Question about Air Intake & Fuel Delivery for Chrysler 300 AWD Sedan
Intake manifold control module
P2008 code year 2007 3.5 liter
  • Chrysler Master
  • 14,363 Answers
Trouble Code: P2008
SHORT RUNNER VALVE SOLENOID CIRCUIT
Possible Causes:
(K343) FUSED AUTO SHUT DOWN RELAY OUTPUT OPEN(K236) SRV CONTROL CIRCUIT SHORT TO BATTERY VOLTAGE(K236) SRV CONTROL CIRCUIT SHORT TO GROUND(K236) SRV CONTROL CIRCUIT OPENSHORT RUNNER VALVE SOLENOIDPCM
Trouble Code: P2008
Short Runner Solenoid Circuit Malfunction
Possible Causes:
S/R solenoid control circuit is openS/R solenoid control circuit is shorted to ground or power (B+)S/R solenoid power supply circuit is open to the ASD relayShort runner solenoid is damaged or it has failedPCM has failed
Posted on Jan 18, 2013
I have a 2007 jeep patriot. The check engine keeps coming on with the code p2008. Mechanic say fixed but check engine light keeps coming on and off. How do I fix problem
but you never scanned it the 2nd time, maybe the gas cap is loose.
p2 is jeep factory only code (unlike p0,1)
so only jeep books get this correct .
2007 MK Jeep it is.
is P2008 a rumor or did you see it with YOUR EYE and on what a real scan too?
P2008 Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
so what did he do? replace it , clean it? what?
if you clean it and it dont work, then its bad. replace it.
as for why the CEL glows now, you'd have to scan it again
mine has like 300 DTC's possible. so ID NEVER ASSUME its still P2008- not me , id scan it, any shop or store can scan it,
why wait, or guess or worry.?
or ask him to help, see if it is something new, or just the gas cap loose.
How do i fix it.
i dont know what you can do.... personally?
buy the FSM and read?
buy a scan tool and scan.
be clear as to all DTC thrown, and post them all.
Apr 22, 2015 | 2007 Jeep Patriot
When you have an extremely high idle and code p2008 shows up what could the problem be
Without knowing what car you have it gets difficult to be specific, however since usually p2008 is dealing with intake manifold runner control, and you have a high idle...Id say you may possibly have a loose or broken vacuum hose to runner control...with the vacuum off the runners cant be regulated...and the air leaking in through the bad/open hose will raise idle. check vacuum hoses and runner linikage
Apr 13, 2015 | Cars & Trucks
What does the code p2008 mean on a 2004 ford freestar minivan
Intake Manifold Runner Control Circuit/open bank 1
Apr 13, 2015 | 2004 Ford Freestar
I have a 2002 chrysler 300m with a 3.5. I started it this morning and it ran rough. I hit the gas and it cleared out. It ran for 5mins then shut off and smoke was coming from under hood. I checked and one...
check for fuses to the ECM
code p2008 refers to intakemanifold air control actuatoror solenoid bank 1---open circuit====causes wiring open circuit--intake manifold air control actuator/solenoid
IF the coil was melted , it is possible that the wiring for the p2008 fault is in the same harness and has burnt through causing the open circuit. or melted out in the connection causing the open circuit.
Feb 21, 2015 | 2002 Chrysler 300M
What is the code p2008
p2 is a factory code
that means a ford book is no good for toy'
only the toy FsM WORKS
IM 3000 Miles in to SA,. no books
but 5 seconds google finds this, see this?
Toyota P2008 OBD EOBD JOBD Vehicle DLC Code Lookup Toyota Intake Manifold Runner Control Circuit/Open.
on modern engine with have this feature(pain)
as solenoid operated ,runner volume switch.
its sticking or bad.
the http://www.helminc.com/helm/search_service_owner.asp?Style=helm&class_2=TOY
FSM covers the tests.
or alldata.com
as with all things like this
inspections, ahh its unplugged, or smashed or melted>
its sticking
the coil measures open
per FSM
Jan 08, 2015 | 2010 Toyota Fortuner 3.0D-4D
D4d tailand cod is p2008
This is a Code for the intake runner control on bank 1. It is a part that moves shutter controls to change the airflow inside the intake manifold. Browse the web for this part "Intake runner control or Solenoid" with your vehicle info.
What it does- In old days Intake airflow was casted into the part and not adjustable. Because of Variable valve timing, intake airflow needs to adjust. Newer intake manifolds have multi-chambers and this part allows air to change from one chamber to another.
Sometimes it is easily to replace than clean the part, some earlier parts had plastic ends which broke, solenoids failed, etc.
Please rate my info.
Nov 14, 2012 | 2007 Toyota Hilux 2.7
P2004 intake man.control bank 1 stuck open
The intake manifold runner control (IMRC) cables have plastic ends that like to break. Check your IMRC to see if the cable it attached. If the cable s attached, then the IMRC actuator is probably defective. (see diagram)
Jun 17, 2012 | 2003 Ford Focus
What is obd codes p 2008 p and p2015 p?
P2008 - Intake Flap for Airflow Control Electrical Malfunction P2015 - Sensor for intake manifold flap position range/performance
Feb 28, 2011 | 2006 Volkswagen Passat
Check engine light in my '07 VW passat 2.0t is on. Got codes P2015 (twice) and P2008 (twice) and EVAP system code P0456. What are these codes? Thx Phyllis
P2015 - Intake manifold runner position
P2008 - Intake manifold runner control circuit
P0456 - Evaporative Emissions System - Small leak detected
None of these are urgent, just annoying. And common problems with Audi's and VW. P2015 and P2008 were likely due to a software/sensor glitch, and did not necessarily require a replacement throttle flap motor. P0456 could be due to loose gas cap, but also was likely caused by carbon contamination from the evap cannister. I have all 3 codes on my 06 passat, and just live with them. I would estimate around 1000k conservatively to track down and fix from dealership.
Aug 16, 2010 | 2007 Volkswagen Passat Sedan
Air Intake & Fuel Delivery for Chrysler 300 AWD Sedan Logo
125 people viewed this question
Top Chrysler Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
elvis0427
john h
Are you a Chrysler Vehicle Part and Accessory Expert? Answer questions, earn points and help others
