Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
Esam5400 broken on/off switch on control panel
Need new buttons without new control panel
Hi all , I'm driving an automatic trans Mazda 6 year 2004. How come I can switch my gear from neutral/D to REVERSE/L (first gear) without pressing the safety lock button on the gear knob? The shift lock...
You should definitely have to push th button to get from forward to reverse. If not the gate at the base of shifter has broken and will need to be replaced
Mar 22, 2015 | 2004 Mazda 6
Intermittent control panel issues
It should not be the board, however it may be a loose connection
Sep 09, 2008 | Dryers
My start button doesn't work, very loose, appears to be off track to engage
Had same problem but solution was different. Start button looked slightly misaligned and wouldn't always work. Followed instructions to pull off front control panel, removed LED display panel and the plastic tab that the start button was attached to had broken off from the panel. Used a good epoxy to glue the edges back together and it works like new. Also broke two tabs that hold the LED panel inside the front plate due to the plastic becoming brittle. Again, epoxy is your friend. Works like new. d04211d8-3b3d-44fc-bc8c-6da6cd6ecf7e.jpg
Jul 13, 2014 | Whirlpool Duet GHW9150P Front Load Washer
Why is my on and off botton stop working tryed putting a new one on but same thing pushing in and out but not turning it on have to do it by wall main
Odds are the PCB trace on the control panel is broken for the switch from pushing hard on the ON button. You will need to repair the connections or replace the switch or replace the control panel. Good Luck
Jul 16, 2013 | Office Equipment & Supplies
Power windows
Sounds like the window lock switch is on, or defective. You can lock out the other switches from the driver's control panel.
Jun 30, 2013 | 1998 Chevrolet Blazer
Hello I have a general electric dryer model DBSR463EG6WW serial number TR775112A and was wondering how do I bypass the start switch because it is broken
please there is no need to start your dryer without the switch. you can easily replace the switch yourself just follow this instructions below to replace your switch. things you will need are philip and hex and nut screwdrivers, putty knife and Replacement "start" switch. then Disconnect the dryer from the electrical outlet. Slide the dryer out from the wall and disconnect the dryer vent from the dryer's back panel.
    1. Loop a piece of string behind the "Start" button and pull forward on the string to pop the knob off the switch's post.
    2. Access the interior of the control panel. Depending on your model of dryer, there are several ways to access the interior of the control panel. On older dryers, there will be an access panel along the back of the control panel that can be removed once all of the retaining screws have been removed. On newer dryers, the control panel is held in place by screws in the front or spring clips. Remove the plastic end caps on the control panel and remove the screws underneath. If your dryer has no end caps, slide a putty knife under the corners of the control panel and lift up on the knife to release the clips. Rotate the control panel toward the rear of the dryer to access the interior.
    3. Unplug the wires from the switch by sliding them off the contact terminals on the switch. Make a note which wire connects to which terminal so you can easily connect them to the new switch.
    4. Press the release tab to unlock the switch and slide it out of its socket. If you have an older dryer, remove the retaining screw to remove the switch. Slide a new switch into the socket and press it down until the release tab locks into place. If you removed a retaining screw, replace the screw. Reconnect the wires.
    5. Rotate the control panel back down on the dryer or replace the rear access panel. Replace the knob and reconnect the dryer vent. Plug the dryer back into the electrical outlet.
Dec 24, 2010 | Dryers
The green botton plastic underneath it looks as it it broke off the button. It is not making contact with the print function
I would say that the Print switch on the control panel PCB has a broken solder joint. If you know how to get the control panel off and know how to use a solder iron, you can fix it. Or you will need to get a new control panel or you can call a local service rep. Good Luck...
Jul 02, 2010 | Canon PC-980 Color Copier
Cant find reset area getting error code c0500
First open the right side cover where the image unit is located. Check the two latches that latch the door ensure they are not broken, especially the rear one. Then get a paper clip and stick the clip in the small hole on the right side of the control panel it will touch a switch. The control panel will go thru some screens when you see the screen with the copiers on it on the left side of the screen in the middle you will see a small "." When the dot appears touch 3 button. Then the machine will continue to the code screen. Press the Utility button you should see a new button "Maintenance Mode" touch it then touch trouble reset. The machine will again go thru screens will see the"." again do nothing. Should go ready to Copy. If the code comes back do not reset you are messing with the Fuser the Hot part. Continuing to reset without a technician looking at and or replacing it, the fuser can catch on fire and that would ruin a perfectly good day.
if you need new fuser try this site
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Aug 19, 2009 | Minolta DiALTA Di250 All-In-One Laser...
Hi my laptop (acer aspire 5672wlmi) wlan and bluetooth switch that are conntected to its motherboard have broken off and are broke is there any way that im able to turn the bluetooh and wireless on without...
I believe that you can turn these functions on and off via the Network Connections that you can access from the control panel.
In Windows XP:
Click on START button
Select Control Panel
Click on Network Connections
In Windows Vista:
Select Network and Internet
Select Network and Sharing Center
In left panel, select Manage Network Connections
Once here, you should see your wireless adapter and your bluetooth adapter. If you Right-Click on either connection, a menu will pop up and you can choose to Enable or Disable the connection without the button on the front of your computer.
Hope this helps.
Jan 11, 2009 | Acer Aspire 3690-2196 Notebook
Whirlpool Control Panel Repair
model # MH6150XLQ
LOST POWER. I CHECKED WALL RECEPTACLE. IT'S GOT POWER.
MICROWAVE IS DEAD. NO LIGHT..........NOTHING.
WHAT'S HAPPENED?
Apr 30, 2008 | Whirlpool GH7145XF Microwave Oven
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
18 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
