Question about HTC One V
Htc one v no power, not charging - HTC One V
The post above me is completely wrong. The HTC One V has a built in battery. The problem has been popping up all over and we are currently waiting for a solution, whether it be software or hardware related. Again, the first post is not correct and will get you no where. Please do not post again unless you have an actual solution.
The situation sucks but that is the only conclusion I have reached as there is no fix for it at the moment.
Posted on Jun 11, 2013
  • HTC Master
  • 14,641 Answers
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
Posted on Jan 18, 2013
HTC sensation X315e charging problem
Leave it on until all power gone then hold down power button for 30 sec's and the try charging.
Jan 15, 2014 | HTC Tablets & eReaders
Htc rhyme not charging
First Option:
Second Option:
Jul 27, 2012 | HTC Rhyme
How do i charge myHTC wildfire
Hi There and Welcome to Fixya.
Here's my recommendation to maximize your battery power :
  • Fully discharge the battery of your HTC
  • Charge it fully
Repeat this for 3 times. This will enable your HTC to properly hold the battery power and maximize it's resources. For your convenience, I've included the user's manual :
HTC Wildfire Manual
Hope this helps, Thanks for using FixYa.
Apr 15, 2011 | HTC Wildfire Cell Phone
Charging problems, light comes on as charging but icon doesnt show up and doesnt charge
Back up all your files
And do a Hard Reset on your HTC Touch Pro
1. While the HTC Touch Pro is off, press and hold Talk/Send, End and Power until you see a message on the screen about deleting all data.
2. Release the buttons after the message appears.
3. Press the Volume Up button.
See if this helps -
Best Regards
Mr Solutions
Mar 11, 2011 | HTC Touch Pro Smartphone
HTC Touch Viva is not charging
You have to check first the charger you can used multitester in position DC volt to make sure the voltage no problem, if in the plug no voltage maybe the cable damage, or the soldering on pcb circuit bad,you can try with another charger first to make sure where is the problem.
Jul 12, 2009 | HTC Touch Viva Cell Phone
HTC TOUCH HD charging problem
Well hope so you didn't damaged the sensors! try this : use the phone until battery is empty and switches off. then put it on the charger for 4 hours. If no joy,try different battery to make sure that device is not damaged and get a new battery.
May 12, 2009 | HTC Touch HD Smartphone
No power When I press power button.- Battery is full
Try changing ur battery if it doesnt help then do this
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows
try this if it helps
hard rest factory default settings = when ur set is switched off press both buttons call and end key and then press power button on upside of pda for like 5 sec screen will appear asking to format all data take out ur card if u dont want to format that now confirm by pressing the centre action button in 4 side joystick and go
if not solved then go to www.htc.com for latest Rom update downlaod and update
other wise check xda forums for software dead HTC http://forum.xda-developers.com/
pls do rate me if i fixed ur problem
Feb 24, 2009 | HTC Touch P3450 Smartphone
My HTC smartphone doesn't power on despite charging
try pressing the reset button near the charging port on the pda if it doesnt work try to hard reset it as follows other wise check xda forums for software dead HTC
Feb 10, 2009 | HTC Touch P3450 Smartphone
HTC S710 - Battery issue
it could be either battery or charger, If the charger isn't supplying enough power it will fool the phone..
some 3rd party batteries and cheapo chargers can cause all sorts of problems like this.
best way to test is charge your phone by usb, it takes longer but will give you some idea of weather its the battery or charger.
Make sure that the box at the bottom of the power management window (dont charge by usb) is set to off. Also for best results remove any other usb devices from the computer this will leave more power for the phone.
Best of luck
Jun 05, 2008 | HTC S710 Smartphone
HTC One V Logo
645 people viewed this question
Top HTC Computers & Internet Experts
SANJEEV KUMAR SURI
SANJEEV KUMAR SURI
Tom Chichester
Are you a HTC Computer and Internet Expert? Answer questions, earn points and help others
