Question about Yamaha 12V Air Pump
Starting problem on 2002 Yamaha Wave Runner FX140
I have a 2002 FX140 and the problem occurs when I have stopped and started the engine 6 or so times after a decent warm up. I use the wave runner for fishing so move around a fair bit.The engine turns over as normal but just wont fire, it almost seems like it is flooded and I have had to use engine start...which I am lucky I carry with me, to spray into the intakes to get it going again. What can be causing this?
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 118 Answers
Yamaha 4 stokes wont fire back up if you try to restart within 1 second of shuting it off.
Posted on May 27, 2013
3 Suggested Answers
jjhunmichael
  • 85 Answers
SOURCE: 1200 yamaha wave runner exhaust light keeps coming
The exhaust light must be blinking. However, running or operating the engine after the warnings had been activated, the light will continuously on. In this case, cool down the engine b stopping it. otherwise, it may result to a serious damage to the engine.
Posted on Jun 09, 2011
protek480
  • 1714 Answers
SOURCE: 95 yamaha wave runner starts
Have you changed the 'fuel filter'. That's where you start.
Posted on Aug 29, 2009
I have a myster oil leak on my 2011 Yamaha wave runner cannot find
if you can find a motor oil leak while in the wave runner
rear engine seal / oil filter seal /rocker covers front cover seals
lift the motor out and replace all the engine seals and gaskets
unseen internals
hardened valve stem seals /burning oil through rings
Apr 22, 2017 | Yamaha Cars & Trucks
2004 waverunner fx cruiser, ran great last time out. Now hard to start and wont run on high speed. Nothing over 6 mph.
How old is the fuel? Ethanol causes major problems if left too long. You may need to empty the fuel and clean out the fuel system. Try changing the fuel filter and adding some seafoam to the fuel and running seafoam thru the fuel system. Hopoe this helps.
Mar 15, 2014 | Covercraft UltraTech Custom PWC Jet Ski...
Dies when I first start have to restart a few times and dies at stop light unless it gets a little gas
This is usually a problem caused by a bad water temperature sensor. There are usually 2 sensors with one working the temperature gauge and the second working engine controls.
The "cold start" sequence is similar to a choke in old cars. It needs the signal from the water sensor to trigger the cold start sequence. The cold start sequence enriches the fuel charge, adjusts timing, and increases idle speed until the engine gets a little warm.
Now if stalling when warm, you have other issues. Manifold runners are a problem on some engines.
Feb 12, 2014 | 1999 Ford Taurus
How do I Change the idle speed on a 1994 Wave Runner
find where throttle cable attatches to carbs and on that wheel there is a lip on the inside and a screw should be there that you adjust the tickover !! P...
Aug 06, 2013 | Covercraft Personal Watercraft Cover -...
1999 Yamaha wave runner 1200 XL won't start
Check to see if you get power to the starter when you try and start it. If you do, they you may have a bad starter. If not then you may have a bad switch or even blown fuse.
Jun 11, 2013 | Motorcycles
Yamaha wave runner check engine light comes one and will not run properly.
Have the fault codes read. Replace faulty items. Use only
genuine items as replacement as non-genuine are not always compatible with the OEM fitted CPU units. This results in the fault codes not cancelling out.
Jun 09, 2013 | Yamaha 2009 WaveRunner FX SHO
ABOUT HOW MUCH IS TO UNLOCKED A 2 STROKE WAVE RUNNER 1200XL LIMITED
no idea on price but this sort of thing is used in salt water so although a new set of rings and a quick hone of the bore will sort it and maybe a new crank bearing as its obvious someone didnt put oil in with the petrol but the problem i have had with a lot of these fun machines is that getting the engine apart after salt water use is ?well lets just say difficult
Apr 12, 2012 | Covercraft Personal Watercraft Cover -...
Engine Runs Rough at Idle
go to auto zone,its free ck.throtle senser
Feb 19, 2012 | 2002 Ford Explorer
Yamaha 12V Air Pump Logo
530 people viewed this question
Top Yamaha Water Sport Experts
Colin Stickland
Colin Stickland
Piyal Perera
Piyal Perera
Are you a Yamaha Water Sport Expert? Answer questions, earn points and help others
