Question about Electrical Supplies
Honda eu30i genset not starting with shelf
Engine does not start with remote switch or manually.it starts only by pulling rope
CarlGehrke
  • 169 Answers
SOURCE: Quietsource 25kw Staring problem In auto mode or manual
Sounds like the you have no spark since when you force the engine to crank it never fires. The low battery light come on because the 2 sec of cranking lets the voltage get lower than the alarm threshold.
I'd connect a spark tester to either of the plugs and try a manual start, if you see sparks replace the plugs, if you get no sparks then you've got to troubleshoot the ignition modules and the kill wire that comes from them.
Regards,
Carl
Posted on Mar 01, 2009
SOURCE: I am looking for a servivce manual download for a
hi look for 4100 makita genertor manual
Posted on Mar 08, 2009
KMusselmann
  • 247 Answers
SOURCE: pull rope broke
This usually happens at the most inopportune time. You go out mow the lawn, pull the rope and it comes out in your hand. Here's how to fix it yourself.
First, we'll talk about a simple rope replacement. In most cases you will have to remove the blower housing from the engine to get to the underside of the rewind starter where the rope is. We'll assume at this point that the spring is ok and you can just wind it back up again. You can check the spring by turning on the hub in a counter-clockwise direction and see if the spring gains tension. Do not try to remove the spring from its holder or you may end up having to take the mower in for service.
1. Remove the rope from around the hub. Since there is no tension, it should come right out. If you are lucky and it broke near one end, you can probably just re-use it. If it is badly frayed or too short, you will need to find a replacement at a local hardware store.
2. Attach the handle or tie a knot in one end of the rope so it will not wind all the way into the hub. You also may want to burn the rope ends to keep them from fraying and causing a problem in the future. Set the rope aside where you can grab it once you wind up the spring.
3. Wind the hub in a counter-clockwise direction using your thumb to keep it from unwinding, until the spring is tight. Then let it come back slightly so the rope hole in the starter housing lines up with the rope hole in the hub.
4. Stick the rope through both holes while holding the hub from unwinding. This is tricky because you don't want the hub to unwind on you before you have the rope secured in it. A pair of needle nose pliers or a small screwdriver or pick may help get the rope through.
5. Tie a half hitch knot in the rope after you have it through both holes. While holding the rope, release your hold on the hub and let the rope slowly pull itself back into the starter.
6. Put the blower housing back on and your ready to start the engine & mow.
Kurt
Posted on Mar 19, 2009
  • 7 Answers
SOURCE: when pulling the rope to start it doesn't grab for about 5-6 pull
Unscrew the 3 or 4 screws on the outside of the plate that is part of the pull string housing, there are 2 centrifugal pegs that are sticking due to trimmings getting in that area. Inspect, and clean the pegs that fly out when you pull the string. Do not oil (that will only attract more junk later), make sure they are free, and come out when you pull the string. And your problem will be solved.
Posted on May 25, 2009
#1 Taper
  • 1040 Answers
SOURCE: cannot get my trimmer started.
Tom, it sounds like part of the rope has jumped off of the spool. There should be a small piece of plastic with a screw holding the spool in place. It may have worked itself loose.
Jim
Posted on Jun 07, 2009
What connector is needed for a remote start?
talk with an accredited electrician as there will have to be a special relay/ breaker in the fuse board of the house
the problem is that your genset cannot be running when utility power comes back on as it will destroy the genset
the electrician can wire the board so that when utility power is available the gen set can be started but not connected to the house
when the utiltiy power fails the relay switches over to the gen set and allows it to start and power the house
when utiltiy power is restored the relay disconnects the gen set and reconnects to the utiltiy power supply
This is not a job for anyone except a fully qualified electrician
Oct 19, 2015 | Honda Generator Wireless Remote Starter...
How do I start a weedeater fb25?
Press primer bulb 6 times
Move throttle lever to start position
Move choke lever to full choke position
Pull starter rope sharply until engine attempts to start, but no more than 5 pulls.
Move choke lever to half choke position. Pull starter rope sharply engine runs. If engine hasn't started after 5 pulls, repeat all steps above.
After warming up for 10 seconds, move choke lever to run position.
