Question about Maytag LSE7806A Top Load Stacked Washer/Dryer
No power After a brief power outage the dryer will not operate. How do you reset it?
  • 65 Answers
ALL I CAN SAY IS TO VERIFY 240 VOLTS AT THE MACHINE. I LIKE TO REMOVE THE COVER ON THE BACK WHERE THE CORD CONNECTS AND TEST THERE WITH A VOLTMETER. IF POWER IS PRESENT, IT COULD BE ONE OF TWO WHITE PLASTIC THERMAL FUSES INSIDE THE DRYER. ONE ON THE HEATER AND ON ON THE BLOWER HOUSING. TEST BOTH FOR CONTINUITY WITH THE OHMS SETTING ON YOUR METER. IT SHOULD READ 0 OHMS.
Posted on Jan 27, 2009
Model RB215LABP reset temperature display after power outage
Samsung Blinking Dash/Line Error Code List - Parts Dr
https://partsdr.com/blog/samsung-blinking-dashline-error-code-list/
Jul 16, 2011 - Indicate Error when the temperature sensed by Refrigerator sensor is .... My model required holding the super freeze and super cool buttons, but it worked! ... My display said S and E after a power outage I pressed energy .... I had that 5 E error code after a brief power outage... thank you for the resetting ...
Samsung Refrigerator Troubleshooting Self Diagnostics ...
www.appliancerepairlesson.com/.../samsung-refrigerator-troubleshooting...
Apr 13, 2011 - and then I also noticed that the display buttons for the temperature is not working. ..... We have tried to reset the refrigerator with no luck. ..... I had a power outage yesterday and my Samsung Fridge RSG257 now shows an 88 .... I haveModel# RF268ABRS, this thing quit cooling/freezing after we lost power.
Error Codes / Messages / Blinking
Dec 22, 2015 | Samsung Refrigerators
Our fridge compressor won't run after a power outage, can it be reset?
compressors use a small start / run capacitor to start the compressor
modern fridges do not like spikes from power outages and many power boards and electronic components fail because of this and I am inclined top use a surge protector before the fridge cord plug
I went google and typed in --fault code 88-88 for samsung fridge model rf26aewp and the first site up is error codes /messages/ blinking
the site is support-us.samsung>popup>iframe
there is a detailed answer there with a list of fault codes as well and what they indicate
there are other sites that also refer to the fault that you have
Dec 15, 2015 | Samsung RF267AEWP - 26 cu. ft. French Door...
Reset after power outage
Assuming this is a 220 volt dryer, are both sides of the breaker on? It should not blow only one side of the 220, but worth checking.
Jan 26, 2014 | Kenmore Dryers
We had a power outage and the display is blinking and there is no response to pressing any button
First, try unplugging the microwave for 2 to 5 minutes and then plugging it back in. Sometimes, a very brief power outage will be sensed by the control as an internal error and the control will lock itself out.
If it continues to blink and does not respond to key presses after this "hard reset", it is likely a portion of the control board could have been damaged from the power outage.
FYI ... the touch panel for this model is no longer available. I mention that because no response from any key press can also denote a shorted key pad.
Apr 15, 2011 | Frigidaire FMT116E1W Microwave Oven
Runs but will not heat. Power outages in area over last few weeks.
If the dryer was running during an outage, even with a very brief flash there usually is a power surge when it comes back on. If everything else seems to work okay it's possible that the heating elements got fried. You can check them with a voltmeter. Also check to seek if the dryer has overlaod protection. Most have a reset. One other thing that could happen, the breaker is defective. That you can check at the back of the dryer where the plug cable attaches to the dryer.
Apr 09, 2011 | LG DLE2516 Electric Dryer
We had a brief, about 5 seconds, power outage now our Intertherm electric furnace is turning on and off repeatedly. The temp was set at 65 and I turned it down to about 60 and it has stopped. Could that...
Hi, is this furnace a free standing unit or a full size electric heater? You can try turning off the main power to this heater for 5 or so minutes and back on again. You may have lost a internal stat of some kind. Try what I said and if nothing changes, send me the model and serial number so I can check into this further. If it stopped at 60, it should be alright at 65. The thermostat may have burned out. I don't know this yet but let me know what happens.
Shastalaker7
Apr 14, 2010 | Heating & Cooling
After extended power outage my laptop will not
Try holding down on the power button until the leds stay on ... then release it. Don't just tap or push the power button once.
Feb 06, 2010 | Microsoft Windows XP Professional With...
We had a brief power outage--now prinker knunks
In all probability that Power Outage caused a massive Spike or Surge on your power line. This has affected this unit. It doesn't take much to cause this type of thing and is quite common. It may be repairable, however these days buying a new one is often a better option. If you do go the repair route, go to a reputable place, & please ensure you get a firm "Quote" not an "Estimate" for repair.
Jan 20, 2010 | HP Photosmart 2410 All-In-One InkJet...
Maytag LSE7806A Top Load Stacked Washer/Dryer Logo
94 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
