Help I got my DVD stuck in the DVD slot on my Ensignia TV with side DVD slot....
    Genius:
  • 2,920 Answers
You may have to take the back of the tv off to get to the dvd player and get it loose...when u take the back off power the tv up in dvd mode and jiggle the tray for the dvd to see if it will come lose and release the dvd.
Posted on Jan 24, 2009
I have a dvd stuck in my Technika LCD 26-56D TV/DVD combi. Eject button on the remote control and side of TV will not eject the dvd. Screen is blue, indicating no DVD in the slot, but I can see it. Any...
Check the connection between the devices. There may be incompatibility issues. Or might the remote button not to make contact. Spread the remote, clean motherboard and contact sheet. Let them dry and reassembles.
Aug 11, 2013 | Televison & Video
CD is stuck inside of a tv/dvd player
Try shutting the television off. With the unit turned off, hold the eject button and turn the unit back on. Continue holding the eject button for 30 seconds or until the DVD comes out.
If this doesn't work, try unplugging the TV for 5 minutes and attempting the above steps.
Hope this helps!
Dec 06, 2011 | Toshiba Televison & Video
We have a Polaroid 15 inch LCD television with a built-in dvd player. It also allows for jumpdrive connection. I must be missing something but we cannot figure out how to play a dvd. I put a dvd...
Do you have the Polaroid 1513-TDXB? I assume you have tried the eject button on the side of the TV (the lowest button next to the DVD slot). There are a few things that can cause a DVD to jam and not be recognized by the drive: put in the disc label side to the back of the TV, home disc with a glued on label (if the label comes loose), two discs in the slot or non-standard optical discs.
Some slot optical drives have a manual eject hole on one side of the slot; it should be near the top of the slot on this unit. Straighten a paperclip and try pushing on the release mechanism inside that hole. (A small paperclip is the correct size.) Sometimes pushing the optical disc with a second optical disc will bump it loose (be careful you do not want the disc to be dragged into the drive). Another possible solution is to pry the disc up off the spindle with a credit card. (Note: trying this could damage the disc and the drive.) A similar card with double sided sticky tape can sometimes lift the disc off the spindle. Stick the tape on the card, then peel the paper off the other side of the tape. Insert the card to be on the top of the disc (sticky side towards the back of the TV) and press it down on the disc. Lift up slightly and pull the card and optical disc out.
If the disc has partially ejected, two credit cards (one above and one below) can grab it. Turning the TV on its side so that the optical drive is pointing to the ground can also work.
There are a few things to check once you get the disc out. Were there scratches or other problems that would keep the drive from seeing the disc? Other optical drive issues are dirt on the lens and the tracking unit failing on the drive. Blowing the dirt out of the drive may help. Otherwise, it needs to be fixed or replaced which means getting it out of the TV.
The manual for the TV is available at this review site: http://www.hdtvreview.com/Polaroid-1513-TDXB-hdtv.html . The direct link to the manual is http://www.hdtvreview.com/pdf/polaroid-1513-tdxb-manual.pdf .
I hope this helps.
Jun 09, 2011 | Televison & Video
My granddaughter used my Wii dvd slot as a coin holder or a slot machine, and now my wii dvds will not come out. We took a dime out last week, and inserted a dvd without incident, but now that dvd is stuck...
you want to take off the side of the wii with a screwdriver (or whatever you might need) and see if you can see any coins lodged in there. If all else fails call nintendo and see if they can help you.
Mar 01, 2010 | Video Game Consoles & Games
Dvd stuck in tv dvd player
According the owners manual you will have to call PROSCAN customer support for help with this problem. The telephone number for customer support is 1-888-977-6722. You can also go to The website and use the customer support there. The website for PROSCAN is www.oncorpus.com. I hope this has helped you with your problem.
