Question about SanDisk Sansa m240 MP3 Player
Does not show songs that were previously synced
I got my Sansa 2GB couple of years back and used to sync it via computer running on windows XP. Everything seemed to run smoothly until couple of months ago when i added 2gb micro sd card. I tried to search for the old songs that i had uploaded to the sansa hard drive and it does not show on the any folders. I can however see the new songs that i have uploaded. i cannot delete the old songs as it does not show up on any folders; however it shows up on the MP3 while i play it.
Please help
  • 2 more comments
  • rrkunwar79 Jan 24, 2009
    Hi coolguyrocks,
    thanks for the suggestion, i do have WMP v11. I have always set my sansa c250 USB mode on MSC ever since i got my new system with windows vista and yet it does not retrieve the old songs that i had uploaded. i even tried using my buddys system that has windows xp to see if i could retrieve those old songs from the sansa hard drive but it did not work. Still stuck with figuring out why i cannot view those old MP3 files.
    yes i did remove the SD card and connected it to my computer and tried locating the old files via WMP but i can't find it. thanks anyway.
    Thank You very much this worked out perfectly for me although i had to use my buddy's system that had windows XP, does not quite work the same way with windows vista once you get to step vi. None the less i managed to recover all the old files. Appreciate your help!! thanks a lot/\.
  • tom sh Jan 25, 2009
    My Sandisk m240 does not show songs that were previously synced to the player.
    Scholar:
  • 51 Answers
1. Make sure you Windows Media Player 11 (Goto Help --> About WMP --> v??) 2. If you do not have it, install it from this location: http://www.microsoft.com/mediaplayer  3. Change the Mode on Device: Go into Menu --> Settings --> USB Mode:Auto Detect/MTP/MSC  4. Select MSC and it should work. If it does not try Powercycling your device (turn it off and then turn it on). 5. Try other modes as well.
Posted on Jan 24, 2009
  • 1 more comment
  • Sagayaraj Arulanandu Jan 24, 2009
    HI,
    Did you try removing the SD card and then connecting the device? I believe you are trying to view the tracks in My Computer. Did you try to view them in Windows Media Player?
    Keep the device in AutoDetect Mode and follow the instructions below:
    i. Connect your Device
    ii. Right click on My Computer and select Manage
    iii. Select Device Manager
    iv. At the right hand side look out for Portable devices and click on the + symbol to display your device
    v. Right Click on the device and select Update Drivers
    vi. Select 'No, not at this time' and click Next
    vii. Select 'Install from a list or specific location' and then click Next
    viii. Select 'Don't search, I'll choose the driver to install' and then click Next
    ix. Select 'MTP Device' and then click Next. This should install the device and then should be ready for use.
    Keep the device in AutoDetect Mode and follow the instructions below (for Vista):
    vi. Select 'Browse my computer for driver software' and then click Next
    vii. Select 'Let me pick from a list...' and then click Next,
    viii. Select 'MTP device (or you may/not have WPD Device)' and then click Next to install it. Hope you have it now in your Vista as well.
How to delete songs
There's no way of directly deleting a song on the player. You need to do it either via Windows Explorer, or a music manager program which "syncs" to your player.
To delete a song via Windows Explorer, connect your Sansa to your PC, open up "My Computer" (or "Computer" if you're running Vista), and you should see your Sansa listed there. Double-click on it. If you then see "Internal Memory", double-click on that. You should then see a list of folders including "Music". Double-click on that, and you should see a list of songs. If you see a list of folders named after your Artists, double-click on the appropriate Artist folders to find the songs you want to delete. Select the song(s) and press "delete" on your keyboard.
If you use a music manager program such as Windows Media Player, Media Monkey or Winamp to sync music onto your Sansa, just delete the song from the music manager library or playlist(s) you're syncing to your Sansa, then do another sync.
Feb 17, 2010 | SanDisk Sansa e200 MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
Hello i have a sansa clip 2gb and the music is showing up when i check the files but does not on the clip itself. it says "No song" I know i added the songs on there. can you help me?
try using windows media player to transfer the music...here's how 1.Update WMP to version 10 or 11 2.goto sync tab and yoyc player must be detected. 3.create a playlist of songs you want to transfer 4.click on start sync to transfer music to your player.
Sep 03, 2009 | SanDisk Sansa Clip MP3 Player
My Sansa e250 won't stay connected or sync
haha your welcome. good luck with your mp3 player in the future!
Dec 26, 2008 | SanDisk Sansa e250 MP3 Player
Sansa Clip 2GB...WMP11 will recognize, but will not list in device pane in Sync mode...
Hah, figured it out! Had to roll back my version of WMP, which can simply be done by (in XP) going to Start > Control Panel > Add Remove Programs, and then click on WMP11 in the program list. Click remove, and it will ask if you want to roll back to the previous version of Windows. Click yes, and it will roll it back to the previous version of WMP11. Now, assuming you have an active internet connection, after you restart your computer, it will ask if you want to update your WMP. Click yes, and it will re-install the version you started out with, replacing drivers, .dlls, and anything you were missing before hand. Long story short, the solution was patching the holes in the program. I can now plug my Sansa Clip 2GB into the USB port, and WMP will recognize it right away (I can almost hear a small voice from inside my computer saying "would you like tea with that, mr. guy?" hah). I also found out you can have more than one media player connected at the same time! How cool is that? Great if you're trying to set up multiple players with the same playlists (promotional type stuff, business type stuff, etc.).
Aug 06, 2008 | SanDisk Sansa Clip MP3 Player
Cant download music
The songs need to be formatted for a sansa. Use Windows Media Player 11. Don't use Rhapsody, too many problems.
Load a CD into your computer, on the Toolbar of WMP11 click rip, After all songs are ripped, hook up your Sansa to the computer via USB cable, Click Sync. WMP11 will not only sync the sansa it will sync the micro card also. You have your choice where you want to put the music. Drag and drop the music in the box to the left where you synced your sansa and at the bottom of the box click Sync. All music will be synced to your sansa or card which ever one you chose. Understand, when the sansa starts up, the card syncs with the sansa, you don't have to do anything. Try this and let me know how it works.
Mar 24, 2008 | SanDisk Sansa e260 MP3 Player
Songs will not show up in the mp3 player!
something is wrong with the format of the new songs
Feb 19, 2008 | SanDisk Sansa e260 MP3 Player
Adding music to my sansa e250
you must use windows media player 10 or 11 to sync songs into the sansa. Make sure you sync it this way or else your songs will not go in properly.
Jan 21, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 using micro sd card
Go to the knowledge base on the Sansa site and find this (chances are you have an SDHC card in an incompatible unit):
Sansa e200
 - verify the version of the player.  To check, go to SETTINGS > INFO
For 01.xx.xx firmware (e200 version 1) - up to 2GB microSD cards
For 03.xx.xx firmware (e200 version 2) - up to 16GB microSDHC cards
NOTE: Firmware is not interchangeable.
Sansa e200R - up to 2GB microSD cards
Sansa e100 - supports SD cards up to 2GB
Nov 12, 2007 | SanDisk Sansa e250 MP3 Player
Sync to player and memory card without duplicates
I got this from:http://www.livedigitally.com/2005/06/27/sandisk-sansa-e130-the-micro-version-of-the-ipod-mini/ Create two playlists with names such as 1. SANSA Internal and 2. SANSA 2GB (assuming your SD card is 2gb). Load songs into each playlist. Edit the sync properties for each drive to only sycn to those playlists. Sync!
Feb 08, 2007 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa m240 MP3 Player Logo
121 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Computer Repairing
Computer Repairing
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
