Question about Drywall
What are the 5 functions of a 5-in-1 tool? - Drywall
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
Scraping with the flat edge, spreading putty with the flat edge, chisel/drywall cutter with pointy edge, pick with pointy edge (to open a paint can, for example) and squeegee with the semi-circle edge
Posted on Jan 16, 2013
What does a diagnostic tool mean when saying "bank 1"...
It usually means the catalytic converter is not getting hot enough to function, but could be another issue. The sensor readings between the sensor before and the sensor after the cat are not within spec.
Bank one is the side with cylinder one, or the side with the catalytic converter.
Jul 25, 2014 | 2003 Buick Regal LS
How do i program the remote for my car?
PROGRAMMING REMOTE KEYLESS ENTRY TRANSMITTERS (RKE)
1. Install scan tool
2. Turn the ignition switch to ON - do not start engine
3. Select "Remote Function Actuation" with the scan tool
4. Select "Special Functions"
5. Select "Program Key Fobs"
6. Select the number of key fobs to be programmed
7. Press and hold the LOCK and UNLOCK buttons on the first transmitter simultaneously for approximately 15 seconds. The door locks should cycle (Lock and unlock) to confirm that the programming of the first fob is complete.
8. If you are programming more than one transmitter, repeat the previous step for each transmitter for up to four transmitters in total.
9. Remove the scan tool
10. Exit the vehicle and operate transmitter functions to verify correct programming and operation.
Apr 20, 2011 | 2003 Saturn L-Series
99 cavalier dtc p0452 fuel pressure sensor,i replaced sensor cel wont clear code, pcm?
did you try to remove the code # with a diagnostic code retrieveing tool, this will remove the light from being on in the system, providing the computer is functioning properly, if you do not have the tool to do this with, then disconnect your positive battery cable, for about 1 minute, then reconnect it back up, and see if light is out. you will have to reset your vehicles clock, and possibly some radio functions.
Apr 15, 2011 | 1999 Chevrolet Cavalier
How to bleed the brakes
Bleeding the ABS System
Print
NOTE
This procedure requires the use of a scan tool.
NOTE
Performing the SYSTEM BLEED FUNCTION on the diagnostic tool drives trapped air from the hydraulic control unit (HCU). Subsequent bleeding removes the air from the brake hydraulic system to the bleeder screws.
NOTE
The engine must be running to provide adequate voltage to the HCU module during the anti-lock control portion of the system bleed.
1. Connect the diagnostic tool.
2. Start the engine and depress the brake pedal to half of the full travel position.
3. Access FUNCTION TEST mode and press the trigger to run the SYSTEM BLEED FUNCTION.
4. Manually bleed the brake hydraulic system.
5. Repeat the procedure performing a total of two diagnostic tool cycles and two manual bleed cycles. The bleed procedure is complete.
Hope helps.
Nov 01, 2010 | Ford Laser Cars & Trucks
How do i program a 2004 malibu keyless remote
The order in which the transmitters are programmed is important. The first transmitter programmed will be transmitter #1, and the second transmitter programmed will be transmitter #2. Use care to program the transmitters correctly.
The scan tool must stay connected until all of the transmitters are programmed.
  1. Install a scan tool.
  2. Turn ON the ignition with the engine OFF.
  3. With the scan tool, select Body,go to Remote Function Actuation.
  4. Select Special Functions.
  5. Select Program Key Fobs.
  6. Select the number of key fobs to be programmed.
  7. Press and hold the LOCK and the UNLOCK buttons simultaneously on the first transmitter for approximately 15 seconds . The Power Locks should cycle to confirm programming of the first fob is complete.
  8. If you are programming more than one transmitter, repeat the previous step to program up to four transmitters.
  9. Remove the scan tool.
  10. Exit the vehicle. Attempt to lock/unlock the doors to verify the programming.
  11. Operate the transmitter functions in order to verify correct system operation.
May 27, 2010 | 2004 Chevrolet Malibu Maxx
Instructions for programing kwikset lock
-Insert the functioning key (current working key)
-Turn 1/4 turn clockwise
-Insert Programming tool (goes in the real small slot) until you hear the click.
-Remove the Program tool
-Remove the functioning key
-Insert the new key
-Turn back 1/4 turn counter-clockwise.
-The new key should work with the lock now and the old one should not.
Oct 18, 2009 | Kwikset Locks & Locksmithing
Factorial
Function to calculate factorial would be:
function fact(n){
if (n<=1) return 1;
return fact(n-1);
or nonrecursive
function factnr(n)
var f=1;
for(i=n;i>1;i--) f=f*i;
return f;
In both cases n must be an integer
Jan 29, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Visual basic 6.0
Use a compare (instr) command to search the sentence for punctution and spaces. Increment a variable for each word found, resetting the search string and retaining the start position of each find.
Feb 27, 2008 | Computers & Internet
Drywall Logo
1,019 people viewed this question
Top Drywall Experts
Tim Hunt
Tim Hunt
ray gallant
Bill Boyd
Are you a Drywall Expert? Answer questions, earn points and help others
