Question about Canon CanoScan 8000F Flatbed Scanner
Is my canoscan 8000f vista compatable On the site of canon they state that the same driver can be used as for Windows XP. This is not true. Untill now, I found no way to get it working again.
  • francois711 Mar 12, 2009
    My scanner is not working with Windows Vista
    Sergeant:
    Champion:
  • 259 Answers
You may have to install or update drivers Most of the drivers/software I get are from a web site driverguide.com you need to fill out a free registration then search for the driver you need download it in a format you can use install it and then most times reboot the computer
Posted on Jan 24, 2009
CanoScan 8000F Installation for Windows 8.1
Unfortunately, the Canon 8000F is not compatible with Windows 8.1. You can find this at http://www.microsoft.com/en-us/windows/compatibility/CompatCenter/ProductViewerWithDefaultFilters?TempOsid=Windows%208.1&Locale=en-us&Architecture=X64&TextSearch=CanoScan%2B8000F&Type=Both&CurrentPage=0&TotalPages=1&ShowCriteria=0&SortCriteria=Relevance&Compatibility=Unknown&LastRequested=14. Canon choose not to write a Windows 8 or 8.1 driver for this scanner. The changes between Windows 7 and 8 mean that the old driver won't work. The compatibility mode doesn't help in this case.
You have two choices: The cheapest option (if you buy a used machine): You can get a second computer with Windows 7 or an older version of Windows installed that does support the Canon 8000F. Alternatively, with a computer with more than 4GB of memory and a CPU that supports can support a virtual OS to buy 1) an upgrade to Windows 8.1 Pro and 2) a Windows 7 license and DVD. (This will cost at around $200 for Windows 7 Home Premium and the upgrade.) Then you can add the Hyper V feature and install Windows 7 as a virtual OS with at least 2 GB of your memory assigned to virtual OS. Install the scanner in that virtual computer.
I hope this helps.
Mar 06, 2014 | Canon CanoScan 8000F Flatbed Scanner
I want to install the CanoScan Lide30/N1240U but there is no driver for Windows7. So it looks like I cannot use the scanner anymore. Is there anyone who knows a solution?
Go to site
http://software.canon-europe.com/products/0000466.asp
and select OS as Vista and language as English and press submit
and download windows vista drivers.
you can use Vista driver in Windows 7 using Compatability Mode.
Step required..
1. Right click on driver installation file.
2. choose properties
3. choose compatability tab
4. select Vista
5. press ok
6. Install the driver
I hope it will help you.
Thanks for using FixYa.
May 23, 2011 | Canon CanoScan LiDE 30/N1240U
CS4 is not detecting WIA device or the Twain driver. I have down loaded the latest canon driver and installed it several times and the system will not connect the two programs. I am using Windows 7...
The Canon software that you downloaded is for Win7 32-bit. Canon does not support this scanner on 64-bit OS versions. With Canon, I've found that the compatibility mode does not work.
A method that will work is to use a computer (virtual, dual-boot, or true second machine) with an older version of Windows installed. If you have Win7 Pro or Ultimate (or upgrade to them), you can create a virtual XP computer for free. Download and install Virtual PC and XP mode from Microsoft. Install them in order. Then install the XP software from the above site in the virtual computer and it will work. (Other virtual computer programs are Parallels and VMWare.) All of the other options will require a licensed version of the older Windows OS. Please note that the virtual computer can't share files directly with the main computer. You'll need to save files to external or removable media (optical media or flash drive, for example) to share them.
I hope this helps.
Apr 14, 2011 | Canon CanoScan 8000F Flatbed Scanner
I have a canoscan 8000f and I cannot get the negative scanner to work on windows vista
Here is the link to Canon Official Support site. You can download Vista Drivers for Canon CanoScan 8000F Flatbed Scanner
GoodLuck!
Dont forget to rate the solution if I could have been of any help!
CreativeTECH
Dec 04, 2010 | Canon CanoScan 8000F Flatbed Scanner
Hi, I have windows 7 64bit and windows vista 64bit. I cannot find drivers for my canon canoscan 8000f. thanks
you may download from "http://support-in.canon-asia.com/P/search?category=Scanners&series=CanoScan&model=CanoScan+8000F&menu=download&filter=0"
Aug 17, 2010 | Canon CanoScan 8000F Flatbed Scanner
Need drivers
there is no driver yet for windows 7.but download scan gear and scan gear toolbox from here:http://software.canon-europe.com/products/0000473.asp  open properties,compatibility and run it in compatibility mode for xp sp2
Feb 28, 2010 | Canon CanoScan N650U Flatbed Scanner
CANOSCAN D646U NOT HAVE DRIVER FOR WIDNOWS VISTA
Try to run windows vista in compatibility mode. If you can't find the driver for it, even under driverguide.com, this is about the only other thing you can try.
Aug 09, 2009 | Canon CanoScan D646U Flatbed Scanner
CanoScan N1220U
It will with the program from the link below.
http://windows-vista-updates.blogspot.com/2007/05/canon-scanner-drivers-for-windows-vista.html
Jul 12, 2008 | Canon CanoScan N1220U Flatbed Scanner
I need driver for Cannon 8000 scaner
You can try here for your drivers.
http://www.usa.canon.com/consumer/controller?act=SupportIndexAct
Or if that fails most the time you can go here.
www.driverguide.com
They have a huge selection of drivers, and registration is free.
Hope this helps. M~
May 01, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Canoscan 4200f Problem with Vista 32 bit
I got mine working after experiencing the same problem.
I had mine hooked up to a USB hub, after I hooked it directly to the USB ports in the back of my computer, everything just worked fine.
Weird that it worked on the USB hub on XP and not vista though.
Dec 31, 2007 | Canon CanoScan 4200F Flatbed Scanner
Canon CanoScan 8000F Flatbed Scanner Logo
383 people viewed this question
old marine
old marine