Mar 12, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
Sunia LTD-1720 17" Color LCD TV and DVD Player Combo with Remote
i have a sunia tv anddvd combo need a remote and programming instruction for it. the remote model is rc518n than you
Apr 26, 2008 | Televison & Video
Mintek 263
I understand your problem. Please try my solution and even though it is the same manufacturer but a different model number
but I think it will work. I have posted my solution in this site
and also other fix-it sites but I will post it here for you.
Late last year, my friend had the same problem. She and her friends tried for two months but it was impossible to physically pulled the stuck DVD out from the unit. I was happened to be in the area and she asked me if I can help her retrieved her movie
DVD disc which was stuck inside the MinTek DTV-265-D.
GOOD NEWS! I was successful in getting the
stuck DVD disc out of the unit and back into her hands.
Here is what I did to fix the stuck DVD problem:
I. Requirements
a. Tools:
Phillips Screwdriver (magnetic head will be the best)
Tweezers - Only if you don't have a magnetic Phillips screwdriver
Flashlight
b. Surface:
Large flat padded table because you will need it to lay the TV - flat.
c. People:
I did it by myself but having an extra hands is a plus.
II. Instructions
1. Disconnect power cord, power switch button "off" position, unplug cables and video cables from the unit.
2. Place the TV unit flat on the surface - screen on the bottom - Back cover side facing up
3. Back Stand: Remove the TV bracket stand in the back by unscrewing the 8 screws.
4. Back Cover: Unsecured the back cover panel side of the unit - 9 screws (After unscrewing the screws you might need to use the tweezers to lift and remove the screws.)
5. Back Cover: Carefully lift (unlock) the back cover panel slightly away from the screen unit slowly because it is wired to the circuit board. In other words, you can't remove it completely which it is OK and it is not necessary. This back cover panel removal sounds easy but the cable coaxial connector block it and making it difficulty.
Therefore, you will have to wiggle the cover until it is free and away from the coaxial connector because you will need some clearance space to access the DVD unit.
6. DVD Unit: Unlock the DVD unit by unscrewing 4 (silver) screws.
7. Now you are set and ready to release your stuck DVD.
An extra hands will be nice to have but two hands is a requirements to do the next couple of steps.
8. DVD Unit:
On the front side, locate the two (black triangle-shape or arrow shape) slot holders.
They are in a locked position.
Using your fingers lift and hold both sloth holders in the up position.
(You might have to raise these holders (up and down) several times.)
As you are holding up these slot holders please perform the next step (#9).
9. Power:
Push power button on the unit switch "on"
Plug back the power cord into the unit AC inlet
Unit Ready Light: "red" standby light is on
Remote Control: Press the power/DVD button - st the remote to DVD Unit Ready Light: "Green"
** Important: Step No. 8 and Step No. 9 must be done simultaneously **
10. VIOLA! The DVD disc will automatically slide out of slot from the DVD unit.
Good Luck.
William
Jan 27, 2008 | Mintek LCD TV Progressive Scan DVD Player
Mintek 265D dvd stuck in drive
You need to take the back off the unit and you'll see the DVD . Take the DVD out . You may damage the DVD ( scratch it) but don't disasemble the DVD carriage or you may not get it back together. Good Luck
Ed
NC Electronic
Mills, Wyoming
Jan 06, 2008 | Mintek LCD TV Progressive Scan DVD Player
Dvd stuck in dvd
Lay the TV, face down on a folded towel. Remove all the screws. Note: there is one perimeter screw with machine threads; all the others are the same.
Remove the four black screws from this area:
Then you can pop the back loose and slide it towards the end where the black screws were. It just lifts off and there are no wires attached.
Now you can see the DVD player. I used the end of a plastic pen to shove against the edge of the DVD that you can see through this slot.
Press on the DVD's edge until you see it come out the entry slot.
You can see the DVD slide out the entry slot as you are pushing.
When done, slide the back into place and replace the screws.
Dec 31, 2007 | RCA 15L500TD 15 in. TV/DVD Combo
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
