SOURCE: 2001 Chvy van: overheat+water leak/from strange(new?) hole
seems u have a blown head gasket or cracked head!
SOURCE: Camaro Water Pump!!!!
For those attempting this, it must be known that to get to last pump bolts the mounting bracket for the coil packs has to be removed. But to do this you have to remove the power steering pump pulley, and for that you need a special tool. The kit cost about $65.00 and has the adapters to not only pull off the pulley, but has studs that thread into the end of the power steering pumps shaft to get it back on. Also make note that the bolts around the circumference of the water pump all need to be torqued to specific inch/ pounds and ft/pounds, so a torque wrench is needed.
SOURCE: 2000 monte carlo how to replace water pump.last bolt
there should be holes in power steering pump pulley that when positioned correctly the bole should go through one of those holes, if not then you have to remove the pump
SOURCE: remove the power steering pump pulley on a 2003 monte carlo
you can either remove the steering pump to gain access,if there is no holes in PS pump pulley,you can rent a pulley puller....can be a ***** to get in and use them though....I will drill a hole in it for next time whenever I replace a pump on cars without ....
Fig. Alternator mounting-1.5L and 1.6L (VIN 5) engine shown
Fig. Alternator mounting-2.0L and 1.6L (VIN 3) engines shown
Fig. Alternator mounting-2.4L and 2.7L engine
