Question about Nortel IP Phone 1140E NTYS05
I need to reset the Nortel IP Phone 1140E NTYS05
All the informatiom regarding ip, tn number and all the other details which is used to configuru the nortel is given wrong. so i need to reset all these things and to make the nortel fresh. contact no. 9790901664
Mouline
  • 3 Answers
SOURCE: Problem with IP phone Nortel 1120E
Try to reset the bandwith of the phone by using the nortel software.
Posted on Jul 12, 2007
SOURCE: i have nortel phone ip
1. Reset the phone by disconnecting and re-connecting power.
2. When the Nortel logo appears, press each of the four soft keys in sequence.
3. If no other configuration changes are required, press OK repeatedly until the “PC
Port? 1-ON 0-0FF
” option appears.
4. Press 1 to enable the PC Port or 0 to disable the PC Port.
5. Select OK to confirm the change.
6. Restart the IP Phone.
When the IP Phone is restarted, the firmware sets the PC Port status accordingly
Posted on Nov 09, 2008
SOURCE: Nortel 1140E IP Phone, Expansion Module 1100 series not working
If you're running on a hosted PBX, the expansion module will not work. It only works on premis based systems.
Posted on Mar 24, 2009
  • 8 Answers
SOURCE: reset a 1140E IP Phone
If you are running C6E or later firmware, then the following keypad sequence is used to reset all provisioning paramaters to a "factory default":
[*][*][7][3][6][3][9][MAC][#][#]
Where MAC corresponds to the MAC address of the IP Phone which can be found on a label on the back of the IP Phone.
Since a MAC address can contain the letters A-F, then letters A/B/C can be entered via the [2] key on the dialpad, and letters D/E/F can be entered via the [3] key.
For example, an IP Phone with MAC address 00:19:E1:E2:17:12 would be reset to "factory default" when the sequence **73639001931321712## is entered on the keypad.
Posted on Jun 26, 2009
Imsian
  • 97 Answers
SOURCE: Nortel IP soft phone 2050 shows the licensing
hello,
you can downgrade to an earlier version that doesn't require a liscense. you probably know that.Try upgrading to the latest (3.02.0045) version.
Hope this will help
Posted on Sep 22, 2009
NORTEL IP 1140E + BT 2 WIRE ROUTER.
Try a different phone on the same router, does that fix it?
Dec 20, 2013 | Nortel 1140E
Can two way speakerphone be disabled on a 1140E?
Yes - download the opperator manual from net at
http://www.nd.gov/itd/files/services/voice/1140e-user-guide.pdf
You can use the mute feature to block 2 way speech
Jul 05, 2012 | Nortel Avaya / Ip Phone 1140e - Ntys05bce6
Reset a 1140E IP Phone
Apr 08, 2009 | Nortel 1140E
Cannot activate light on feature keys display
You need to use an AC power supply on the base IP Phone 1140E for the backlight on the Expansion Module to work.
Dec 18, 2008 | Nortel 1140E
is it a bcm 50?bcm 50 must be version 3.0 release for module to work.
Dec 09, 2008 | Nortel 1140E
I have nortel phone ip 2002 i want use for my own carrier i need to reset
Port? 1-ON 0-0FF
” option appears.
Apr 20, 2008 | Nortel 1140E
1140E phone upgrade
C1B is ancient UNIStim firmware. You cannot downgrade to it. Try converting to a more recent UNIStim version. You can download firmware from www.nortel.com/support.
Mar 17, 2008 | Nortel 1140E
Nortel IP Phones I2004 and 1140e lose connectivity
here you are...
This could be the problem with your signaling server , have you checked it ??
I think it is losing connectivity of T-Lan Network.
Jan 10, 2008 | Nortel 1140E
Starting DHCP screen won't clear
Try using 26567*738 as the default password for the 1120E and 1140E IP phones.
Nov 30, 2007 | Nortel 1140E
1140E Problem
Is it the only IP phone? Howstable is the network?
Nov 22, 2007 | Nortel 1140E
Nortel IP Phone 1140E NTYS05 Logo
243 people viewed this question
Top Nortel Computers & Internet Experts
Jax Planet
Jax Planet
kwiz
Level 1 Expert
Are you a Nortel Computer and Internet Expert? Answer questions, earn points and help others
