Question about Tools & Hardware - Others
Arrow jt27 staple gun won't load or staple
I loaded the staples like it says to do and it won't staple. It just jams. Help
Everyone here is assuming that you have fully operational gun. I have a business where we use these guns. I can tell you now that 3 out of 5 of the Arrow JT-27 just don't work. The staples won't advance. After looking at the information online, it is probably due to a weak spring. The best solution is to go with a different brand of stapler. This one is just not worth the trouble.
Posted on Sep 02, 2017
SOURCE: staple gun
Open the chamber and drop the staples upright in to the chamber do not try to load the staples by placing them on the strip that pulls out as you do with most staple guns.
Posted on Nov 25, 2008
SOURCE: LOAD IT
pull out the spring at the end of the gun. turn the staple gun upside down. Lay the staples in the track pointed side up, push in the spring slide so that it locks. You are ready to staple.
Posted on Dec 07, 2008
smartr10U
  • 1305 Answers
SOURCE: How to load Arrow T25 Staple Gun
at the back end of the handle, there is a retainer spring loaded clip. Push it in, then push it downward toward the base of the stapler, the clip should then release the spring, pull the rod with the spring completely out, slide a row of staple in where the rod came out, ONLY ONE ROW, then insert the rod with the spring back in and push it firmly in, and lift it upward to engage the lock. and fire away... Hope this gets your working
Posted on Jun 08, 2009
  • 384 Answers
SOURCE: How do I load the staples in this staple gun?
Push in and down the silver color piece at the end of the gun. Pull piece and spring out. Load staples, end down. Reassemble.
Posted on Jul 07, 2009
farmerbear
  • 490 Answers
SOURCE: Just purchased t27 arrow staple
That stapler takes a jt21 staple. some fill from the bottom when the plunger is in the drawn back position and some fill from the rear with plunger removed. If the plunger is attached, then it fills from the bottom. Hope this helps:)
Posted on Aug 24, 2010
Staples won't advance and come out
There may be a piece of a broken staple jammed in the end or the spring may be weak
Apr 19, 2013 | Swingline 747 Classic Desk Stapler, 20...
Staplegun driver won't retract enough for staple to load
Check for a piece of a broken staple wedged in the driver slot
Jan 14, 2013 | Tools & Hardware - Others
The staples won't go fully into the Wood
1. The wood may be too hard for the staples to penetrate
2. The stapler drive spring may have ghotten weak
3. You may not be holding the stapler nose firmly against the wood while stapling
Jan 06, 2013 | Stanley TR250 H Heavy Duty Heavy Duty...
Staples are loaded and won't shoot
check for a jammed staple near the end. This often happens and prevents the staple from feeding all the way
Sep 17, 2011 | Garden
Just got an ET50red electric staple gun. Loaded Arrow T50 14 mm staples with the points facing up and out of the tool. When I pull the trigger, the led worklight comes on, I hear and feel the stapler...
remove the staples and check inside for a jammed one up there. squirt some oil in there. load it again and try. please follow the instructions to a tee. having the wrong staples or what ever can damage the unit, if it isn't already. good luck
Jul 31, 2011 | Arrow T50P ARROW STAPLE GUN
Someone loaded regular staples into our Swingline 45 Optima now it will not work when loaded with the correct staples.
Using the wrong or style ofstaples, overfilling the machine and stapling through too-thick materials can causeOptima to jam. Now follow these steps: 1. Holdthe base down as you lift the top of the Optima stapler to access the stapletray. 2. Removeall the staples from the tray so that you have access to the jammed staple. 3. Turnthe stapler upside down and shake it to clear out staples you can't reach withyour fingers. 4. Gripthe jammed staple with the needle-nose pliers and, while holding the staplersecurely, pull it up. 5. Twistthe staple until it breaks into two pieces if it will not pull straight out.Pull out the two individual pieces. The Optima stapler line bySwingline is designed to be jam-free when Optima premium jam-free staples areused. Using another , style or brand may cause frequent jamming. Hope thiswill help you. Good Luck.
Jul 21, 2011 | Office Equipment & Supplies
How do you load staples in ET501? I pinch the back of the loader together but it won't pull out.
Try pinching it and pushing it down at the same time. If that doesn't work then there is likely a jam.
Jul 02, 2011 | Heavy Duty Arrow Et501 Electric...
My PHT150 SharpShooter is jammed and won't spring back. The staple plunger is sticking out and won't retract.
Sometimes a bit of the staple material will be sheared off and jam the hammer in its guide, keeping the tool compressed. On the business end of a PHT150 there is a notch in the hammer housing and a slot on the staple carrier. Most times a standard screwdriver can be used by sticking the tip straight into the slot and using the notch to leverage the the two apart. If not, you can clamp the hammer housing in a vise and, using the screwdriver in the carrier slot, tap away from the hammer housing to release the jamb.
May 31, 2011 | Stanley Tools Hammer Staple/Tacker -...
My Swingline Optima Power Ease will not staple, nor can I open it to try to find out why. There are staples in there, but it feels like there are no springs
This happened to me as well. I am not sure what causes this but heres what I did to fix it.
Just grab the top part of the stapler ( where it says Swingline) and pull up, like you are trying to seperate the top and bottom. You will hear a click and your stapler should work fine.
Sep 14, 2010 | Staples Swingline® 36115 Staple Guns Tools...
My gun will not shoot staples after loaded I thin there is a part missing
Staple gun are simple device and the 'shooting' mechanism is just a sring loaded bar that hammers the staple out: the problem is usually a jam/stuck staple where the staple in the orifice where the staple comes out. Just use a small screwdriver and /or plier to remove the stuck staple which could be jammed against the hammer bar. You may need to force the hammer bar backwards with the help of your small flat head screwdriver.
Hope it helps!
May 02, 2010 | Stanley CT10C Heavy Duty Staple Gun/Cable...
Tools & Hardware - Others Logo
340 people viewed this question
Top Tools & Hardware - Others Experts
Are you a Tool and Hardware - Other Expert? Answer questions, earn points and help others