Manuallib.com has a manual for this model available for free download
Oct 20, 2014 | Weedeater Garden
1998 Honda F6 C Valkyrie only starts in neutral
Hi, Belakovacs the ignition circuit cut-off system comprising of the side stand switch, clutch switch and neutral switch has the following functions:
a. It prevents starting when the transmission is in gear and the side stand is up, but the clutch lever is not pulled.
b. It prevents starting when the transmission is in gear and the clutch lever is pulled, but the side stand is still down.
c. It cuts the running engine when the transmission is in gear and the side stand is moved down.
Periodically check the operation of the ignition circuit cut-off system according to the following tests.
With the engine turned off:
1. Move the side stand down.
2. Make sure that the engine stop switch is set to "RUN"
3. Turn the key to "ON".
4. Shift the transmission into the neutral position.
5. Push the start switch if the engine does not start the neutral switch may be faulty.
With the engine still running:
6. Move the side stand up.
7. Keep the clutch lever pulled.
8. Shift the transmission into gear.
9. Move the side stand down if the engine does not stall you may have a faulty side stand switch.
After the engine has stalled:
10. Move the side stand up.
11. Keep the clutch lever pulled.
12. Push the start switch if the engine does not start you may have a faulty clutch switch.
This check is most reliable if performed with a warmed-up engine.
For more information about your issue and valuable "FREE" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Won start unless in Nuetral GL1500 Information Questions goldwingdocs com
98 GL1500 SE US Spec wont always start when button pushed
Honda GL1500 Service Manual
https://www.partsfish.com/page/oem-parts-for-honda
Honda 1997 GL1500C Valkirie Owner Manual
Mar 30, 2013 | 1998 Honda F6 C Valkyrie
My yard pro lawn mower will not start, when i try to pull start it the crank rope vets pulled back sometimes
Two things to check here, check the blade is tight, it acts as a flywheel so needs to be tight, second, check the flywheel key has not sheared as this will cause the engine to kick back as the timing will be out.
Apr 25, 2012 | Garden
I have a honda gx390 13 horse engine I just put a new pull Rope on it and cleaned the carb its been sitting for 3k10 years when I pull the rope slowly it will turn the engine when I give it a good yank...
This is a common problem. The valves need adjusting in the motor. You may eventually get it started and running in this condition but you will probably end up breaking your pull rope a few times in the process. Take it to someone who works on small engines like a mower repair shop.
Apr 01, 2011 | Garden
Motorturns over hard with pullstarter on my gx340 pressurewasher
You have a nice setup, lots of power. The honda gx340 has a compression release built into the engine so it should be relatively easy to start. With the pressure pump under load however, it will be very hard to pull the rope. With water connected hold spray gun open so water is running out tip and pull rope to start (for easy start, remove tip from gun) . If it still feels very hard to pull rope while holding gun open, most likely problem with lubrication in pump or engine valves are not adjusted correctly preventing compression release. If you suspect problem, go to store where you purchased the unit or any store that sells gx340 and pull the rope to get a feel of what force is required to start engine and compare to yours. Good luck.
Feb 15, 2011 | Honda Pressure Washer PSI 3000
What are the settings to pull start it
Pull starting a machine of any kind is fairly simple.
make sure your ignition is in the on position and that all safety switches are set (brake, oil level, blades, neutral etc.)
-give the engine extra fuel by the throttle position just past full throttle called "choke" -pull the engine through slowly until you feel resistance -let the rope back into the engine -pull quickly on the rope (if the engine does not start on the first pull repeat the previous two steps ) Once the engine starts back the throttle down out of "choke mode"
Feb 10, 2011 | Garden
I tried to start the pressure washer by lulling the cord, there was sharp popping noise, and the engine would not crank to start. It is a Honda K. washer. What went wrong? Pls advise, thanks.
Make sure your oil level is correct and not overfull. If ok, pull the sparkplug out. Then, pull the starter rope to see if the engine spins freely. If it does, pull it 4-5 more times to clear the cylinder of oil or gas. Put the plug back in and try it again.
However, if the rope fails to pull freely, you either have a locked engine or pump. You will have to seperate the pump from the engine to determine which is locked up.
Aug 02, 2010 | Honda Garden
Pull cord broke
if you have not replaced cord you will need to do this,when you fit the cord turn the pulley 4 or 5 times full circle the same way as if it was pulling cord,then feed cord through pulley and out of housing to fit handle when this is done you can let pulley recoil and you should have correct tension,hope this helps
Mar 10, 2009 | Honda Pressure Washer PSI 3000
Electrical Supplies Logo
Top Electrical Supplies Experts
ken skalski
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
