Question about Home
Shower runs boiling hot water to freezing cold and lacks water pressure
My shower lacks water pressure and keeps running boiling hot then freezing cold water
brainyass
  • 242 Answers
SOURCE: Gainsborough Shower Running Cold
It sounds like you have a faulty thermostat or broken heater element.
Posted on Oct 23, 2008
  • 148 Answers
SOURCE: Our Aqualisa power shower lacks water pressure power
more than likely you have some debris near the shower head
take an adjustible wrench( crescent or channel lock
wrap a rag around the eustaceon( chrome tube coming out of shower wall srap around tube to protect the chrome hold it firmly with vicegrips or channel locks, take adjustible wrench or chanel locks and remove the chrome nut holding the shower head on to the eustaceon(turn counter cockwise be careful not to drop the tools that wil damage the tile or fiberglass
after removing showerhead
turn on shower to force and debris out and place shwoer head into stream of water to clean out any deposits the head may have some type of screen to strain the water
this should work if the flow has not incresed then there is a need to adjust the flow valve at the control
to reinstall the shower head reverse procedure
if you have any teflon tape wrap it around the threaded portion of the eustaceon
good luck
hoe this works
Posted on Dec 30, 2008
  • 659 Answers
SOURCE: Just moved house today, have a sirrus shower 1600- cold water
There is something caught in the hot side of the faucet manifold (main faucet body). You have to remove the trim and guts to access it. Use a flash light and look inside. Hopefully you can find the object. Oh by the way, you need to turn the water off to the whole house to do this. If you don't see anything have someone turn on the water slowly with the valve out of the manifold to rinse out the pipe leading to the valve body. Hopefully it will remove whats in there. If what you see is a white looking material that is stiff but brittle, then it's from the water heater and the water heater needs to be replaced. Sometimes there can be small stones that get "washed" into the lines when the main is worked on within the area of your home. But most likey it's from the water heater. Good luck! Don't forget to turn the water off before you remove the faucet guts.
Posted on Mar 21, 2009
  • 4 Answers
SOURCE: mixer shower connected to combi boiler running hot and cold
Mixing valves usually have a diaphragm inside that keeps the hot and cold separate. If the diaphragm is old it may be allowing the hot and cold to mix improperly at the back of the valve. This is similar to a cross connection (a hot water line tied into a cold line) in your plumbing. Cross connections interfere with the performance of Combination Boilers and Tankless Water heaters due to their having no water storage or a very small buffer tank. The brand of the valve will help as each one is different in their mechanical design. If this is the problem you or a licensed plumber can replace the cartridge in the valve. Refer to your valve's owner's manual for part numbers.
  • 12173 Answers
SOURCE: When turning on the shower faucet there is no hot water.
adjust ur anti scold the setting is set to low when single handle shower units are shipped they are set in cold mode for safety ur install/instructional paperwork explains such and also advises on how to adjust---remove handle and on shaft will see a blue and red plastic clips that are adjustable slide towards u and move red for more hot water test water continue till comfort level is reached for hot water
Posted on Mar 24, 2010
Testimonial: "This information was extremely helpful especially when you know what to look for and have instruction."
Water doesnt get hot unless you run the sink first then the wster on shower get boiling hot then ice cold showers a few weeks old
So you have 2 heating elements in your hot water heater. A top and a bottom. From the sounds of it your top element has went bad however they are only about $17 a piece new and it is recommended you replace both at the same time. Thats why it takes you long run to get hot water the top water heater water is still cold and long run gets to the bottom and gives you hot water.
Apr 03, 2015 | Home
Triton jade 3 running cold
Sounds like you have an instant hot water system... (no hot water tank) if true, check that fuse.
Jan 12, 2014 | Home
Moen single handled shower the hot water turns cooler then cold after a minute
Your whole house is likely plumbed wrong so that it is impossible to have equal pressures of both hot and cold at your shower. If you had your home plumbed with aquapex using a radiator for the hot water and a radiator for the cold water and have the radiators fed with a 1 inch line you can have close to perfect pressures.
Nov 15, 2013 | Moen Home
Gainsbourgh stanza 9.5 shower is boiling and water running slowly
it could be your shower is full of lime scale if it an electric shower if so try turning off the power and take the shower front off remove the heater chamber and block off the out let pipe and pour in a kettle descaler and wait this should remove scale then rince and put back together checking for leaks .
Jan 30, 2013 | Home
Lack of Hot water pressure
If its a tap refurde to, remove the head at the front of the tap and clean out the filter in front, if the houses warm water has low presure u must find ur presure redusing velve located on main cold feed to geyser and clean the cartrage out revit and ur presure must then be vine , let me know if that dosent help
May 28, 2010 | Danze & Single Handle Tub And Shower...
Shower goes boiling hot then freezing
does this happen with any other fixture in your house that almost sounds like an element in a hot water heater.
or remove handle and look for an adjustment dial to temper water and adjust it
Apr 30, 2010 | Home
Mira mixer cannot balance temp.either scalding hot or freezing cold
I suspect you have gravity fed hot water system and the mixer cannot balance the high pressure of the cold mains against the low pressure of the hot water.
Either install a shower pump. Means installing electrical connections and quite a bit of plumbing
Or a mechanical pressure reduction valve on the cold input pipe to the shower
Apr 02, 2010 | Legacy Home
Can't get cold water
the balancing spool sounds like it is frozen. You need to replace the cartridge. The spool needs to move freely to regulate the water coming through it to keep from scalding a person.
Nov 20, 2009 | Moen Posi-Temp Single HandleTub And Shower...
Water heater shuts off when the cold water is turned on
Not sure but check the inlet water at the heater, the filter may be clog up a little that restrict the flow. Did u use the heater at all during the winter? If not, the heat exchanger may be clogged with built up in there. U need to descale it. Good luck. Chinhcu
Mar 31, 2017 | Bosch Water Heaters
Lack of hot water from water heater
Unit needs a new "dip tube" It is cracked and allowing cold in water to mix with all hot water resulting in "lukewarm water". Need plumbing skills to change out at cold inlet top of heater,pull out old,buy new at hdepot 5.99 reinstall.
This has been a small manufactor recall on this matter
Please rate Thanks
jj505
Mar 29, 2009 | Whirlpool Water Heaters
Home Logo
67 people viewed this question
Top Home Experts
Donni Steen
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
