Do i need a different transmitter for every receiver in my house?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 152 Answers
No, you can use multiple receivers with the same transmitter
Posted on Jan 16, 2013
Wireless mic not sending signal
need more information.
what model?
handheld or beltpack? microphone or instrument?
check transmitter and receiver are set to same frequency.
does a different transmitter work with the receiver?
does the receiver show the transmitter is functioning (ie receiving rf) but not receiving audio signal (af)?
Nov 07, 2013 | Sennheiser Audio Players & Recorders
Tip
Genie Intellicode Remote Transmitter Programming Instructions
USE ONLY WITH SERIES II ELECTRONICS.<br /> Older Transmitters and Receivers will not work with these new electronics. There are no Security Code Switches inside the Door Operators, Transmitters and Receivers.<br /> <br /> <br /> To Program Receiver <br /> Step 2-1 Locate the Learn Code Button and Radio Signal Indicator on the Power Head Receiver of your Door Operator.<br /> <br /> Step 2-2 Press a Transmitter Button once within 30 seconds.<br /> <br /> Step 2-3 Press and release the Learn Code Button<br /> &bull; The Radio Signal Indicator will blink approximately 2 times per second.<br /> &bull; The Radio Signal Indicator stays lit - SOLID.<br /> <br /> Step 2-4 Press the same Transmitter Button within 30 seconds.<br /> &bull; Radio Signal Indicator will go out.<br /> <br /> NOTE: If a second Transmitter Code is not confirmed within 30 seconds or if a different Transmitter Code is sent, the Radio Signal Indicator will blink approximately 4 times per second, then programming will stop. If programming stops, repeat Steps 2-2 through 2-4.<br /> <br /> Step 2-5 Repeat Steps 2-2 through Step 2-4 for each Transmitter, Wireless Keypad or other access device to be learned.<br /> <br /> NOTE: A maximum of 7 Transmitter, Wireless Keypad and other access device Codes can be stored into Receiver Memory at one time. If a Transmitter becomes lost or if you want to delete a Transmitter, Wireless Keypad or other access device, proceed to ERASING ALL RECEIVER MEMORY.<br /> <br /> <span style="font-weight: bold;">Multi-Button Transmitters</span><br /> <br /> NOTE: Only ONE button of a Multi-Button Transmitter can be programmed into a single Receiver. The other buttons are to control other Door Operators.<br /> <br /> NOTE: If you are replacing a lost or stolen Transmitter:(1) Erase ALL Transmitter Codes from the Receiver memory. (2) Reprogram the Receiver with the remaining Transmitters Codes.<br /> <br /> <span style="font-weight: bold;">Erasing All Receiver Memory</span><br /> <br /> Step 4-1 Press and HOLD the Learn Code Button for 10 seconds or until Radio Signal Indicator goes out.<br /> <br /> <span style="font-weight: bold;">ALL Transmitter Codes are erased from Receiver memory.</span><br style="font-weight: bold;" /> <br /> Step 4-2 Reprogram the Receiver with the remaining Transmitter Codes (Repeat Steps 2-2 through 2-4).<br /> <br /> <span style="font-weight: bold;">Step 5-1 Battery replacement</span><br /> &bull; Slide Battery Cover off of Transmitter back.<br /> &bull; Replace with new batteries.<br /> &bull; Slide Battery Cover back on.<br /> <span style="font-weight: bold;"><br /> Step 5-2 Visor Clip installation</span><br /> &bull; Slide Visor Clip into back of transmitter until it snaps into<br /> place.
on Jun 21, 2011 | Genie Company IntelliCode GICT390-1BL...
Would like codes for the area of 56573
If you need a S.A.M.E. code, NOAA does these by county.
The zip code of 56573 is part of the county of Otter Tail, Minnesota, assuming no typing errors are involved. Thus the S.A.M.E. code is 027111 . Several transmitters cover this region 162.400 (channel 1), 162.500 (channel 5), 162.550 (channel 7), and 162.525 (channel 6) . However, the best transmitter choice is probably Channel 5 (162.500 WNG680) from Fergus Falls. The second best choice for Perham, MN is Channel 1 (162.400 Detroit Lakes WXM64 but it is a low power transmitter). See the link to the coverage map below.
All S.A.M.E. codes are available here: http://www.weather.gov/nwr/indexnw.htm . Click on your State and then look for your county. The Minnesota S.A.M.E. codes are listed here: http://www.weather.gov/nwr/CntyCov/nwrMN.htm . To see the coverage zones for each of the transmitters, see http://www.weather.gov/nwr/Maps/PHP/minnesota.php (the link to the coverage map is also on the County S.A.M.E. code list page on the left hand side of the page.
Otter Tail is a large county and none of the transmitters seem to cover every inch. So you will need to try your weather radio and see which transmitter gives you the best reception of tests, watches and warnings.
I hope this helps.
(who has several weather radios in the house. They are in different areas and set to receive different transmitters. I live near a county line and the signal strength depends on where in the house you are. We tried using an external antenna. We received the signal from a transmitter from another state at the desired frequency and didn't receive the local warnings.)
