor settings there.let me know if it works
Sep 07, 2009 | Computers & Internet
Compaq w17q monitor keeps going on and off how can i fix it?
1. check the power cords- make sure all are snug.
2. check and make sure no pins are bent in the cord to the computer
3. make sure that the monitor is not in auto-power save. Or in auto off mode. For example- is the light amber or green.
4. finally, make sure that your settings on your computer are not set to power off your monitor- as in a blank screen saver, power save or hibernate
Mar 26, 2009 | HP Compaq W17q Monitor
Compaq pressario
Techguru2009: First thing disconnect the monitor and start your computer. Then connect the monitor, can you see your operating system? You need to check your bios settings for power save mode. you might need to reset the bios. You can open your case and remove the battery for ten minutes or if you can load the bios setup reset the default settings. Hope this helps.
Jan 24, 2009 | Computers & Internet
Monitor in power saver mode
try to restart your computer in safe mode and see if that affect the monitor, also you may have the setting to go into hybernation quicker, to save the most energy, check those settings
Jun 06, 2008 | Computers & Internet
Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Jan 28, 2008 | LG Flatron L1710M 17" LCD Monitor
Computers & Internet Logo
65 people viewed this question
David Payne
David Payne
