Question about Konica Minolta Konica 1015 1120 1212 Toner Black 947136
Error code p-25
How to reset error code p-25
  • Sherif Mkp
    Sherif Mkp Jan 16, 2013
    what s this error p25 how can i reset have nice day
How do I fix a F11 code on Whirlpool duet washer
Error code F11 = Serial Communication Error. Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.Aug 25, 2009
give it a try - worth unplugging and plugging back in.
Jan 29, 2018 | Whirlpool Washing Machines
2000 roadking pulled error code 25 what is it
HI Anonymous, Code 25 is "rear ignition coil open/low" Good luck
Jan 09, 2014 | 2000 Harley Davidson FLHR-FLHRI Road king
Konica 7145 error code F34-2
do this once code comes back replace the fuser continue reset couls cause fire ruining a perfectly good day
To reset failure codes, perform the following:
1. Enter the 25 mode (turn the machine ON, while pressing the 2 and 5 keys).
2. Select [1. software SW settings].
3. Using the arrows on the left of the touchscreen scroll to DIP SW 3.
4. Using the middle arrows scroll to BIT 1.
5. On the touchscreen select OFF (0).
6. Power the copier OFF/ON.
Dec 30, 2013 | Konica Minolta Office Equipment & Supplies
Sony dsr 25 error code
Always look for a tiny hole (in the back) that reads RESET. If none exists, maybe a push on a DISPLAY button? Try combinations (pressing simultaneously) - you cant break anything!
Nov 13, 2013 | Televison & Video
Konica 7065 with error code F36- 1
Sir,
Fuser Code (Hot Unit has over heated) To reset you will need to go to 25 Mode to enter his mode you must turn off the machine then holding down the 2 and 5 button turn on the machine, hold them 25 down for at least 30 second once in 25 mode select SW (soft Switch) select "3" then "3" it should be a "1" change to a "0" then exit and turn off the machine and turn "ON".
Feb 25, 2010 | Office Equipment & Supplies
Sony DSR 25, error code C3140. Any advise. Only comes up when tape is inserted.
FG fault when starting drum.
It’s very possible that you have a bad drum motor.
Dec 27, 2009 | Sony DSR-25 Mini DV VCR
Error message sc36-05on my biz hub pro c 500, we cleared a paper jam now this error comes up
Thats a low temp fuser code. You need to reset the code by going into "25 Mode" and reset dip switch 3-1 _ 1 to 0
Oct 11, 2009 | Konica Minolta bizhub C250 All-In-One...
Have a Abit A17 mother board that posting a 25 or 5D error code
I picked this up from an abit forum, It appears that it is quite common, look here, http://forums.hexus.net/abit-care-hexus/104674-abit-ab9-pro-code-25-error.html
Dec 21, 2008 | Abit A17 Guru Motherboard
Ar-5132 sharp copier
H3-XX codes involve the fusing unit temperature being too low or too high.
Try resetting the error.
[C] – [INTERRUPT] – [0] – [INTERRUPT]
Type in 1 4
Hit [PRINT]
Turn power off then on if it doesn't do it automatically.
If error doesn't reset then you have other trouble
I hope you ran the developer setup and reset all of the parts counters for the items you replaced. Not setting the developer reference can cause a host of problems.
Sim 25-02 adjusts developer.
Sim 42 clears DV counter
Jun 05, 2008 | Office Equipment & Supplies
Soltek error code 25
1. Try use any (to ex. - old) PCI video. If it run good - check (change) PSU, VideoCard or carefully look at capasitors (especially near video-slot).
2. Check temperature of South Bridge. If it very hot - it`s sounds very bad.
3. Remove any overclocking if it set.
Nov 05, 2007 | Computers & Internet
Konica Minolta Konica 1015 1120 1212 Toner Black 947136 Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
