Laptop asus pro31series won't start? - Computers & Internet
    Scholar:
    New Friend:
  • 58 Answers
The most common reason a computer won't start can be a piece of hardware has failed or is causing a problem but that hardware isn't usually a hard drive, the part of your computer that stores all of your files.To fix such kinds of issue, you can take the following steps.1.create a bootable usb or cd ,there are kinds of software for you to complete this step, you can choose Fix Boot,EasyBootDisk or Windows Boot Genius. I suggest you to use Windows Boot Genius, it is easier and more effective.2.boot your computer from the created disk3.fix the issue after run the softwareBy the way, before any further steps you should make sure the power supply is good. Any hardware issues such as pc power and cable,motherboard corrupted should be troubleshooted.I don't suggest you to try the solution above until you are sure there is nothing to do with the hardware.
source:http://windows-8-password-recovery.com/computer-wont-boot.html
Posted on Jan 16, 2013
My Asus X553M laptop is not booting up. Any ideas how to fix this problem?
Temitope, Hard reset. Open computer, remove battery,hold power button down (((1 minute))), reinsert battery, reassemble laptop, push/hold power button a couple seconds.
2nd fix, try to boot laptop without hdd.(hard drive). Remove the hdd, then turn on the laptop.. then it can get into the bios.. reset the bios to the default setting, turn off the laptop, and then turn it on again with hdd reinstalled. This seems to be what works in the forums with this issue found in Asus laptops. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Asus Laptop unable to boot black screen no bios
How to Fix Laptop that Won Turn On Asus X551M
Laptop Won Turn on Fix How to Hard Reset Laptop
Asus laptop not booting
Aug 21, 2016 | ASUS Computers & Internet
My Asus LaptopModel X205Ta is fully dead and won't charge or turn on.
MF. Could be the new charger is faulty, return charger for exchange or refund. Battery could also be faulty, have it tested if you can by a computer tech. Check the attached links,instruction and guides, Good luck
My laptop notebook will not turn on
my asus laptop wont even charge or turn on after it shut off mid windows...
Laptop Won Come On Even When Connected To Charger
Why Won My Laptop Turn On Even Though It Plugged In
Jul 09, 2016 | ASUS Computers & Internet
My asus laptop won't switch on
Can u give us some more info. Any proble
Jul 14, 2013 | Computers & Internet
Asus laptop won't wake up
please provide what model this is, different series has different solutions.
Mar 26, 2013 | ASUS 15.6" Laptop - 4GB Memory - 500GB...
Asus k55dr-sx051h laptop won't boot
More information required. Any messages on screen, noises etc?
Jan 28, 2013 | ASUS Computers & Internet
Asus wont turn on
For this kind of issue, please follow up the following steps to check:
1.confirm the battery and ac adapter connect the laptop normally.Maybe the bad connect lead to this problem. If there are no lights when you turn on laptop, one of possible reason is that your adapter is malfunction.
2.the second possible cause is laptop dc jack failure. If the dc jack is broken or loose, you are required to replace it or repair it.
3.Another possible reason is that there is something wrong with laptop motherboard. For this situation, it includs two kinds of possibility,a failure in an electronic circuit and BGA malfunction.
For more detailed reasons and solutions, please have a look at the following article:http://www.ifitjams.com/lappower.htm
If you verify your laptop adapter is dead and you plan to order a new one, I recommend one for you on the basis of your laptop model:
http://www.chargerbuy.com/laptop-ac-adapter/asus-ac-adapters.html
Nov 30, 2012 | ASUS K Computers & Internet
Asus k50ab won't start up or post
Jacob - have you had any success at fixing your laptop? If so, I would love to hear what the issue was. I have a friend that is experiencing the same issue.
Jun 30, 2012 | ASUS K50ab Amd Turion X 2, 2.2ghtz 320gb...
Want to factory reset my asus g71g laptop
So I assume "blue screen?" If so, you may have a memory error. Or it could be a number of things...you won't have to redo your computer to fix this. We just need to methodically go through the steps to correct the problems. First, are you able to go into safe mode? Press the "F8" key over and over and over during start up until you come to a black screen with options for starting the system. If you can do this, then choose "safe mode with networking" let me know if you are able to do this. Plus, what Antivirus program are you currently using?
Jun 09, 2012 | ASUS G71G, G71V, G72G, G72Gx, G72Gx-A1...
My asus laptop won't turn on and so I have it
may be the wire of the charger has got defect in it. check thoroughly. If your charger is OK it is problem with your motherboard.Replace it to get rid of the problem.
Feb 08, 2012 | ASUS Computers & Internet
My screen won´t turn on
you need do check:
1) find your laptop RAM memory stick location reference:
http://myeeeguides.wordpress.com/2008/10/15/eee-pc-1000h-ram-upgrade/
2) take out the RAM clean pins then reseat it back, turn on, if still dark screen your laptop got trouble at onboard memory, need send to repair.
hope hep you fix it, please feedback any question any time, pleaae take a rating let me know how much helped you thanks!
May 22, 2009 | ASUS Eee PC 1000H Laptop
Computers & Internet Logo
49 people viewed this question
David Payne
David Payne
