Question about Spark Plugs BR4HS Plug 10/BX #3322
How to change spark plugs on toyota 98 prado v6
Toyota prado idling speed
Yes, it can be completely normal, engine idling RPM's will have various factors that affect them such as temperature, altitude, oil level. In all cars the RPM's will change when the compressor for the AC is activated.
Aug 10, 2013 | Cars & Trucks
Toyota prado 2001 v6 5vz engine, will start but wont run
OK - You confirmed the thermostat was causing the overheating? Sounds like fuel injectors - but check the spark plugs and ignition coils first.
Jan 18, 2013 | Toyota Land Cruiser Cars & Trucks
Land cruiser difficult starting on V6, 3.4L
How many miles on it. As simple as New plugs, wires (if any) fuel filter. Until more info is provided that would be my answer.
Oct 21, 2012 | 2005 Toyota LandCruiser Prado
How to change 2007 prado spark plugs
REMOVE IGNITION COILS OFF THE TOP OF SPARK PLUGS.THEN REMOVE SPARK PLUGS.
Feb 04, 2011 | Toyota Land Cruiser Cars & Trucks
How do get to the back on a 98 v6 toyota camry to change the spark plugs
you need a spark plug wrench with a universal joint to cover the angle while turning the wrench...
Apr 14, 2010 | 1998 Toyota Camry
Changing spark plugs in a 98 toyota camry 3.0 v6
How do I make sure I have found where all the spark plugs are on my v6 toyota
Oct 10, 2009 | 1998 Toyota Camry
Bogs down upon acceleration
You have coil over spark plug ignition and one of your coils is bad.You need to find the bad coil and replace it.
Aug 27, 2009 | Toyota Camry Cars & Trucks
Indicator problem 98 Prado
Indicator on right side rear flashes twice normal speed and the front right indicator does not flash
May 28, 2009 | 1985 Toyota Land Cruiser
Spark Plugs BR4HS  Plug 10/BX #3322 Logo
75 people viewed this question
Top Ngk Vehicle Parts & Accessories Experts
Ian Kime
Ian Kime
steve morris
steve morris
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
