Question about Fagor Ovens
Industrial fagor steam oven HEM 20/11 writes err2 and cc1
How to clean inbetween glass on oven door.fagor double oven
take door off the hinges and then unscrew the 2 halves open, wash glass dry really well and reassemble . if you do not get dry it can cause the glass to break when it gets HOT
Mar 19, 2016 | Fagor Ovens
How do i clean between glass doors on bottom oven of fagor fb1982x4 ?
disassemble door , clean glass , reassemble. door.
Jul 27, 2014 | Fagor Ovens
Where to find replacement elements. have found several sites in u.k. but are voltages compatible with u.s. versions?
Hi firstly, U.K uses 110 Vdc and rest of the world or most of the other parts of the world use 220-230 Vdc, so unless your Fagor 5HA200LX Oven has a built in voltage converter from 110 Vdc to 220 Vdc, which most new appliances have these days.
Try these shops:
http://www.fagoramerica.com/shop2/replacement_parts/halogen_oven#
http://www.guaranteedparts.com/category/FAGOR.html
Apr 29, 2014 | Fagor 5HA200LX Oven
Setting clock on fagor 6h-230 x
Fagor appear to be a poor quality brand of oven. I also cannot get the timer to turn on the oven. I am going to find out how to bypass it as I dont want to wasre more money on such bad quality machinery. T P Kennedy
Mar 30, 2014 | Fagor Ovens
Fagor oven has error code F06
I cleaned the smoke filter, took of the top cover, in front of electronics is the brown smoke sensor. I took of one wire off the sensor, started the oven (beware of not shortcutting anything) the f06 error message had disappeared. I put back the wire, mounted the top cover and the oven functions like new.
Nov 28, 2012 | Fagor 5HA-196 X Single Oven
Fagor oven will not regulate its temperature, once
From the symptoms you describe, I would say the oven thermostat is faulty, and in need of replacement.
This is the control you regulate the temoperature with.
Hope this helps.
Dec 15, 2009 | Fagor 5HA-196 X Single Oven
Gas to stay on
hi. thanks for the question. the part you need to replace is the thermocouple on the gas valve. replace that part. thanks the appliance doc
Oct 05, 2008 | Fagor 5HA-196 X Single Oven
Fagor overn doesn't heat
I had a similar problem - turned out the knob on the left by the clock was set to automatic instead of manual.
Dec 15, 2007 | Fagor 5HA-196 X Single Oven
Ovens Logo
71 people viewed this question
Top Fagor Ovens Experts
Dan Webster
Dan Webster
ray gallant
Bill Boyd
Are you a Fagor Oven Expert? Answer questions, earn points and help others