Aug 08, 2011 | Midland WR-100 Weather/RDS Radio
Got a midland weather radio problem wr100 series. all county codes in and channel set. was working for awhile and now no alerts at all. keeps now saying check reception.
Turn your radio off and then on again. Then press the weather/snooze button. Do you hear the broadcast from your local transmitter? Check NOAA to make sure the station is broadcasting (not down for repairs). Try setting the radio to a different transmitter that covers your area.
You may need an external antenna for the radio (http://www.midlandradio.com/Weather-Radio-Accessories.BPE/18-259W ). Beware: when you use an external antenna, you may receive a broadcast from a different transmitter (farther away). In that case, the weather alerts for your county will likely not come in.
I hope this helps.
(we have two weather radios that are on full-time. The one set to a secondary transmitter does not receive the S.A.M.E. test signals or watches. (It can't be positioned to receive from the primary transmitter clearly.) It does receive warnings for the county correctly. The on/off routine has to be done every few weeks since it doesn't get the test signals. We tried an external antenna and kept getting transmitters from other states and missed tests, watches and warnings. Fortunately our main weather radio does get the primary transmitter and gets the tests, watches and warnings.)
Jun 27, 2011 | Midland WR-100 Weather/RDS Radio
I am looking for a baby monitor with 2 transmitters and one receiver . i have not seen such a thing. i am willing to buy 2 baby monitors if either receiver will 'communicate' with either transmitter. ...
There are MANY products available that will suit your needs, begin your search HERE.
MORE
MORE
If more options are needed search your favorite search engine with the phrase:
"Multi Room Baby Monitor"
May 05, 2011 | Graco Direct Connect Monitor
We just got a new Weather Channel wireless temperature sensor 9245. It seems that the transmitter isn't working. We followed the directions and put new batteries in the transmitter first, then the...
The new batteries could be defective or installed incorrectly. Remove all batteries and start over again. Be sure to let the transmitter initialize and begin sending data before you install the batteries in the receiver. If you can't receive a signal, the transmitter may have failed.
I have an Oregon Scientific receiver that is within line of sight of the transmitter and receives nothing......
May 17, 2017 | La Crosse Technology WS9245UBKITCBP...
NEED TO KNOW HOW TO RESET A PRESTIGE ELVATCE CAR ALARM
REPRIORITIZING A TRANSMITTER’S PROGRAMMING:
To reprogram a receiver channel with a different transmitter button once a code has been stored, there will be two options:
  1. Enter the transmitter program mode of the receiver channel to be reprogrammed. Using any unused button or combination of buttons, push out the stored code by pressing the unused button until a long chirp is heard, then repeat 3 additional times. After this, you can add any desired unused transmitter button. This action erases only that particular receiver channel, all other codes will remain stored.
  2. Enter the transmitter program mode. Using any transmitter button press and hold until a long chirp is heard. If a single chirp or multiple chirps, (up to 7 chirps), are heard, the unit is indicating that the transmitter has already been programmed elsewhere in the receiver. Release the transmitter button and within 5 seconds press and hold until a long chirp is heard. This action forces the unit to erase all stored codes of that transmitter.
The unit then exits the program mode the siren emits the program mode exit chirp pattern. All transmitter buttons for that transmitter must now be reprogrammed. Any other transmitter stored in the unit’s memory still remain operational. If the button is released and not pressed again within the 5 second period, no change in programming has been made to the receiver channel. The programmer can move onto a different channel or erase the transmitter codes as described in 1 above.
Regards, Martin @ http://www.lesscoelectronics.com
Sep 21, 2009 | APS20B Prestige Keyless Remote Alarm
Need manual to program remote to a different frequency
Each fan with have a receiver unit mounted in the housing, usually above the fan up against the ceiling. Each receiver unit will have 4 "dip pins" which allow the code to the remote to be set. In order for two fans originally installed with the same code to be run separately, one fan will have to be taken down, and the code changed on the receiver unit. Then you will have to purchase a new remote and set the same code on its dip pins (usually under the battery.) It's easiest to buy a replacement remote WITH a receiver AND a transmitter in it. You can either wire in the new receiver (setting the code differently than the existing one on BOTH the receiver AND the transmitter) OR just put the receiver aside and program the new code that you've set in the old one into the transmitter.
Apr 25, 2009 | Universal Remote Control Hampton Bay...
Hampton bay ceiling fan with built-in remote receiver
In case someone else stumbles upon this:
I replaced the remote receiver on one of these fans. jb is right just the top housing that touches the ceiling needs to be removed. Twist it counter clockwise and pull down. You'll see all the wires and the remote receiver. It might not seem like much room to work with, but you can remove the wires and slide the receiver out sideways to replace it or if you can't see the dip switches. Too bad Home Depot is too cheap to even provide instructions when they send you the replacement remove receiver.
May 23, 2008 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Televison & Video Logo
135 people viewed this question
Top Televison & Video Experts
Electro Med Services...
