Question about Thomson Washing Machines
My washing machine shows a Er 12
My washing machine works and then shows a Er 12
MY LOGIK WASHING MACHINE MODEL L612WMS13 SHOWS ERROR 12, THE POWER WENT OUT WHEN THE MACHINE WAS STILL WASHING AND WHEN IT CAME ON IT DIDN T CONTINUE THE CYCLE AND THERE IS STILL WATER INSIDE
Remove the wall plug which _should_ reset the main board. If that doesn't work, you have to manually drain it by unclipping the drain hose and lowering it into a bucket.
Error 12 (E12)
Washing machine has detected an overfill situation This error code can be caused by overfoaming which is a result of overloading (see this article) or by overdosing or, incorrect detergent as the pressure sensor will falsely read that there is too much water in the washing machine.
Also check the pressure sensor and that the machine has not actually overfilled with water.
  • Check for overfoaming or over soaping
  • Check the air chamber and the pressure switch hose
  • Check water level sensor
  • Check wiring to water pressure sensor
  • Check connections to water level sensor
  • Check main electronic controller
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3848-logik-washing-machine-error-codes
Jan 20, 2016 | Washing Machines
HI would you what know what error code Er13 is?? on a Logik L614WD13 washer dryer?
Feature : Error Code-control panel display "Er13"
  • Answer : Reason:Drying heater element error. Sometimes caused by to much load during the drying cycle. Washer dryers can only dry half the wash load.
Nov 03, 2014 | Washing Machines
Dp error in ifb
I had the same error shown in my IFB Se?orita SX. I cleaned the dust collection tray at the right bottom of my WM. It had lot of dust and a coin. Not it works fine. May be this caused the DP(differential pressure) error. Whatever. My machine is working good now.
Dec 17, 2013 | Washing Machines
Sharp AY-XP 12 ER indoor inverter showing -0 14 error
Sharp AY-XP 12 ER indoor inverter showing -0 13 error
Sep 11, 2013 | Sharp Heating & Cooling
Shows F-12, now not working
Possible errror on the controller unit , you might have to switch off the unit for some time and try again and if the fault persists , it seems that the controller is getting back some feedback error which must be checked out. As mentioned earlier the reset will depend on the make and model , and use of testing equipments to confirm is also important .
Jun 05, 2012 | Washing Machines
I have an error 04 showing on my dishwasher, and the cycle will not run. Please help!
dryer damper problem. there is another post that will help from electrolux personnel.
Thank you in advance for allowing Electrolux to assist you in
this matter.
I apologize for the inconvenience and concerns this dishwasher unit has been causing you. Unfortunately the error "E04" code does indicate an issue with the drying damper. Now this is something that a technician would have to assess because wiring is needed to be checked.
Check wiring between Main Control Board and upper fan. If correct, replace upper fan.
If your unit is brand new it is covered under warranty and you can choose to contact your dealer for a repair technician, or visit www.electroluxappliances.com/servicelocator to find a listing in your area.
Kindest Regards,
Chris Polk
Online Outreach Representative
Electrolux Major Appliances
Er 01
Leak Detector - When water is detected under
the tub.
Er 02
Thermistor - When thermistor/turbidity module
fails
Er 03
Wash Pump - Wash pump not operating
Er 04
Drying Damper - Drying damper not operating
Er 05
Upper Fan - When in the dry cycle, the control
board does not receive proper speed feedback
from the upper fan
Er 06
Lower Fan - When in the dry cycle, the control
from the lower fan
Er 07
Drain Valve - When in the drain mode, the control
board does not receive proper position feedback
from the drain valve
Er 08
Tactile or touch switch - Control board has
verified a switch on the user interface is bad or
shorted
Er 09
Communications - Communication failure between
main user board and power supply
Er 10
Mains Relay - Failure in the mains power relay
Er 11
Drain Valve - Time out before finding a state for
the drain valve
Er 12
Drain Valve - The drain valve is running when it
should be off
Er 13
System wide - Lost control of the State Machine
Jun 23, 2011 | Electrolux Dishwashers
Hello i am repair man . i have a washing machine model aeg 76800 machine take a program correctly and start but after 5 second stop it please help me quicly thank you
when it stops do you still have power to the front panel if there is no power to the panel then you would have a bad connection to one of the control boards. are there any error codes showing when the unit does stop such as flashing lights or an exact er code have you checked the door switch? if the door switch does not work the unit will start then stop immediatley message me back with your finds thanks Rick
Apr 24, 2011 | AEG L76800 Front Load Washer
Samsung washing machine SW50USP. Machine powers up, all buttons and settings work but when press start button the cold light and wash light start flashing but doesnt start to wash. After 2 minutes 4E shows...
I've just had the same problem with my Samsung SW50USP and had a technician out to have a look at it. Apparently the electronics are fried and it would cost much more than it's worth to fix. Time for a new machine unfortunately.
Dec 26, 2010 | Washing Machines
My Whirlpool Calypso Washing Machine has a code Er But makes no beeping sound? What is wrong with it and how do I remedy this?
You sad,My Whirlpool Calypso Washing Machine has a code Er But makes no beeping sound? What is wrong with it and how do I remedy this?
You can unplug the washer for 5 minutes and this should reset the system
Huuum
Oct 24, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Washing Machines Logo
Top Thomson Washing Machines Experts
Garth Jackson
highlander28
Level 1 Expert
Are you a Thomson Washing Machine Expert? Answer questions, earn points and help others
